IPF Offroad wiring questions
Discussion in 'Lighting' started by eltaco, Jun 6, 2010.
  1. Jun 6, 2010 at 5:16 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    Well, my whirlwind of projects is nearing an end. I'm just now wiring in my IPF 968 offroad light and had a couple of questions... hopefully someone can answer these.
    1. There's a yellow wire that attaches into the switch harness on one end. On the other end, it says to tap into the high beam wire. Unfortunately, I don't have a tester handy... can anyone tell me (on the bulb end) which color wire is the high beam?
    2. There's a black wire with a spade connector on the end. The instructions say "Refer to instructions before securing this wire." No joke, the instructions tell me to refer to the instructions. I don't see this referenced anywhere else. Can someone point me in the right direction here? This wire goes directly to the relay.
    Thanks
  2. Aug 24, 2013 at 6:21 PM
    Bushytaco
    Bushytaco New Member
    Vancouver
    Tacoma 4x4 SR5
    K&N cold air intake kit, trail-gear winch bumper w/light bar, IPF 100w spotlights Uniden CB radio w/Larsen Whip Bedliner rims job BFG KM2's Flowmaster HP2 straight through exhaust
    if you pull back the wires from the headlight and use the Yellow and red coloured one- i tapped into that one for the same lights.
    You tried the 100w bulbs included? i installed them and shortly after the lights aren't coming on any more... not sure if there is too much draw or something, i guess I'll switch them out for the 55's and see if they work again :(
  3. Jan 2, 2014 at 12:25 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Bristol Connecticut
    '10 TRD sport 4x4
    Custom built exhaust with Black Widow venom 250 muffler,Afe Stage 2 Dry CAI, AVS window deflectors and bug guard, Undercover Flex Tonneau cover. Weather Tech floormats front and back, Philips 9003 XPS2 X-treme Power Headlight Bulbs, Toyo Open Country AT 2 265/70/17
    Did you end up getting these installed? Im looking at getting some IPF 968s for my truck. Possibly up to 4. How do you like them so far?
