Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Jan 15, 2022 at 6:45 AM
    #9021
    Shellshock
    Iowa
    OperatorOneNine Ghosted us
  2. Jan 15, 2022 at 11:16 AM
    #9022
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :pout:
    Slashaar and Sasquatch3153 like this.
  3. Feb 3, 2022 at 7:48 AM
    #9023
    Sakhone712
    Sakhone712 Well-Known Member
    Sakhone
    2016 TRD OFF Road Silver
    Any Des moines people here have a shop lift their truck for there. Looking for recommendations.
    Sasquatch3153 and CygnusX191 like this.
  4. Feb 3, 2022 at 11:36 AM
    #9024
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Assuming you're doing an actual suspension lift, you can do it in your home garage with a buddy and a few hours. No need to pay a shop $1,000.
    What lift are you getting?
  5. Feb 3, 2022 at 1:43 PM
    #9025
    Sakhone712
    Sakhone
    Eibach pro stage 1 and probably get the UCA to make alignment easier. i think i might have found a shop that is actually reasonable.
    CygnusX191 and Sasquatch3153 like this.
  6. Feb 3, 2022 at 1:48 PM
    #9026
    Sakhone712
    Sakhone
    Reading forums now to see which UCA's to go with but sounds like a lot of people dont.. i just want to for ease of mind. so researching UCA's atm, if you got suggestions let me know
    CygnusX191 likes this.
  7. Feb 3, 2022 at 3:19 PM
    #9027
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    There are a lot of good ones out there, I've got SPCs on mine, I actually wasn't going to do UCA since I'm only at 2 in the lift but this set showed up still wrapped in plastics still in the box for 50% of retail. So I took them.
    Super happy with them and love the greaseable joint cuz it means I can keep it fresh and maintained. The adjustability is second to none as well.
    Sasquatch3153 and Slashaar like this.
  8. Feb 3, 2022 at 3:22 PM
    #9028
    Sakhone712
    Sakhone
    Sounds good thanks for the input.. Haven't seen anyone posted.. but time to order some parts and finally lift after 4 years
  9. Feb 3, 2022 at 3:26 PM
    #9029
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I run SPC LR UCAs. I chose them for the adjustability.
  10. Feb 3, 2022 at 5:28 PM
    #9030
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    I did the same Eibach kit with SPC UCA's. Probably didn't need the SPC's & they were harder to put in than the lift. Took me all afternoon to get the long bolts out & back in. No shop around here will want to deal with bending the metal around the bolts just to install them. I guess it just depends on what size tires you're gonna put on to decide on UCA'S or not
  11. Feb 3, 2022 at 5:31 PM
    #9031
    Sakhone712
    Sakhone
    Well then haha.. I ordered the spcs already lol I'll talk to the shop and see what they can do.. I just figured alignment would be easier if installed. Thanks for the advice.
  12. Feb 3, 2022 at 5:47 PM
    #9032
    MrBrooks
    Midwest
    Yep I thought the same thing. If you end up putting them in make sure you repaint those areas where the metal was bent so they don't rust from our salty Iowa life!
  13. Feb 3, 2022 at 5:48 PM
    #9033
    Sakhone712
    Sakhone
    What should I use for those spots?
  14. Feb 3, 2022 at 6:11 PM
    #9034
    MrBrooks
    Midwest
    I just used a few heavy coats of satin black rustoleum spray paint where I scratched it up with vice grips
  15. Feb 3, 2022 at 6:14 PM
    #9035
    Shellshock
    Iowa
    That’s why most people cut the bolt and then put in a new one from the other side
  16. Feb 3, 2022 at 6:30 PM
    #9036
    MrBrooks
    Midwest
    I thought about doing that but sourcing those from the dealership was gonna take too long time wise
  17. Feb 3, 2022 at 6:51 PM
    #9037
    Sakhone712
    Sakhone
    All I know is.. I'm totally excited lol
    CygnusX191 and MrBrooks like this.
  18. Feb 4, 2022 at 12:30 AM
    #9038
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    As you should be.
    Have your alignment tech set the caster between 2 and 4, camber at 0, and toe at the tiniest of incrimiments (inward) if you're going for larger tires. This will help keep them from rubbing/hitting anything when you hit a speed bump/pot hole/yuge rock
    Slashaar likes this.
  19. Feb 4, 2022 at 4:14 PM
    #9039
    Slashaar
    Josh
    Kansas City, MO
    Also, should be pretty obvious, but you know some techs lack sense. Make sure they don't bend your cam tabs trying to hit numbers.
  20. Feb 5, 2022 at 7:38 AM
    #9040
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This. Found out the hard way some d-nag tech at plaza tire royally effed the passenger side LCA... It'll align, but straight is just wishful thinking at this point. Got a list of junkyard parts I'll be hunting down this summer....
