Iowa Tacomas (Idiots.Out.Wandering.Around)
Discussion in 'Mid West' started by fuzznuts, May 4, 2009.
  1. Dec 12, 2013 at 7:46 AM
    #1001
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    The main thing is your heat and wire speed setting need to be set properly. Then you just train yourself to see where you need to go and move at a constant pace. If you can keep your hands stationary and not weld vertical, the welds will be much easier.
    Welding to the rack might prove difficult. It's probably not plain steel, might be tempered or a hard alloy of some sort. It's hard to figure out how much heat and penetration you get on odd metals.
  2. Dec 12, 2013 at 4:48 PM
    #1002
    t4rwadle5
    t4rwadle5 Well-Known Member
    Nick
    Iowa
    Rotating Garage
    Current Inventory 2015 Lexus GX460 2017 Subaru Outback 3.6R-#dadwagon
    Actually the week after Christmas I will have an entire heated garage if people want to work on several different vehicles at the same time? Maybe play buck hunter and drink keg beer?
  3. Dec 15, 2013 at 8:39 AM
    #1003
    Dewey T
    Dewey T Member
    Muscatine,Ia.
    07 prerunner sr5
    Will sand bags in the back of my 2wd help with traction ? Tires are new just spins pretty easy at take off.
  4. Dec 15, 2013 at 8:40 AM
    #1004
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Yes, I always put a couple hundred pounds in the back of my 2wd. Right over the rear axle.
  5. Dec 15, 2013 at 8:43 AM
    #1005
    Dewey T
    Dewey T Member
    Muscatine,Ia.
    07 prerunner sr5
    Cool thanks.
  6. Dec 15, 2013 at 3:45 PM
    #1006
    t4rwadle5
    Nick
    Iowa
    Rotating Garage
    Saw a black 2nd gen lifted on black wheels with spare mounted in bed and offroad lights on the front? On Hickman? Anyone on here?
  7. Dec 15, 2013 at 5:18 PM
    #1007
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Just got back from the first ever Marshalltown meet...
  8. Dec 15, 2013 at 6:23 PM
    #1008
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    And last ever lol.
  9. Dec 16, 2013 at 5:27 AM
    #1009
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Got the steering rack done this weekend, the poly bushings I installed are awesome. Took the vibes out of the steering wheel, nice and tight turning. Also dropped a bead on both of the inner tie rods to keep them in place. At the alignment shop now... hope it goes well...
  10. Dec 16, 2013 at 6:49 AM
    #1010
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Alignment is finished, not crazy about the results, but it at least drives normally again. I wanted the caster to be in the 2.5 range, instead I got 1.7 on the left and 3.4 on the right...
  11. Dec 16, 2013 at 6:49 AM
    #1011
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Sign me up for this!
  12. Dec 16, 2013 at 7:06 AM
    #1012
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    How they got 3.4 is what I'm wondering... I thought they maxed at 1.7. That's why you need UCAs to get the desired 3.
  13. Dec 16, 2013 at 7:14 AM
    #1013
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I've got LR uppers that are set at 2 to begin with... I feel like they just don't really care what I have to say about getting it to 2.5, cuz it shouldn't be hard.
  14. Dec 16, 2013 at 7:15 AM
    #1014
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Ohhh yeah it should be spot on then.
  15. Dec 16, 2013 at 10:35 AM
    #1015
    Renaud33
    Renaud33 Well-Known Member
    Pretty sure I met you on 63rd/hwy 28 around 8:30 on Sunday evening.
  16. Dec 16, 2013 at 1:49 PM
    #1016
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    Where did you go? I went to toyota of DM and they were able to get it exact Sure it may be a little $$$ more there but they listened and got to right on for me but i do have TC UCA maybe that makes a different wouldnt think so though considering you got the LR UCA
  17. Dec 16, 2013 at 1:51 PM
    #1017
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Firestone on 22nd
  18. Dec 16, 2013 at 1:55 PM
    #1018
    LouTaco
    Lou
    Des Moines, Iowa
    Go back tell them to get it spot on or refund
  19. Dec 16, 2013 at 2:33 PM
    #1019
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Did you get the lifetime alignment? You can get unlimited alignments for just your time.
  20. Dec 16, 2013 at 10:52 PM
    #1020
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Yeah I did
