iPod install & painted shifter console - PICS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmb, Aug 1, 2009.
  1. Aug 1, 2009 at 6:55 PM
    dmb
    dmb [OP] Well-Known Member
    Boise, ID
    I started my Spec USA iPod install today. In the end I want my iPod to sit in the rectangular cubby beside the shifter for easier control. I had to run the first cable from the back of the stereo, into the glove box, and down below the center console.
    Here is the cable coming from the stereo, it was fairly easy to snake into place under the console. I tie-wrapped it in place so it doesn't accidentally come loose.
    Here is where I mounted the adapter. I had originally mounted it closer to the front of the console but soon realized the bottom of the drink holders would hit it. It is mounted w/ 3M heavy duty double-sided tape. It ain't budging.
    With the shifter console off I drilled a small hole, coming from the driver side. Made it just big enough to fit the other adapter cable through. I have some rubber grommets for the hole for final install to make it nice.
    Then I went ahead and painted if black. I figured it would jazz things up a bit. Not to meantion cover up a couple scuffs and scratches ;). I masked everything except for the top silver portions & chrome, scuffed using some 600 grit sandpaper, and painted them w/ Rustoleum Satin Black spray paint, 4 coats.
    I'm letting the console dry overnight and finishing the install tomorrow. I'll post a finished pic after everything is in place. :D
  2. Aug 1, 2009 at 6:59 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    looks good so far!
  3. Aug 1, 2009 at 7:25 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Good job for doing something different. I can't wait to see it.
  4. Aug 1, 2009 at 7:28 PM
    phynyx38
    phynyx38 Believe
    San Antonio, TX
    08 Tacoma PreRunner
    Looks good, post up some pics of it in action.
  5. Aug 1, 2009 at 7:29 PM
    baildavc
    baildavc TREADING LIGHTLY!
    David
    Jasper, AL
    08 4x4 white DC OR
    3 inch lift, 33's, bull bar, debadged, windows tinted, direct wired power inverter, blacked out front emblem,
    Looks great.
  6. Aug 1, 2009 at 8:41 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Good job so far.
  7. Aug 1, 2009 at 9:04 PM
    matt45648
    matt45648 Well-Known Member
    Looks really good. I might hafta do this mod
  8. Aug 1, 2009 at 9:29 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Could you post the link of where you got your converter box from. I would love to do the same thing with mine but have lost the link of where to get them.
  9. Aug 2, 2009 at 6:00 AM
    dmb
    Boise, ID
  10. Aug 2, 2009 at 6:10 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I am interested to see how well it works. I had the pxamg isimple unit in my Accord and it had its issues. The one thing I failed to do before I installed it was update its firmware so that could have been part of my problem. Of course, I have a Touch and at the time they didn't have a cable to charge it. Now they do so that will be nice.
    How is the USA Spec hooked up to the head unit? Do you use the CD/AUX button or XM button?
  11. Aug 2, 2009 at 6:19 AM
    dmb
    Boise, ID
    With the iPod plugged in, it activates using the DISC button from the stock radio. You can control playback strictly from the radio if you like, and keep the iPod out of sight. One of the buttons on the radio activates direct connect, so you can control playback directly from the iPod, which is what I want to do.
  12. Aug 2, 2009 at 6:45 AM
    dexterdog
    Oly WA
    2012 F150
    It sounds exactly like what I want. Although I prefer to keep my Touch hidden, it is nice that you can change to using the ipod controls instead of the head unit buttons.
  13. Aug 2, 2009 at 7:08 AM
    Jason'sLawnCare
    so does this ipod connecting unit cancel out the use of the cd player or can one still use the cd player if this is hooked up?
  14. Aug 2, 2009 at 9:15 AM
    dmb
    Boise, ID
    I forgot to try this. I'm pretty sure you can still play cd's...you just have to unplug your ipod. I'll check in a bit when it stops raining.
  15. Aug 2, 2009 at 9:20 AM
    dexterdog
    Oly WA
    2012 F150
    It sounds like the hookup is through the CD/Aux input so I would hope worst case you would just lose the OEM Aux input. You should just have to push the CD/Aux button twice to get to the Aux.
  16. Aug 2, 2009 at 9:30 AM
    dmb
    Boise, ID
    Finished the install earlier today. It looks sweeeet!
    -Here is everything connected to make sure it still works.
    -Cables tie-wrapped and pretty.
    -Everything back together. Oh yeah.
    -You can see where I brought the cable into the cubby.
    -Driver side
    Close-up
    I might have to find some more stuff to paint lol!
  17. Aug 2, 2009 at 9:51 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    looks good, thats where I put my iphone but the cable goes thru the center console and I just dangle the wires out when I use it.
  18. Aug 2, 2009 at 9:55 AM
    dexterdog
    Oly WA
    2012 F150
    Looks good. Unfortunately my Touch is too wide to lay flat in the little cubby. Do you have a Nano?
  19. Aug 2, 2009 at 9:56 AM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    Nice clean job! I mounted mine behind the stereo....I like where yours is mounted better.
  20. Aug 2, 2009 at 10:15 AM
    dmb
    Boise, ID
    Thanks! It is a Nano, 1st gen I think. That cubby is the perfect size for it.
