iPad Mini dash kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by rafanomenon, Feb 13, 2016.
  1. Feb 13, 2016 at 2:48 PM
    rafanomenon
    rafanomenon [OP] Well-Known Member
    Seattle, WA
    2019 Off-Road Manual Transmission
    - @toyotausa 2019 Tacoma TRD Off-Road, 6 speed manual transmission - @nitrogears 5.29 - @pioneercaraudio DMH-WT8600NEX - @hertz_audio_official Hertz Door Speakers - @jlaudioinc 10” Stealthbox - @prinsudesign Roof Rack - @midnight_tint_kent 30% all around - @weathertech Rain Guards - @diamondbackcovers HD Tonneau Cover - @frontrunneroutfitters Rack System - @ikamper SkyCamp Mini - @volk_racing TE37 XT 17” - @yokohamatire Geolandar X-AT 35x12.50R17 - @dobinsonsusa 3” Lift Kit - @specialty_products_company UCA’s - @ss_offroad Slimline Stage 2 - @runnin4tacos TRD Pro Grill with Raptor Lights - @mesocustoms Smoke side markers & Total Tails Stage 1 - @mesocustoms Molle panel with grab handle retention - @amazon LED interior lights - @bajadesignsofficial Squandron SAE fogs & 40” S8 - @rigidindustries 20” SR-Series - @triggercontroller 6-shooter - @alpinedesignstudio Cab mount relocation - @mountain_hatch Tailgate insert
    I have an iPad mini dash kit for 2012-2015 Toyota Tacomas. This is using the iPad Mini side-slider kit from Soundman. The iPad is able to slide into a Lightning Cable (not included) to charge and read data, and slide out to be removed. There is a suede backing on the kit to prevent scratches to your iPad.
    You can either run this off your stock stereo via Bluetooth or USB if you relocate the stock head unit. Or you can use it with an aftermarket system as long as it has a USB port or Bluetooth.
    The dash kit is already fabricated and all you need is an iPad and to swap out your old dash kit. No need to send me yours. Literally plug and play!
    Asking $600 (free USPS priority shipping!) as I have put 8+ hours into getting this thing perfect with multiple layers of body filler and sanding. I can leave the kit painted metallic black w/clear coat, or can strip the paint and prime it so you can paint it yourself.
  2. Feb 13, 2016 at 4:57 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Can you still display when a person is calling, the current song playing etc.? Will this be Bluetooth compatible? Is is equally as functional or more functional than th stock dash display? Some questions, cool idea tho! Looks mighty sharp
  3. Feb 13, 2016 at 5:14 PM
    rafanomenon
    Seattle, WA
    The stock deck would allow you to do this no problem. It would just treat the iPad as a USB connected device, and return to music when the phone call is done. The aftermarket deck I'm using works the same. I tether it off my phone's LTE data plan and use it to stream from Spotify, Pandora, YouTube (I do not condone this while driving lol). I also use the Waze app and the iOS Maps app for navigation.
    If you can't tether from your phone's data plan, you will need to store music locally on your iPad, or use an iPad that has a data plan.
    Let me know if you have any other questions!
  4. Feb 13, 2016 at 5:16 PM
    rafanomenon
    Seattle, WA
    Sorry, I misread your question. The iPad does not show who is calling, you have to look at your phone to see that (I have a magnetic vent mount for my phone so it's not an issue for me.) It shows current song via Spotify/Pandora, and can connect to your deck via Bluetooth or USB.
    Waaaaaay more functional than the stock deck.
  5. Mar 21, 2016 at 1:58 PM
    rafanomenon
    Seattle, WA
    Bump! This is still available if anyone is interested.
  6. Mar 21, 2016 at 9:16 PM
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    Does this come with the aftermarket radio as well?
  7. Mar 21, 2016 at 9:26 PM
    rafanomenon
    Seattle, WA
    It doesn't, sorry. You can either find a deck with Bluetooth and skip the slide in charging, or find a deck with USB and epoxy set the charging cable.
  8. Jun 24, 2017 at 8:24 PM
    whatevbiznatch
    whatevbiznatch New Member
    do you still have this kit available ?
  9. Jun 24, 2017 at 8:35 PM
    hbarraza1983
    hbarraza1983 Active Member
    Humberto
    Stuttgart, Germany
    2009 tacoma
    how did you like the Sony remote app? I have personally didn't care for it. I've been using CarPlayIOS and Car Mode as my main dashnbord.
