iphone use in 2012 Tacoma
Discussion in 'Audio & Video' started by Mike R, Jan 7, 2012.
  1. Jan 7, 2012 at 6:37 AM
    Mike R
    Mike R [OP] Member
    2012 Tacoma 4x4
    Using Bluetooth I can get the phone function of my iphone 4G to work. However, when playing music from the iphone through the car audio i can't get it to change albums as described in the manual. I have Type B audio control panel. Any suggestions?
  2. Jan 9, 2012 at 9:52 AM
    mtnbiker310
    mtnbiker310 Well-Known Member
    Parker, CO
    '12 Offroad Tacoma
    TRD Cat Back Exhaust, Jumpers LED's interior, Hella 5000 behind grill, Custom grille
    I am having the same issue with mine, if you find out please let me know.
    Also, did you figure out how to sync your iphone phonebook via bluetooth?
  3. Jan 9, 2012 at 2:37 PM
    TexasDave
    TexasDave Member
    Dave
    Melissa, Tx.
    2012 Tacoma 4x4 off road
    Extang Trifecta
    Same problem here.
  4. Jan 9, 2012 at 3:20 PM
    Mike R
    Mike R [OP] Member
    2012 Tacoma 4x4
    I haven't tried the phonebook yet, if I have any luck I'll let you know.
  5. Jan 9, 2012 at 3:22 PM
    nova423
    nova423 Well-Known Member
    Virginia
    2012 DCLB TRD Sport
    Nerf bars, LED lights, truxport tonneau
    The bluetooth sounds really buzzy on the other end. I have had my 2012 for 3 weeks and nothing I have done has changed this, specifically taking the iphone 4 case off, different positions in the truck, etc.
  6. Jan 10, 2012 at 10:15 PM
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    check and make sure nothing is covering the mic which is located between the 2 lamps on the ceiling in the front... if it is free of obstruction you may just have to call the stealership... have read other posts about people having the same problem...
    as for the phonebook, if you try it let me know Mike
  7. Mar 3, 2012 at 9:30 AM
    TTUATO
    TTUATO Member
    JT
    Chattanooga
    2012 DCLB MGM Sport 4x4
    Radio: Hybrid Audio front/rears, IDV3 sub, Alpine MRX-V70 WeatherTech mats Window tint: 20% front, 5% rear N-fab steps: 3” tube (only for DCLB) Light bar: Avid Offroad. Powder-coated black to match steps
    I had same issue. To get album functionality over bluetooth your phone has to be upgraded to iOS 5.0. This will update your bluetooth radio and give you that function. Otherwise it will simply say "streaming audio" when you are operating it.
    I caution you about upgrading your phone for that reason. If you plug your phone in via the usb port, you are forced to change songs on the headunit. I have almost 4,000 songs and don't wanna push buttons to scroll. I would rather use the traditional ipod screen menu. I am uncertain if the streaming changes this functionality too. I don't wanna upgrade my phone and that happen because you can't downgrade ur phone OS. Maybe someone will respond that knows after this bump.
