iPhone 11 bluetooth drops during calls
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Battacoma, Sep 30, 2019.
  1. Nov 18, 2019 at 5:03 PM
    #241
    elmontemike
    elmontemike Well-Known Member
    I installed the latest update to my iphone 11. Erased the info from the truck and repaired the two. Seems to be working now. Was on the phone call for 19 minutes and no problems.
    :fingerscrossed:
    ReefSR54X4 likes this.
  2. Nov 19, 2019 at 3:53 AM
    #242
    GreatnessCement1
    GreatnessCement1 New Member
    Stefani
    2019 sport cement
    Mine still doesn’t work. They erased all data, they also opened a case up through toyota. Updated my phone to 13.2.3 and it still does not work. They keep giving it back knowing it does not work. Really frustrating! In CA it is the law to have a handsfree device, do not see how this cannot be something they understand.
    Interested and wonder if this issue only arrises with JBL with navigation or it goes for all radios with Bluetooth?
  3. Nov 19, 2019 at 6:23 AM
    #243
    Rebelman21
    Rebelman21 Well-Known Member
    Cleveland
    2021 SR5 DCSB Super White
    None yet, several planned
    After latest IOS update, and clearing the data from head unit, mine too seems to be back to normal.
    elmontemike likes this.
  4. Nov 19, 2019 at 7:22 AM
    #244
    Dale98c5
    Dale98c5 New Member
    Dale
    2016 White Tacoma
    Talked to Toyota, they are working with Apple for a fix. Issue with iOS 13. Turn off Bluetooth or unsync contacts worked for me.
  5. Nov 20, 2019 at 11:34 AM
    #245
    GD_TRD
    GD_TRD Active Member
    Gabriel
    Mesa, AZ
    2017 DCSB TRD SPORT 4X4 Stock.... for now. 2001 DC TRD 4X4 BILSTEIN 5100s 17X8.5 WITH BFG MTS 255/75/17
    13.2.3 still doesn’t work. Erased personal data aswell.... Bluetooth works if only connected as a music player not a phone.
  6. Nov 20, 2019 at 2:47 PM
    #246
    sbmon
    sbmon Well-Known Member
    I previously (as posted) had all kinds of issues with dropped calls every single call since apple 13.xx upgrades. Now with 13.2.2 and linked to head unit as a phone but sync contacts and show notifications must be turned off (disabled, which is done on the phones bt tab by clicking the i with a circle around it next to Tacoma). After turning those options off I have not had a single dropped call at all, and it’s been over a week)
    While this is a less than ideal solution it is better than dropping calls every single call.
  7. Nov 20, 2019 at 6:16 PM
    #247
    GreatnessCement1
    Stefani
    2019 sport cement
    does this go for the unit shutting off every minute as well??
  8. Nov 22, 2019 at 8:33 AM
    #248
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I have a brand new iPhone 11. Not the pro or the max. I am having calls fail to go through. I went to the phone store and they did a network reset and I am still having call fail. They told me to go to the apple store:annoyed: everything else works fine. Anyone else having calls fail?
    916Crza likes this.
  9. Nov 22, 2019 at 2:07 PM
    #249
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    read this thread
    TomTwo[QUOTED] likes this.
  10. Nov 22, 2019 at 2:12 PM
    #250
    TomTwo
    Bill
    I-85 Southbound
    I have been :annoyed:
  11. Nov 22, 2019 at 2:15 PM
    #251
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    :annoyed::annoyed::annoyed:I had an update done at the dealer. :annoyed::annoyed::annoyed:. Now it works but if i change songs on pandora it shows on the head unit, the 1st one it was playing . I still think its an Apple problem
  12. Nov 22, 2019 at 2:41 PM
    #252
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    Doesn't sound related to the truck issue. Do they fail with and without being in the truck? Could be a bad antenna or some other QA related issue.
  13. Nov 22, 2019 at 2:44 PM
    #253
    TomTwo
    Bill
    I-85 Southbound
    Yes calls fail in or out of the truck. I am not dropping calls. So far just two people I can not call
  14. Nov 22, 2019 at 2:50 PM
    #254
    john221us
    Bed Mat
    I assume these two are consistently failing (always fails for these two numbers). Sounds like a carrier routing issue. I would call your carrier (like Verizon, ATT, etc.). Are you blocking caller ID?
  15. Nov 22, 2019 at 3:04 PM
    #255
    TomTwo
    Bill
    I-85 Southbound
    Spoke with at&t yesterday (My Wife is a retired at&t engineer) they checked several things with Her on the line and said everything is good. I am going to the apple store after Thanksgiving.
  16. Nov 26, 2019 at 9:44 PM
    #256
    2017OR
    2017OR Well-Known Member
    2017 TRD Off-Road
    TRD exhaust, Pro Grill, Access Tonneau cover, TRD Pro wheels, BumperShellz, Pro shift know, Yota LED grille lights
    I have iPhone X and now on 13.1.3. Everything seems to be fine and no change from earlier software versions over past 2 years. I think I’ll hold off on new updates. I am planning on upgrading my phone to a pro however so this thread has me second guessing. There seems to be variability on this thread between users. Some work and some don’t. I wonder since mine has worked on version 13+ with my 2017 Taco if a new phone on 13+ will fail or succeed.
  17. Nov 27, 2019 at 7:10 AM
    #257
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I think it's mostly related to OS 13 and it's interaction with the head unit. Doesn't matter if it's a 11 Pro or a 8, if it's running OS13 there are reported problems. The latest version is 13.1.2. I've got it to work on my 2019 and 11 Pro by following the reset tips mentioned in previous posts. Delete the phone on Entune, forget BT connection on the phone, do a hard restart of the phone and reboot Entune. Then go through the pairing procedures. This has worked for me as well as others who have posted here, so it's worth a try.
    2017OR[QUOTED] likes this.
  18. Nov 29, 2019 at 12:20 PM
    #258
    TomTwo
    Bill
    I-85 Southbound
    Got my phone fixed today. I was trying to run an iPhone 11 on an iPhone 5 sim card. As soon as at&t updated my sim card to a iPhone 11 sim card everything started working properly.
  19. Dec 10, 2019 at 4:18 PM
    #259
    2017OR
    2017 TRD Off-Road
    Just got an 11 pro max. Cleared out the previous phone on my entune Bluetooth. This was a new phone so went through the pairing process. Took 2 calls today and had no issues. Both calls lasted about 15 min. Hopefully good to go. Will update this post if my experience changes. But, so far so good. Note that I previously had on iPhone X on 13.2.3 I think. No issues with that phone either.
  20. Dec 14, 2019 at 6:09 PM
    #260
    Black Magic 2003
    Black Magic 2003 Well-Known Member
    Edwin
    Mass
    19 Tacoma TRD Pro Double Cab
    Hey Guys,
    For the older iPhone (like my iPhone 8S Plus), I downloaded the latest iTunes (13.3.3), deleted my old phone and contacts off of the truck radio and reloaded the phone. I drove around today and so far, so good. No re-booting. I hope this helps with people who still have the older iPhones.
