Inverter
Discussion in 'General Tacoma Talk' started by asanelli, Oct 12, 2023.
  1. Oct 12, 2023 at 7:51 AM
    asanelli
    asanelli [OP] Well-Known Member
    Tony
    Golden CO
    3rd Gen Tacoma TRD Offroad
    I have a 3rd tacoma with the OEM outlet inverter which is rated for 400W and 120VAC. I calculated that this equates to 3.33A. I have a device (electric kettle) that is max rated at 1500W and 120VAC which is 12.5A.
    Can I use the kettle in the OEM outlet inverter albeit the kettle will take significantly more time to heat at a lower amperage? Or will the breaker pop immediately? Or will the battery drain quickly?
  2. Oct 12, 2023 at 8:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You will most likely just trip the overload as that's almost 4 times it's rated output.
    tcjacado likes this.
  3. Oct 12, 2023 at 8:46 AM
    tcjacado
    tcjacado Well-Known Member
    Pretty sure the 400 watt power is only when the engine is running. If the engine isn't running the output drops to less than half.
  4. Oct 17, 2023 at 5:38 PM
    azjim2001
    azjim2001 Active Member
    Jim
    2001 Tacoma 4x4 crew
    Hopefully the breaker or fuse trips.
    Burnt wiring becomes the fuse otherwise.
