iPhone/Entune Audio System Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Perseus2017, Jan 28, 2017.
  1. Jan 28, 2017 at 4:05 PM
    Perseus2017
    Perseus2017 [OP] Member
    2017 Black Tacoma SR5 Double Cab Longbed
    None
    I own a 2017 SR5 and am using an iPhone 6+ running iOS 10.2.1. Lately, when the phone connects via Bluetooth, the damn Entune Audio Plus system dials MY OWN cell number and calls MY iPhone. (Interestingly, the phone really isn't making a call, just the audio system, if that makes sense.). What's worse is the system won't let me hang up (pressing the soft key on the screen/hard key on the steering wheel). I even tried cycling the ignition (on/off) several times to no avail. In the end, I had to actually call someone on my iPhone to "kick the system in the pants" and get it to hang up! I just checked w/Toyota service and they said no updates/TSBs for the audio system.
    Has anyone else experienced this problem? Suggestions?
  2. Jan 31, 2017 at 6:04 PM
    Taco 2017SR5
    Taco 2017SR5 New Member
    2017 Gray Tacoma SR5
    I have a 2017 SR5 and am having the same issue. It doesn't do it all of the time but very frustrating when it happens. I did figure out if the headset mode button is lit up and can be selected on the screen it will take you out of it. When it's not lit up I have to take my phone out of the system and go through the pairing process again. Starting to frustrate me enough where I was seeing if there was something on the internet on how to fix it when I saw your post. Guess will take it in to see if they can do anything with it.
  3. Jan 31, 2017 at 6:32 PM
    matt636
    matt636 Well-Known Member
    Central, IL
    2017 TRD Sport 4x4 DCSB Inferno
    so I haven't installed Entune yet on my iPhone because all the reviews are so terrible. I just connect Bluetooth and do calls/txt's that way, or when I want to have quality sound from Pandora I just plug my phone in via USB and it sounds surprisingly well.
    what would Entune give me extra of that? The one thing I can think of is the weather app. I don't have HD Radio where I'm at so therefore haven't even seen the weather app work. I wish it would work when I plug my phone in, but that hasn't work yet. and that doesn't seem like a good enough reason to install Entune.
    please educate me if I 'm missing something!@
  4. Jan 31, 2017 at 6:32 PM
    Gabtap
    Gabtap Well-Known Member
    2017 Black Offroad
    Mine won't show incoming messages
  5. Jan 31, 2017 at 6:51 PM
    TMD78
    TMD78 Member
    Pittsburgh
    2017 MGM Tacoma TRD OR
    OEM audio+, trd pro grille, sema wheels/tires kbro2
    I believe you have to be stopped to actually see the message. Also, if you want it to read them to you, I have to go to apps/messages then on my iPhone turn Bluetooth off then back on. Now when a text comes in I have the option to have it read. Have to do it every time I start it. Automakers never fix any of this sh!t so don't hold your breath.
  6. Feb 1, 2017 at 8:03 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    This is interesting. My truck recently quit playing tunes over Bluetooth and I have no idea why. Disconnecting and repairing hasn't fixed it either. Maybe there's a larger issue at play here.
  7. Feb 1, 2017 at 8:07 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    There are alot of iphone issues with the system. Mine would play all music at 2x speed the first time I connected, always had to unpair/repair to fix it.
    E: my current Pixel has worked fine though, knock on wood.
  8. Feb 1, 2017 at 8:26 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Fixed that for you; while you may be having that problem, don't erroneously say everyone is having it.
    Works just fine here with my iphone7. I did have to turn off quick contacts on the head unit and delete/repair my phone. Once. Three months ago.
    Only real issue is that Pandora via Entune app sometimes isn't working when I start it up, requiring I force-quit and restart the Entune app on my phone.
    All the other stuff always works fine, no idea what the issue is with the Pandora piece.
  9. Feb 1, 2017 at 8:43 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    I don't think it's limited to the iPhone. The dialing happened once on my Tacoma and a few times on my Sienna and I'm using Android.
  10. Feb 1, 2017 at 8:48 AM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I'm an Android guy but when traveling the wife will hook up her phone to Entune either by BT or cable and she will run the entertainment. Seems to work. I did not put the Entune app on her phone. So I would also be interested in what the Entune app would do if more of if using it?
  11. Feb 1, 2017 at 9:14 AM
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    I had issues previously with mine only receiving one text and reading it to me, after that I would not get any notifications of texts. Also pandora would be hit or miss for it to work. I ended up deleting my entune sytem to factory and on my iphone forgetting (removing) "tacoma" from my bluetooth connections. After I did that I set everything back up and it's been working like a charm for weeks. The weather app is just pitiful by the way...ashame. I wish they'd put out an update for this thing already, it's been so damn long. I wish it came with apple car play, oh well.
  12. Feb 1, 2017 at 9:51 AM
    gpb
    Atlanta
    Have you used CarPlay much?
