Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Mar 30, 2021 at 8:22 AM
    #8901
    Shellshock
    Iowa
    Here’s how i did mine - without touching LCA bolts
    Put front of truck on jack stands
    Remove front tires
    Remove skid plate
    Remove sway bar
    Put jack under LCA
    Remove the bolt for brake line
    Jack up LCA
    Remove top spindle bolt
    Slowly lower jack
    Remove lower shock bolt
    Remove 3 top shock bolts
    Remove shock (you may need to pry the LCA arm down slightly to remove or reinstall shock)
    Reverse to put it all back together
    The rear shocks - Be prepared for the top shock nut to be a pain. Either from rust or just because you cant get to it.
    Save yourself the headache and get a nut splitter
    Jack up truck
    Remove upper shock nut (may require persuasion)
    Leafs are just a bolt front / rear + U Bolts
    Make sure you support the axel so you dont rip off ABS or other things attached
    Depending on the age of your truck you may require pb blaster, impact wrench or large breaker bar
    Mine wasnt too bad for being 3 years old.
    MrBrooks and TacoFergie[QUOTED] like this.
  2. Mar 30, 2021 at 2:18 PM
    #8902
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And grease the puck out of your leaf spring bushings before you put them back in (red will do). Makes a tough job and much quicker less tough job.
    Also with the rear, remove both shocks before you drop the axle. Put the shocks back on last. Otherwise, because of their not straight alignment, it'll twist the axle while you're trying to work on it.
    TacoFergie likes this.
  3. Mar 30, 2021 at 2:51 PM
    #8903
    Whelk88
    Whelk88 Member
    IL/IA
    2020 White TRD Sport DCSB
    Thanks for all the write-ups, but due to personal situations, its not something that I'd be able to install myself unfortunately.
    TacoFergie and CygnusX191 like this.
  4. Mar 30, 2021 at 2:57 PM
    #8904
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Just go to @Shellshock 's house and make him do it
    TacoFergie, Tigerian and Shellshock like this.
  5. Mar 30, 2021 at 2:57 PM
    #8905
    Shellshock
    Iowa
    Not like I’ve got anything better to do.. plus hes got a 2020 so its not got years of rust making everything difficult
  6. Mar 30, 2021 at 3:01 PM
    #8906
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    Don't be spreading my install secrets like that.:rofl:
  7. Mar 30, 2021 at 6:15 PM
    #8907
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If you have access to the Arsenal the Auto Shop can help you get it done. Otherwise, seriously, find a buddy like @Shellshock to help you.
    CygnusX191 likes this.
  8. Mar 31, 2021 at 5:28 AM
    #8908
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Absolutely! Mine was about 4 years old when I installed the 3rd gen suspension and just last summer I installed the 6112/5100's. I found out from my own mistakes of not lubing certain things when I installed the 6112/5100's.
    Very good point with that!!! I ended up leaving the U-bolts loose (but tight enough that the centering pin would stay in) on one side while doing the other.
    If you were on the western side of Iowa I would be more than willing to help out!!!
    ClevSix and CygnusX191[QUOTED] like this.
  9. Mar 31, 2021 at 7:56 AM
    #8909
    Whelk88
    Whelk88 Member
    IL/IA
    I mean if you’re willing and bored, just let me know how much you’d want :notsure:
    ClevSix, TacoFergie and CygnusX191 like this.
  10. Apr 7, 2021 at 10:42 AM
    #8910
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Thanks for the tips @Shellshock I got the Eibach kit & SPC's done today & have appt for alignment next week. The ride is so much better than those Hitachi's!
  11. Apr 12, 2021 at 11:44 AM
    #8911
    MrBrooks
    Midwest
    Been doing some reading about KDMax over the weekend. @Shellshock have you tried it out yet or plan on getting in on it as a tuner?
  12. Apr 12, 2021 at 1:02 PM
    #8912
    Shellshock
    Iowa
    I’m not offering it at this time but possibly in the future. I’ve been following it talking with some people that have run it. I’ve got a MT so my experience is going to be much different than someone with an AT
    it’s still quite new and being updated. I want to see if any issues crop up and if more changes are made. Otherwise I’ll end up having to update people all the time.
  13. Apr 12, 2021 at 2:51 PM
    #8913
    MrBrooks
    Midwest
    Yea sounds like there's some updates to vftuner going on & then maybe some learning woes to go along with it for the new features. Lots of good reviews & I'm definitely liking the idea of having better low end torque plus better gas mileage!
  14. Apr 12, 2021 at 5:30 PM
    #8914
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's a miracle for these trucks for sure.
    MrBrooks[QUOTED] likes this.
  15. Apr 12, 2021 at 6:29 PM
    #8915
    MrBrooks
    Midwest
    I wouldn't say my truck drives horrible after the TSB flash but it could be improved on. I never did get OVT but I'm seriously thinking about buying the vfTuner & playing around with KDMax. There's a few guys around here that would probably want to try it also
    CygnusX191[QUOTED] likes this.
  16. Apr 12, 2021 at 6:34 PM
    #8916
    Shellshock
    Iowa
    Just an FYI but if you buy kdmax, that’s not an editable file. You can flash it but that’s all
    just making sure you know
  17. Apr 12, 2021 at 6:48 PM
    #8917
    MrBrooks
    Midwest
    Right I just meant trying the different files for fuel & tip in. Gonna wait awhile & see how this all progresses
    I would love to get rid of that harsh kick down at hwy speeds. Kinda ridiculous
    CygnusX191 and Shellshock like this.
  18. Apr 12, 2021 at 7:10 PM
    #8918
    Shellshock
    Iowa
    Oh for sure. That’s why I got rid of my AT 4 years ago. There’s been a ton of progress over the last year and I’m sure it’s way better these days especially with tuning
    CygnusX191 and MrBrooks[QUOTED] like this.
  19. Apr 12, 2021 at 8:35 PM
    #8919
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    What's this newfangled KDMax?
  20. Apr 13, 2021 at 7:36 AM
    #8920
    MrBrooks
    Midwest
