iPad mini install! Teaser pics inside!!
Discussion in 'Audio & Video' started by GuY0NaUniCORN, Nov 13, 2013.
  1. Jan 8, 2014 at 11:35 AM
    #201
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    That is exactly what I am driving at, seat, glovebox, etc. etc., or get an interface with better sound quality and suited more for this type of install. There are a couple on the market already.
  2. Jan 8, 2014 at 11:47 AM
    #202
    GuY0NaUniCORN
    GuY0NaUniCORN [OP] Well-Known Member
    STG
    '06 BSP TRD Off-Road
    Yes it's connected via USB, and it's a lightning connector not a 30 pin :) I considered mounting under my seat but didn't want to run the wiring down there, it will fit perfect under the seat though I did some test fitting with that idea
  3. Jan 8, 2014 at 11:54 AM
    #203
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Shoot hold on, do you know if this will fit a 2012 dash? Dammit I just saw your truck is an 06. If it doesn't fit then I am out.
  4. Jan 8, 2014 at 12:00 PM
    #204
    GuY0NaUniCORN
    STG
    This will fit '05-'11 as I think the dash was changed in the '12 model
  5. Jan 8, 2014 at 12:06 PM
    #205
    2ski4life7
    Seattle WA
    Well damn looks like I am out then.
    THE LIST:
    1.
    2.
    3.
    4.
    5.
  6. Jan 8, 2014 at 12:12 PM
    #206
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I'm in.....
    THE LIST:
    1. sfcadams
    2.
    3.
    4.
    5.
  7. Jan 8, 2014 at 1:53 PM
    #207
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  8. Jan 10, 2014 at 10:13 AM
    #208
    Brock19
    Brock19 Well-Known Member
    brock
    southern utah
    Trail gear bolt-on sliders. BLHM, AUX relayed fuse block, Plastiderp, Diff breather mod, Paracord handles, Trex eyelids, Spacer lift (for now), Magnaflow offroad series cat-back exhaust. sound system, limo tint on all windows excluding windshield. all pro rear bumper with side plates
    STG as in saint george utah?
  9. Jan 10, 2014 at 7:47 PM
    #209
    zXrunner
    zXrunner New Member
    Maui
    2006 SWB X-Runner
    None
    THE LIST:
    1. sfcadams
    2. zXrunner
    3.
    4.
    5.
    Hopefully you are able to ship to Hawaii. haha
  10. Jan 11, 2014 at 12:03 AM
    #210
    GuY0NaUniCORN
    STG
    Yes sir!
  11. Jan 11, 2014 at 6:09 AM
    #211
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Gawd I want one so bad... I just can't put another $1,000 into my sound system right now... Hopefully soon though
  12. Jan 11, 2014 at 10:16 AM
    #212
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Make me one for free.
  13. Jan 11, 2014 at 11:46 AM
    #213
    DMart
    DMart Active Member
    Dennis
    Phoenix, AZ
    2011 PreRunner SR5
    Awesome Job OP! Looks Great!!!
  14. Jan 13, 2014 at 6:44 PM
    #214
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yuck. You better clean up that attitude! Lol just kidding man :D
  15. Feb 8, 2014 at 8:22 PM
    #215
    Bazzy
    Bazzy Active Member
    I guess i'm late to the party but I've had mine installed for the last 5 months and there are issues with temperature. When it's below freezing, the system I used refuses to start for a 5-10 seconds. If the iPad has the sun directly shining on it, it will suspend itself until it's safe to power on. During a Texas summer, after several hours of sitting in the cab, it took up to 5 minutes for the iPad to cool down enough.
  16. Feb 24, 2014 at 11:49 AM
    #216
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Did you got around making more of these?
  17. Feb 26, 2014 at 1:42 AM
    #217
    bebopblues
    bebopblues Well-Known Member
    Los Angeles, CA
    09 PreRunner SR5 DC/SB
    Does the iPad mini wifi have GPS radio or you have to get the 4G version to get GPS?
  18. Feb 26, 2014 at 1:49 AM
    #218
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Follow this LINK Its how I got my in-dash WiFi mini to be GPS enabled no matter where in the world I go.
  19. Feb 26, 2014 at 1:56 AM
    #219
    bebopblues
    Los Angeles, CA
    Thanks.
    I imagine that unit requires a power source, so is it always ON or it has to be turned ON and manually paired with the iPad via bluetooth? If it's a hassle to always have to be turned ON and paired, I might just get the iPad mini 4G to save the trouble.
  20. Feb 26, 2014 at 2:14 AM
    #220
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    It runs for 8 hours on its own battery. Once paired with the ipad it will always pair up. If it is not plugged in it does need to be turned on.
    The bonus to this unit is that it is much more accurate than the gps on the 4g ipad. Once you lose cell service the 4g Ipads GPS is not as accurate. It alost does not require you to have a data plan with your cell provider to run. The way around this is to jailbreak either you android or iOS so you can hotspot your phone. A lot of work when you can get the unit I have or another company that makes a GPS for the iPad is Bad Elf. Just throwin out all the options to you. Lots to think about.
    I spend a lot of time out in areas with Zero cell service and this is by far the best option. Theres guys I run with that have Lowrance systems that like my offroad navigation better than what they have.
    Here is a shot of my track from 2 days ago using ViewRanger on my ipad mini. This is a totally standalone offroad GPS mapping program. The map programs that come on your phone or the ipads require a Data connection in order to download maps as yyou drive around.
