iPad mini in a 2nd gen?
Discussion in 'Audio & Video' started by TuFerLife, Nov 7, 2012.
  1. Jan 16, 2013 at 1:17 PM
    #281
    RubberDucky
    RubberDucky Well-Known Member
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    I am so excited to find this post! I am wanting to do an install of an iPad Mini or a Nexus 7 in my Tacoma. Ive been doing a bit of research on the subject but obviously there isn't much out there on it.
    Check out THIS POST and those MP3CAR.COM forums have a lot of stuff about fabrication and such for tablet/Carputer installs.
    Now here is what I was planning, feel free to shatter my dreams with reality though.
    I am planning on connecting my tablet to a Clarion EQS746 1/2 DIN Graphic Equalizer with Built-in Crossover which will be connected directly to my 5-channel amp. Im trying to remove the headunit from the picture because I just can't afford one at the moment. The equalizer has a line driver for the input and it splits it to the 3 pairs of RCA outs for the 5-channel amp.
    As for the connection of the tablet to the Equalizer I may use my Bluetooth Blackberry Music Gateway or just wire it through the 3.5mm jack.
  2. Jan 16, 2013 at 1:24 PM
    #282
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    have a smartphone with a data plan? it can be shared/tethered pretty easily if you do.
  3. Jan 16, 2013 at 2:10 PM
    #283
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    3.5 will sound horrible and bluetooth will be even worse......get a lightning pin to 30 pin converter then get the cable that has the 30 pin on one end and both USB and RCA on the other....run the USB to power for charging the unit and the RCA into the eq.....simple
  4. Jan 16, 2013 at 2:27 PM
    #284
    RubberDucky
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    What about on an Android tablet?
    Also: I just discovered this post over on head-fi.org a site that is pretty much the TacomaWorld of audiophiles and if you want truly awesome sound out of your tablet I guess a DAC is the way to go? http://www.head-fi.org/t/507559/list-of-dacs-that-work-with-ipad
  5. Jan 16, 2013 at 3:18 PM
    #285
    NoSoup4You
    David
    Palos Verdes
    depends on the tablet. I think you must have JellyBean at minimum to get the USB Audio function enabled as well.
  6. Jan 16, 2013 at 3:38 PM
    #286
    RubberDucky
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    I was thinking I'd like a Nexus 7. I would just prefer Android because my phone is Android and from what I read online it functions better with bluetooth OBDII readers using the Torque application.
  7. Jan 16, 2013 at 3:48 PM
    #287
    NoSoup4You
    David
    Palos Verdes
    Yeah, I've have heard the same about OBDII .. I believe the main issue is the refresh interval of BT vs WiFi. The dongles I have seen are specifically BT for Android or WiFi for iOS, so you have to switch platforms to avoid the issue.
    But it could also be those crappy china knock offs .. the PLX Kiwi (again, BT for Android and Wifi for iOS) does not seem to have that issue, but I have never been hand-on with any of these.
  8. Jan 16, 2013 at 4:04 PM
    #288
    RTR84
    RTR84 Active Member
    Joe
    Tuscaloosa, AL
    05 5-lug
    I ordered a Sony MEX-GS600BT head unit, the ********* kit with Image Dynamics CTX65CS speakers, a Polk Audio 300W 2-Channel amp, and a roll of cheap adhesive backed aluminum roofing repair material to experiment with as a sound dampener in my doors (planning on doing a little dampening and sealing while I replace the speakers and run the wires from the amp).
    I bought the head unit from crutchfield and it comes with a free dash kit so I think I might try my hand at fabbing up something for the iPad mini with that kit while we wait on bkmcinty's kit. I've never worked with fiberglass so I'm thinking about trying to get by with milling out some plexiglass parts and gluing them together. If all goes well, I'll end up with something functionally the same as soundwaves' second ipad mini install with the lightning connector and magnets but I also want to add a safety latch on the far end of the ipad to keep it from possibly popping out.
