Invertor needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Nov 9, 2020.
  1. Nov 9, 2020 at 9:40 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    Hello,
    Can someone please tell me what invertor I can use to power 48V 17.5 Ah 3Amp and 48V 14Ah lithium-ion battery . I am getting Sondors Fold XS and XS ebikes and want to charge the batteries while I am driving so I would like to get the correct invertor. I was looking at this one from Costco. These are the chargers needed to charge the batteries.
    https://shop.sondors.com/products/battery-charger-48v
    https://www.costco.com/duracell-300...mLLrjhFQ/GZ/xS/n0O1nfenrKwk0SHCSLPjKn+1ucVA==
    Thanks for your help and suggestions.
  2. Nov 9, 2020 at 9:55 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    3amps at 120v = 360watts. That 3000w duracell would work, but would be way overkill. A 3000w inverter can provide more amps than your standard house circuit.
    If it were me and I weren't using the inverter for anything more than that charger and maybe some lights or something I'd go with something like this: The wiring requirements for the lower amperage wouldn't be nearly as onerous. I'd imagine with a 3000w inverter you'd want like, 2/0 wiring if you're putting it in the bed away from the battery, you'd be pulling 250amps if you were to use all the load available. A 750w inverter is 62.5 amps @ 12v and could probably be done with 4 gauge.
    Or if you have the inverter built into the bed it should handle it fine, that's 400w.
  3. Nov 9, 2020 at 10:06 AM
    boxxed
    Denver, CO
    09 Off Road
    I thought it might be over kill.. I do have the invertor built in but I want to charge 2 batteries at the same time. I didn't think the built in could handle it while driving.
    With the HarborFreight one can I hardwire it from the battery so the invertor in the cab somewhere?
    Thanks
  4. Nov 9, 2020 at 10:13 AM
    spencermarkd
    Spencer
    Two chargers at 360w = 720 total watts. I'd go to a 1000w inverter then for some headroom so you aren't running it at full capacity all the time. Built-in won't handle two chargers, you're right.
    Yes, you can wire it anywhere you want to, but if you aren't comfortable with it, please get a professional to do it. An inverter installed incorrectly (wrong wire size, poorly crimped/soldered ends, wired incorrectly, put in without a fuse, run where it could chafe, run to a spot without enough ventilation, etc etc etc) could burn your truck down pretty easily.
    Muddinfun likes this.
  5. Nov 9, 2020 at 10:18 AM
    boxxed
    Denver, CO
    09 Off Road
    Appreciate it.. Thanks for the info and the warning.
  6. Nov 9, 2020 at 10:24 AM
    dbbd1
    dbbd1 Well-Known Member
    Or,
    Use the truck inverter for one battery and a new, small unit for the second.
    Muddinfun and boxxed[OP] like this.
  7. Nov 9, 2020 at 1:02 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    And how much does all this affect your current alternator? Will it be able to keep up?
    I know our trucks came with two sizes depending on trim level.
  8. Nov 9, 2020 at 1:07 PM
    boxxed
    Denver, CO
    09 Off Road
    I dont know the exact number but because I have the tow package with was the better alternator.
    Thanks
