Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Dec 11, 2013 at 12:27 PM
    #981
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I ordered some poly bushings for the new steering rack, should be nice and tight.... twss
  2. Dec 11, 2013 at 12:30 PM
    #982
    krap22
    krap22 Well-Known Member
    I'm going to order some tires, spacers, 5100s, and brake pads. I'll have a few things to do.
  3. Dec 11, 2013 at 12:33 PM
    #983
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Wheel spacers?
  4. Dec 11, 2013 at 12:42 PM
    #984
    krap22
    Yes
  5. Dec 11, 2013 at 12:47 PM
    #985
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    My list of stuff already purchased and some I still need is as follows:
    Pioneer head unit
    CB radio
    Wheel spacers
    Wheels and tires
    Icon coilovers
    Rear springs and shocks
    Spec stage 2 clutch
    Flywheel
    Energy suspension rack bushings
    Tie rods
    Light racing upper control arms
    Lower control arms
    Hawk brake pads
    Brake rotors
    Stainless braided extended brake lines
    Rear e-locker axle
    Front diff maybe?
    4.56 gears
    And then of course armor...
  6. Dec 11, 2013 at 12:53 PM
    #986
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have a SWR meter and extra piece of coax if you wanna tune the CB.
    So when's this shit goin' down? :D
  7. Dec 11, 2013 at 12:56 PM
    #987
    krap22
    Not sure when the garage is available
  8. Dec 11, 2013 at 1:02 PM
    #988
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Forgot doug thorley headers, borla catback, magnaflow catalytic converter, deckplate, fuel filter, belts, and some other crap.
    I plan on taking it all back home when I get everything and installing it on a hoist. 4 guys and a couple days and we should have it done. The hardest part will be taking everything off because of rust. A torch and grinder will help.
    The CB won't be done until I get my rear bumper made since the firestick will be mounted on it. But the cb radio is already peaked and tuned so it should be an easy install.
  9. Dec 11, 2013 at 1:13 PM
    #989
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Damn, that's a hell of a list. This weekend is no good for me, probably be more available after the holidays.
  10. Dec 11, 2013 at 1:14 PM
    #990
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Why do you need those? The tires you are getting shouldn't have any issues fitting.
  11. Dec 11, 2013 at 1:16 PM
    #991
    krap22
    I want them to stick out a little further :eek:
  12. Dec 11, 2013 at 1:25 PM
    #992
    MowTaco
    Kansas
    I wish I could give you some of my sticky-outiness haha. One puddle and your truck is covered in whatever you just went through. Although it flings water up in the air like indy cars do, so that's neat I guess
  13. Dec 11, 2013 at 1:29 PM
    #993
    MowTaco
    Kansas
    Also that CB will have to be retuned when the antenna is installed.
  14. Dec 11, 2013 at 1:34 PM
    #994
    krap22
    I'm not going too far, just a little to change the stance.
  15. Dec 11, 2013 at 1:57 PM
    #995
    MowTaco
    Kansas
    Yeah my spindles put me at 3"over, so 1.5" over each side. about half the tire sticks out the wheel well.
  16. Dec 11, 2013 at 2:04 PM
    #996
    krap22
    I'm looking to only go about 1", It should bring the edge of the tread even with the fender.
  17. Dec 11, 2013 at 7:21 PM
    #997
    t4rwadle5
    t4rwadle5 Well-Known Member
    Nick
    Iowa
    Rotating Garage
    Current Inventory 2015 Lexus GX460 2017 Subaru Outback 3.6R-#dadwagon
    Yeah that's what I was reading just dependent on tire brand and model. Ill post pics when he is done.
    And yes!!! Someone needs to walk me through a tranny flush!?!?
  18. Dec 11, 2013 at 7:26 PM
    #998
    krap22
    I'll let you know in a week or so. I just ordered the Cooper ATPs in 265/75/16.
    I'm not going to touch that one
  19. Dec 12, 2013 at 7:27 AM
    #999
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    This weekend I am dropping the steering rack and installing poly bushings and welding the tie rod ends to the rack. Also going to take about a half inch of preload out of my coilovers, and maybe remove my overload leaf if it looks goofy. Alignment on Monday.
    Laid my first couple of beads on the welder last night, going to need a ton of practice...
  20. Dec 12, 2013 at 7:28 AM
    #1000
    krap22
    welding is definitely an art form.