    I am wondering exactly how they've got the lightning connector attached though, so that the ipad can be tilted in and out. I'm thinking something at the base of the connector to keep it from pushing into the dash, leaving a little room for tilting where the connector protrudes, and then silicone surrounding the connector at the protrusion might do the trick. Guess we'll see...
  9. Jan 16, 2013 at 4:17 PM
    #289
    RubberDucky
    Dillon
    North Pole, AK
    2010 Sport SR5 LB
    Stereo install.
    Same here as far as the hands on goes. MP3Car forums have a lot on the subject and it definitely is an issue of the updates per second on the Chinese knock offs. This isn't necessarily a horrible thing if you are only asking it to display a couple of stats at a time, but with a fully loaded screen all the stats will suffer. They talk about the superior performance of a $140 bluetooth OBDII reader in This Post.
    Not worth it in my opinion. I'm not big on that stuff though, Ill be OK with the cheapo-depot ones.
  10. Jan 17, 2013 at 10:07 AM
    #290
    RDNK TAZ
    RDNK TAZ Well-Known Member
    Chad
    Marion, SC
    '11 Silver Streak Mica DCSB TRD 2x4
    Don't have one mainly due to the cost of the data plan. I'm an old Alltel member that was sold off to Verizon. I've heard enough of lies from Verizon and I've set them straight to the point that they don't want to mess with me any more. I have just learned about Straight Talk. A few of my friends have it and they love it. Unlimited everything for only $45 a month. In my research, I've learned that they will cut you off if and when you go over 2 gigs of data and not let you reup for the next month. Still trying to find out if this is true. Sorry but if something sounds to good to be true, I try to find out everything I can before jumping in. That's why I'm trying to find out every app I can get to use without the internet. The thought of a radio mounted behind or somewhere else to have fm radio just really kills the whole tablet idea for me. I'm to the point of just ordering a Pioneer AVIC-X940BT and when I get a smart phone just get a plug and enjoy what I can.
  11. Jan 17, 2013 at 1:02 PM
    #291
    polox40
    polox40 Well-Known Member
    ONTARIO
    TRD SPORT 4X4
    TOYOTA ALUMINUM STEP BAR, 3M HOOD FILM, WEATHERTECH FLOOR MATS, 7" DD WITH BACKUP CAMERA, TRD SEAT COVERS
    I use tunein app
  12. Jan 17, 2013 at 1:06 PM
    #292
    Domreis
    Domreis Well-Known Member
    Pullman
    That was me. It is called App Remote. It only works with the Sony GS decks. There is a video about it in my previous post.
  13. Jan 18, 2013 at 3:36 PM
    #293
    RDNK TAZ
    Chad
    Marion, SC
    Do these require the internet and or a radio?
  14. Jan 18, 2013 at 3:42 PM
    #294
    Domreis
    Pullman
    The App Remote requires a Sony Deck, but something is needed to handle audio out to the speakers.
    The TuneIn app requires an internet connection.
  15. Jan 18, 2013 at 4:17 PM
    #295
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Almost done with my new design guys! A lot more user friendly and totally plug and play! No drilling, cutting or modifying any parts on the truck....super excited will make a video and start taking orders by next week :D
  16. Jan 18, 2013 at 4:17 PM
    #296
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Oh yeah.....will be able to get the price down for you guys ;)
  17. Jan 18, 2013 at 4:38 PM
    #297
    NoSoup4You
    David
    Palos Verdes
    :yay: I was just showing my brother this idea today and he is stoked on it. Wants to do an Android version in his A4 :D
    Can't wait for pics and prices :)
  18. Jan 18, 2013 at 4:41 PM
    #298
    Domreis
    Pullman
    Hope your design works in a '13!!!
  19. Jan 18, 2013 at 5:00 PM
    #299
    NoSoup4You
    David
    Palos Verdes
    I think it's based on a standard dash kit, so you may be SOL until he makes one for '13
  20. Jan 18, 2013 at 5:18 PM
    #300
    TuFerLife
    TuFerLife [OP] 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Aaaaannnndddd boom goes the dynamite!!!
