Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Nov 11, 2020 at 9:55 AM
    #8781
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    I washed it, and moved my mud flaps out wider. Soooo, yea. I’m pretty awesome too
  2. Nov 11, 2020 at 10:02 AM
    #8782
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Gona be doing many fluids here in <2k miles
    Thatbassguy likes this.
  3. Nov 11, 2020 at 10:22 AM
    #8783
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Short list of work in the last 6 weeks.
    Tacoma - 109,3xx miles:
    Driveshaft u-joints - grease
    Cabin filter - replace
    Front, Rear & Xfer case fluid - change
    MAF & Throttle body -cleaned
    Spark plugs & PCV - replaced
    Power steering, Brake, Coolant - change
    Transmission fluid & filter - change
    Daughter's TrailBlazer - 118,5xx miles:
    Rear Diff fluid - change
    Spark plugs - change
    Edit Damn forgot ----Fuel filter - change
    Brake Master Reservoir - change (source of green stuff)
    Serp belt, idle pulley & tensioner - replace.
    $$ saved vs dealer = BIG $$$
    Just the tranny work on the Taco was quoted at $650
    Serp belt system work on Taco is quoted at $1130
    GQ7227 and CygnusX191 like this.
  4. Nov 11, 2020 at 10:36 AM
    #8784
    Shellshock
    Iowa
    Just did a wheel bearing on @Tigerian truck
    dealer quoted $900. I did it for under $200
    CygnusX191 likes this.
  5. Nov 11, 2020 at 10:51 AM
    #8785
    Knute
    In this time of Covid and income has been slashed by 75%, means need to save as much as possible while keeping the vehicles usable.
    I want to do some upgrades to the truck like Head Unit & speakers, replace the rims (corrosion causing paint to flake off exposing aluminum to weather) and tires. But these are WANTS. NEEDS must come first; mortgage, food, utility, clothing, maintenance (house & vehicles)......and job hunting.
    Normally, I would avoid this heavy mechanical work, but necessity is forcing grease and dirt under my fingernails.
    Anyhow, Stay well.
    Good work on the wheel bearing. I know its not a simple task.
  6. Nov 11, 2020 at 11:17 AM
    #8786
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like you've got major hustle work ethic. If only America could take a lesson.
    Good luck man. What kind of work are you looking for? If I may ask
  7. Nov 11, 2020 at 11:20 AM
    #8787
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Nice, did you buy it from that fella on here that presses them?
  8. Nov 11, 2020 at 11:27 AM
    #8788
    Shellshock
    Iowa
    Got the assembly from o’reilly
  9. Nov 11, 2020 at 11:30 AM
    #8789
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yeah I answered my own question when I found the thread and saw prices...never done one myself but thought I'd ask, hopefully he has good luck from the parts store as far as quality
    Definitely has luck on his side with $ saved!
    :cheers:
  10. Nov 11, 2020 at 12:36 PM
    #8790
    Shellshock
    Iowa
    Yep. I figure we can buy a few if we need to and still come out ahead
  11. Nov 14, 2020 at 11:45 AM
    #8791
    Iwilltaco
    Under development
    Did the same thing on my 2nd gen. After I told the guy at the dealer I was pretty sure it was the bearing, mechanic rode with me, agreed it was the bearing. Then they quoted me like 150 to diagnose, and if it was bearing 600 to replace. So got assembly from oreilly and watched a video. Had no issues for 40k miles before I sold my truck. And I’m no mechanic
  12. Nov 23, 2020 at 12:53 PM
    #8792
    Iwilltaco
    Under development
    I guess it’s officially winter. The roads here have been sprayed with the nasty solution
    CygnusX191 and GQ7227 like this.
  13. Nov 23, 2020 at 1:04 PM
    #8793
    Shellshock
    Iowa
    It’s apparently snowing in Des Moines
  14. Nov 23, 2020 at 1:05 PM
    #8794
    Iwilltaco
    Under development
    I don’t like snow if it just makes the roads a mess. Big snow or no snow!
  15. Nov 23, 2020 at 1:06 PM
    #8795
    Shellshock
    Iowa
    Totally agree. Give me like 6 feet
    CygnusX191 and Iwilltaco[QUOTED] like this.
  16. Nov 23, 2020 at 1:10 PM
    #8796
    Iwilltaco
    Under development
    That would be a sight when I open up the garage door
  17. Nov 23, 2020 at 1:19 PM
    #8797
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I am down for this
    Shellshock[QUOTED] likes this.
  18. Nov 23, 2020 at 4:45 PM
    #8798
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Yes.
  19. Dec 3, 2020 at 11:27 AM
    #8799
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sooo..............
    Slashaar and Sociopenguin like this.
  20. Dec 3, 2020 at 11:28 AM
    #8800
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    What?
    Slashaar likes this.