    I had it for a week in a rental (work travel). The concept is nice, and it works well enough for longer drives, but the wired connection ruins it for short trips / running errands where you're making a lot of stops. All the plugging in and unplugging every time I got in and out of the car got annoying really quickly.
    Contrast to Entune, which while having its own issues, works a lot better for just leaving your phone in your pocket or popping it onto a wireless charging magnetic mount. :D
    I think the first wireless CarPlay implementations are starting to now come out. Long overdue.
    Hank Heel likes this.
  13. Feb 1, 2017 at 10:03 AM
    Tommyb08
    Tom
    I can't say that I have but I've just been reading about it now and then. Wow I did not know you had to plug it in all the time. That is unfortunate and I def do no like that. That would be a deal breaker for me as I like the fact we can connect via bluetooth to entunes. In any case I'm glad entunes has been working pretty darn well since I wiped it on both the unit and my iphone.
    gpb[QUOTED] likes this.
  14. Feb 1, 2017 at 10:35 AM
    matt636
    Central, IL
    Quoting myself here, as I saw CarPlay brought up. I had CarPlay in my previous head unit and HATED IT! ok, so it had a familiar interface, but that was about it. I disabled it and rather used normal phone plug to USB like I say above.
  15. Feb 1, 2017 at 10:47 AM
    brownmound
    brownmound Well-Known Member
    had this happen yesterday...not the first time either...frustrating as hell, I need to figure out why it may be occuring.
    I was worried someone on the other end was listening to my say WTF?! repeatedly and get frustrated.
    To end it I finally turned off blue tooth on my iPhone, then just turned it back on.
  16. Feb 1, 2017 at 11:04 AM
    Tommyb08
    Tom
    You know what, I actually remember a similar situation. Prior to wiping my entunes and bluetooth connection when I would use the google app (not the bowser) on my 7+ it would make a phone call to my number and immediately stop. I do not know if it was a bug in the actual google app or an issue with entunes. I have not opened the app since I've done the wipe but I'll try it today to see if it still occurs. Is there a particular task you are doing on your phone when this happens? Like I said the google app caused it for me but it would stop after 1 ring. I'm going to test it when I leave work to see if it still happens. When it happened for me I was running iOS 10.2, now I am on 10.2.1. Also the google app has updated w/ bug fixes since. I'll report back with findings.
  17. Feb 1, 2017 at 4:25 PM
    Gabtap
    2017 Black Offroad
    No I fixed it, it was notifications themself, just went to my bluetooth options and turned off notifications, itll read it. You have to be stopped for you to see it word for word
  18. Feb 1, 2017 at 4:46 PM
    Perseus2017
    None
    Wow! I never thought my post would generate so much discussion!
    For me, everything with the phone and Entune seems to be working fine except for the dumb system dialing my own phone. I truly believe it's a problem with Entune and not the phone. The problem with the system "self-dialing" is intermittent, so when I bring it to the dealer, they can't find anything wrong because, at that moment, there is nothing wrong (or, at least, there appears to be nothing wrong)! The system seems to work well enough about 99% of the time. It's that 1%, when it stubbornly won't stop calling my phone, that it drives me nuts.
    In reading through the posts, some of you refer to an "Entune app". I'm not aware of/don't have that. Is that something I need to load on the phone? I just paired the phone with the system and that was it. Granted, I have the Entune Audio Plus System (not the Premium) which may not require an app on the phone.
    Thanks for your posts, and if I find out any useful information, I'll let you all know.
    Keep on truckin'!
  19. Feb 1, 2017 at 6:53 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    The audio plus does not have apps, only the premium ones you can download apps.
  20. Feb 1, 2017 at 7:37 PM
    MPOW33R
    MPOW33R Well-Known Member
    MoMo
    East Bay, California
    A Few Air Cooled Porsche, A Few Water Cooled Porsche, 2018 Mag Gray Limited 4x4 (TRD Pro Rep 6/2023) 17 Mag Gray DC SB TRD Sport Premium JBL NAV Tech | 10 Mag Gray DC SB TRD Off Road JLB Audio
    10' TRD Beadlocks, LTX MS/2s , Skid Plate, Roof Rack , Tonneau, Full Stereo System w.DVD 17' TRD Pro 17s, TRD PRO Grill, TRD Pro Rigid Fog Lights, TRD Pro Tails, TRD Pro Knob, TRD Pro Bugle and Hood Decal, 265/70/17 BFG KO2s (C), TRD Skid Plate, OEM Tri Fold Tonneau, OEM Roof Racks, TRD Exhaust Tip, All LED Lighting, Tacoma Matte Tailgate Lettering, OEM Rear Bed Step, Remote Start, Locking Tailgate
    Looking for a quick answer
    I have the Premium JBL with Nav, Sub etc - Do I/we have a single cd drive
    inside the head unit or a 6 CD Feed? I can play one cd just wondering
    how or if I can get 6 in there? My homework has said NO its only a single.
    I mean i have 134 different ways of playing music through it lol but
    im wondering is all.
    - i have no issues with my phone syncing or anything you guys are
    discussing at all with my iPhone SE
