Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Jan 16, 2020 at 5:11 AM
    #5041
    GQ7227
    GQ7227 mw survivor
    J A Y
    its always nice when it rains hard first before the snowstorm then they cannot put that garbage down because it will just wash right off the road
    but then they just end up using something else
  2. Jan 16, 2020 at 5:16 AM
    #5042
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I don’t know how my frame didn’t need replacing!
  3. Jan 16, 2020 at 5:26 AM
    #5043
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you routinely wash it off when the temps are right about freezing?
    or use some anti-corrosion sprays
  4. Jan 16, 2020 at 5:29 AM
    #5044
    PennSilverTaco
    Charlie
    I wouldn’t say I do routinely, but I do wash it several times a winter; Definitely don’t use anti-corrosion sprays...
    My truck was approved for the anti-rust spray back in October 2017 and my local dealer did that; Dealer says they are willing to go to battle for me against Toyota if I ever need a new frame.
    GQ7227[QUOTED] likes this.
  5. Jan 16, 2020 at 5:32 AM
    #5045
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you spray your suspension parts, axle, driveshafts,etc with anything to keep them looking good?
  6. Jan 16, 2020 at 5:33 AM
    #5046
    PennSilverTaco
    Charlie
    No, and aside from very minor surface rust they look great!
    Also, my truck hasn’t been regularly exposed to snow and slush.
  7. Jan 16, 2020 at 5:37 AM
    #5047
    GQ7227
    GQ7227 mw survivor
    J A Y
    your truck is only 9 years old, my relative has an '11 single cab that i just sprayed all underneath everywhere and there were just some crusty minor spots popping up but I wanted to keep it from getting any worse.
    it looks real sharp at night under there with headlights on the rear axle, black and shiny
  8. Jan 16, 2020 at 5:44 AM
    #5048
    PennSilverTaco
    Charlie
    Actually, my truck is technically ten years old, as it was manufactured in August '09 and purchased in September '09. I can tell you right now that Michigan is the one state I'd never buy a used Tacoma form, no matter how good it looked!
  9. Jan 16, 2020 at 6:44 AM
    #5049
    OperatorOneNine
    OperatorOneNine Well-Known Member
    Jake
    2020 Tacoma TRD Off-Road Premium
    Our roads are currently white, as of this morning. Like a sheet of paper. Looks like they went crazy after the fact on the ice.... Like i mean WHITE. Now I can't wait until it's above freezing so I can wash my truck again.
    PennSilverTaco and GQ7227 like this.
  10. Jan 16, 2020 at 6:47 AM
    #5050
    GQ7227
    GQ7227 mw survivor
    J A Y
    the white stuff i am assuming doesn't go into effect until it combines with moisture, humidity or whatever, and the whiteness disappears?
  11. Jan 16, 2020 at 6:48 AM
    #5051
    OperatorOneNine
    Jake
    No. It's bad period. Even when dry the cars around you kick it up in a cloud that sticks to your vehicle.
  12. Jan 16, 2020 at 6:48 AM
    #5052
    GQ7227
    GQ7227 mw survivor
    J A Y
    i meant that it doesn't start to corrode anything until it gets wet?
  13. Jan 16, 2020 at 6:49 AM
    #5053
    OperatorOneNine
    Jake
    If it sticks to your vehicle it's eventually going to be a problem.
    Shellshock and GQ7227[QUOTED] like this.
  14. Jan 16, 2020 at 9:34 AM
    #5054
    Shellshock
    Iowa
    They dumped truckloads of sand around here. The gravel roads are 100% ice. It caught me off guard last night and the back end was going all over the place til I kicked in 4wd
  15. Jan 16, 2020 at 10:06 AM
    #5055
    OperatorOneNine
    Jake
    That's how they used to do it here. They still do that in the more rural area's and on the gravels. They used to do that everywhere, though.
  16. Jan 16, 2020 at 11:30 AM
    #5056
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    They’ve been dumping sand on the gravel roads here too. I just put it into 4wd as soon as I get off pavement. Between the curvy roads and the hills if you aren’t prepared you could easily go skidding off the road and go tumbling down the road. The roads are not fun when things are melting off them.
    GQ7227 likes this.
  17. Jan 16, 2020 at 12:05 PM
    #5057
    OperatorOneNine
    Jake
    Looks like we are actually going to get a bunch of snow tomorrow. Working from home and hoping to do some four wheel drive things tomorrow evening or Saturday. Although I need to grab a tow strap and a shovel.
  18. Jan 16, 2020 at 12:10 PM
    #5058
    Shellshock
    Iowa
    I should probably put my maxtrax back in my truck before I forget
  19. Jan 16, 2020 at 12:22 PM
    #5059
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Probably not a bad idea. As much as we are doing the freeze, melt, freeze, my yard is a swamp. Keep some boards on both in case we bury one.....
    GQ7227 likes this.
  20. Jan 16, 2020 at 12:41 PM
    #5060
    Shellshock
    Iowa
    Everything here currently is ice, which is going to make it real fun when the snow starts flying later today and through tomorrow.
    Sociopenguin[QUOTED] likes this.
