iPhone audio can’t connect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by R_Dub5, Jun 10, 2019.
  1. Jun 10, 2019 at 1:51 PM
    R_Dub5
    R_Dub5 [OP] Well-Known Member
    Rob
    2019 Tacoma TRD Off Road
    hello everyone. New member here. I recently purchased a 2019 taco off road (5 days ago actually). I’ve run into a couple issues that maybe someone here might have some insight about. 1. I keep losing my audio connection with my iPhone 8. I’ve paired my phone and sometimes when I start the truck it says “can’t connect to audio player”. The phone works (I can make and receive calls). But I can’t play music. Turning the vehicle off then on again fixes the problem. Very strange. It’s happened probably 5 times in 5 days now. Has anyone else experienced this and is there a way to fix it? 2. Has anyone noticed that wireless charging is a little weak. It charges very very slowly and if I’m playing music it’s basically charging at the same rate as it’s draining. Also the phone needs to be placed in the front of the charging compartment. If I put on the brakes hard or for some reason the phone slides even a little bit forward it stops charging. Again, anyone experiencing this? Thanks! And other than these small annoyances I absolutely LOVE this truck!!
  2. Jun 10, 2019 at 1:56 PM
    ClubSoda
    ClubSoda Well-Known Member
    Harry
    2018 Cement Tacoma TRD Off-Road
    I'd try seeing if another phone has the same strange connection issue you are having. I do not have an iPhone, however, I cannot say I've seen any connection problems with my Samsung Note 9. Wireless charging also works well, perhaps the case you are using is thick and the connection is poor? When my bud puts his iPhone on my wireless charger, his silicon case causes the pad to go crazy, stops working for a few minutes.
  3. Jun 10, 2019 at 2:00 PM
    phatfisher
    phatfisher Member
    Yeah, same thing happens to me. Sometimes my iphone 6s seems to lose its connection to the car I think it's happened to me 3-4 times since last September when i got my truck. I typically just use the forget network option in the phone and reconnect manually again to fix the issue.
    Another issue i run into is like 90% of the time when i try to charge my phone(wire) in while the truck is on I'll lose connectivity with the bluetooth, yet it says the music is still playing on my phone.
    Can't say about the wireless charging since i don't have wireless charging on my phone.
  4. Jun 10, 2019 at 2:23 PM
    R_Dub5
    Rob
    Just took case off. Doesn’t fix the charging issue. Not sure if it will help the audio connection issue. I guess I’ll find out if and when it happens again.
  5. Jun 10, 2019 at 2:25 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Tried deleting your device out of the system memory and reconnecting?
  6. Jun 10, 2019 at 2:34 PM
    R_Dub5
    Rob
    Yes philrab. That works. But having to do that every day will get old real fast!
  7. Jun 10, 2019 at 2:39 PM
    Brewster52
    Brewster52 Well-Known Member
    Bree
    2014 DCSB
    I have a 2nd gen and this is a constant thing for me. It will randomly connect later as I’m driving or other times I’ll have to unpair and pair it again. The head unit also just randomly restarts. Toyota has done the “update” but still a daily struggle.
  8. Jun 10, 2019 at 5:30 PM
    TacoTheTaco
    TacoTheTaco Well-Known Member
    DC
    2018 TRD Sport 4x4 DBL Cab
    I get this every once in a while. I just hold the power on the radio to hard restart it then it works fine.
    apocataco2015 and R_Dub5[OP] like this.
  9. Jun 10, 2019 at 7:13 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    My experience with the wireless charger has been identical. I never use it now-days.
  10. Jun 10, 2019 at 7:31 PM
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Same random audio connection issue with my iPhone 8 Plus. My 7 Plus did it too. I finally gave up trying to find a solution and loaded all my music on a thumb drive.
    Would love to know the cause.
  11. Jun 10, 2019 at 7:44 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Sorry you have connection issues. I’ve not had any with iPhone. Maybe reboot the phone just to see if is phonsiide and delete any old Bluetooth connections you no longer need.
    For Qi charging, the protocol calls for slower than cable charge to keep temperatures down and because induction is less efficient. And placement on any pad is dependent on location, I’m sure you noticed this on your in-house Qi chargers too.
    R_Dub5[OP] likes this.
  12. Jun 10, 2019 at 7:45 PM
    n2ones
    n2ones Member
    Nestor
    2017 Barcelona Red Toyota Tacoma TRD Sport
    Demello Off Road - Front Bumper - Sliders -Custom Roof/Bed Rack Icon Wheels Milestar Patagonia AT Tires Eibach Pro lift kit and shocks PIAA LED Lights sPod controller Warn winch
    Do you run into this problem when you plug it into the USB charger? Mine tries to connect through the USB cable. if I don't plug it in when I turn the car on it connect through blue tooth no problem.
  13. Jun 10, 2019 at 7:48 PM
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    No problems with my old Samsung S8 or my newer S10. Charger isn't super fast but it isn't as bad as described.
  14. Jun 10, 2019 at 8:17 PM
    R_Dub5
    Rob
    This makes sense, I've never used a Qi charger before so I had nothing to compare to, thanks!
  15. Jun 10, 2019 at 8:20 PM
    R_Dub5
    Rob
    If i plug phone into the USB then it plays through USB fine. (But of course now I'm no longer connected via Bluetooth.)
  16. Jun 11, 2019 at 8:35 PM
    Philrab
    Phil
    I ask because I had this issue with my 2015 and my iPhone XR once, clearing the phone out of memory and reconnecting fixed it and it hasn’t been and issue since. Wouldn’t suggest this as a repetitive fix.
  17. Jun 11, 2019 at 8:44 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Delete any other phones that are on there. Un-sync your phone then re-sync. The Qi charger is worthless, charges slow, heats up the phone, very finicky on placement. Use the USB.
  18. Jun 11, 2019 at 9:54 PM
    DouglasEverdeen
    DouglasEverdeen Active Member
    Sask - Canada
    2019 TRD Sport 6MT DCSB Cement
    Have you tried a soft reset on your iPhone? In quick succession—
    - Press and release volume up
    - Press and release volume down
    - Press and hold the power button until the phone restarts, don’t let go until you see the Apple logo
    I’d probably remove the device from the truck, “forget” the BT connection on the phone and try the above steps. :fingerscrossed:
  19. Jun 12, 2019 at 5:38 AM
    R_Dub5
    Rob
    Thanks for the help! I also checked and it seems there are no updates available for the 2019 entune system (yet).
  20. Jun 13, 2019 at 8:45 AM
    erics
    erics Well-Known Member
    Eric
    PA Slate Belt
    2018 Tacoma TRD Offroad 6-speed
    I have the same problem. Happens 2-3 times a week. I've tried everything I can think of, including removing my phone from the radio and re-pairing it. Nothing helps except re-starting the truck.
    It also disconnects if I don't start playing music within a minute or 2 of starting the truck.
