iPhone 11 bluetooth drops during calls
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Battacoma, Sep 30, 2019.
  1. Nov 14, 2019 at 10:24 AM
    #221
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I would offer that there is a choice, iPhones are not the only devices used for portable communications. You seem to make the case for trying something different if you've been screwed pretty good over the years.
    Not knocking you, just an opinion from the outside looking in.
  2. Nov 14, 2019 at 10:44 AM
    #222
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I used my phone for work purposes. Received calls, scheduled and view appointments, and browse the internet with it. My phone allowed me to do all of that and fit in my pocket. It was the best option. One iOS update stopped the iPhone calendar from syncing with the google calendar, which was what I used to make appointments. I could still do it from google on the browser or the google calendar app but it wasn’t as easy and I also didn’t get the alert reminders the way I did using the calendar. Also another one that stopped my emails and had a bunch of other things wrong. Then the patch for that ended up causing other issues. Phone was all jacked up for a couple of weeks.
    Just about any operating system has some type of bugs. Google has their share. Apple has been getting bad. Look at all the windows blenders over the years. All it takes it one little error in a code and it can screw a lot of things up. I remember programming with C++, Java, HTML, ~ 15 years ago in school. Programming is a lot more advanced now and it was a big pain in the ass back then. And I could only do real basic stuff. Couldn’t imaging trying to write program script for an entire OS. I can understand what they have to go through.
    johnnyroid[QUOTED] likes this.
  3. Nov 14, 2019 at 11:41 AM
    #223
    elmontemike
    elmontemike Well-Known Member
    I have tried this but doesn’t work for me
  4. Nov 14, 2019 at 5:26 PM
    #224
    Silver_Jim
    Silver_Jim Well-Known Member
    Maryland
    2019 Toyota Tacoma DCOR
    Mine worked fine until I upgrade to IOS 13.1.*, I forget which. It resets constantly when the BT is connected. When it is not connected, the head unit works fine. I think it is the BT upgrade from Apple that is causing an incompatibility. I havent patched the head unit either.
    (Sorry meant 13.1 and greater)
  5. Nov 14, 2019 at 7:19 PM
    #225
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    That's the first I've heard of iOS 11 (or anything lower than 13) causing such problems. Apple acknowledge some BT issues with 13 and ran through a number of dot releases with most mentioning BT issues being fixed. So yeah, I think it's a OS issue.
    Mine seems to be okay now with 13.2.2 but just wondering if this is more prevalent with the JBL head units or is it across the board with both the standard and premium head units.
  6. Nov 15, 2019 at 8:13 AM
    #226
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    I upgraded to 13.2.2 yesterday and had a couple of good calls without a drop. We'll see...
  7. Nov 15, 2019 at 6:34 PM
    #227
    GreatnessCement1
    GreatnessCement1 New Member
    Stefani
    2019 sport cement
    My 2019 Navigation/jBL will reboot every minute. If the Bluetooth is off- it will not reboot. If the Bluetooth is on it will. They told me about 90 days to get a new update. What should I do about not having the Bluetooth/navigation work for that long? That seems a little long for that many days to be without something that I upgraded for.
  8. Nov 15, 2019 at 6:44 PM
    #228
    xxmagpulxx
    xxmagpulxx Well-Known Member
    Reno, NV
    TRD Off-Road DCSB Blazing Blue
    So I had an iPhone 8 Plus and had absolutely no connection issues with Entune. I upgraded to the iPhone 11 Pro Max and now it wont stay connected longer than 15 or 20 seconds. The call is still connected on the phone, but the blue tooth drops. Super annoying.
  9. Nov 15, 2019 at 6:55 PM
    #229
    GreatnessCement1
    Stefani
    2019 sport cement
    not sure if it’s a connection issue with the iPhone 11 or just the IOS but I’m running 13.1.3 and that doesn’t work only every minute..... the Bluetooth won’t stay connected since the whole system reboots.
  10. Nov 16, 2019 at 3:18 AM
    #230
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    I had the dealer update my head unit, then had to remove iphone info off it too.
    Then updated to 13.2.2 on my iphone7,
    Re paired and seems ok so far.
  11. Nov 16, 2019 at 4:06 AM
    #231
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Well there’s some top notch deductive reasoning right there.... lol
  12. Nov 16, 2019 at 6:13 AM
    #232
    viking15
    viking15 Well-Known Member
    Joe
    no one ask you about your Android
  13. Nov 16, 2019 at 3:01 PM
    #233
    Silver_Jim
    Maryland
    I updated iPhone to 13.2.2 and I still have the constant reboot. I also checked here to see if there were any updates and guess what, there are not any. So I guess Ill take it to the dealer and see if they any ideas. Seems like a software incompatibility to me....
    Reported issue to Toyota via website
    What was interesting is that Toyota definitely knows about this issue because they had a whole custom form to collect data and artifacts. If I hear anything back, Ill post it.
    Response Sent!
    Your email has been submitted under reference number: #191116-000305
    Thank you for contacting Toyota Motor Sales, U.S.A., Inc. We received your email, and we will have a tailored response to you as quickly as possible.
    If you have additional information you'd like to add to this request before you hear back from us, simply reply to the email from "Ask Toyota" that is now in your inbox.
    Thank you.
    Toyota Customer Experience
  14. Nov 17, 2019 at 4:18 AM
    #234
    johnnyroid
    I was using it as a point of reference to illustrate it might be an iPhone problem alone. No one asked you to be a dick, but there you are.
  15. Nov 17, 2019 at 7:23 AM
    #235
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    I don't thing he was trying to be a "dick". We are discussing Apple phone problems and us Apple folks get a little annoyed when brand X users try to make it about the gear we've bought with a "I have and Android and everything is rosy." Like we're stupid for buying Apple products. I don't think that was your intent, but I'm just pointing out how comments like that can come across. Apple issue or Toyota issue, there is an issue which the two should work together to fix. We pay a pretty good premium for tech in these trucks and I for one want it to work as advertised.
    Philrab and johnnyroid[QUOTED] like this.
  16. Nov 17, 2019 at 8:01 AM
    #236
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    did you remove all phone data, from the head unit? After update on phone? Then re pair?
    Silver_Jim[QUOTED] likes this.
  17. Nov 17, 2019 at 10:31 AM
    #237
    Silver_Jim
    Maryland
    Actually I didn't. I just disassociated the phone. I will try that and see what happens. Thanks!
    Philrab likes this.
  18. Nov 18, 2019 at 10:23 AM
    #238
    Cindys 4x4
    Cindys 4x4 New Member
    Cindy
    2017 white Tacome TRD 4dr
    is it still working? I am going to ask for the same--the head unit? is it a newly updated unit? I really hate not having my phone or GPS
  19. Nov 18, 2019 at 10:32 AM
    #239
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    I had dealer update software. Your 17 may be still under the 3 yr waranty so it shouldn’t cost you 75$.. my IOS is now 13.2.2 and had to re pair after removing it from the head unit. Still good after that. There is a link for updates from Toyota someplace, I deleted. Might be able to find it again if u need it
  20. Nov 18, 2019 at 3:50 PM
    #240
    Silver_Jim
    Maryland
    Yea mine seems to be working after disassociating it. It didnt right away though. So for now seems like it is working.
