IPod jacked in- no volume
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dimonback, Aug 25, 2010.
  1. Aug 25, 2010 at 6:12 PM
    Dimonback
    Dimonback [OP] Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Okay, I don't know much about the IPod, but this is making me think it's useless.
    On both my motorcycle (with a factory IPod adapter) and on my Taco (with a Best Buy direct-to-antenna input), there are some tunes that need the head unit volume maxed out just to hear clearly. I have the volume on the IPod maxed, but it just doesn't seem as though the signal is getting to the head unit well. That being said, even the tunes that do come through with decent volume sound a little off-- like the speakers are in a box. When I use headphones/IPod, they all come through fine.
    Am I doing something wrong in my burning, or missing a setting on the IPod, or what?
    Can't afford a new HU with a USB input... so don't go there.
  2. Aug 25, 2010 at 6:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    I think iPods have some equalizer settings...Not sure tho. And a some a setting with "equal volume playback"
  3. Aug 25, 2010 at 6:17 PM
    hawkeye12
    hawkeye12 Go Pack Go!
    Bryce
    Raleigh, NC
    10 Black DC SB Tacoma TRD Sport
    Smittybilt nerf bars
    It is most likely your actual AUX cable. I would invest in a new one of those.
  4. Aug 25, 2010 at 6:21 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    FM Transmitters never work as well as ones that plug directly in, so you are going to loose quite a bit of quality and volume there. Chances are, switching the equalizer as well as turning on "Sound Check" will both help. They can be found in the iPod settings.
  5. Aug 25, 2010 at 8:41 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
  6. Aug 25, 2010 at 9:21 PM
    Dimonback
    Patrick
    Yep... did all that previous to posting. Sound check, EQ peaking... no help. Aparently the loss is in the way I'm connecting through the antenna. Considering the stereo in the Taco is pretty lame to begin with I guess I'll just take earbuds.Thanks for the input, all.
  7. Aug 25, 2010 at 10:43 PM
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    Yeah, I have the same problems, Im really thinking about getting one of the amps.
  8. Aug 31, 2010 at 1:19 PM
    Thickshaft
    Thickshaft New Member
    southeastern PA
    '10 BSP DC/SB SR5 4x4 V6
    Katzkin leather interior black nerf bars
    Just got my 2010 Taco with 6 CD system, and had same volume problem with 3.5 mm male-male cable into the aux input. Had to turn Ipod volume to max and radio volume to 50s just to hear while driving.
    Then saw this fix on this forum (sorry, can't remember which thread exactly so apologies for not being able to credit OP):
    Go to Itunes --> music library --> select all songs --> right click --> select "get info" --> "options" tab --> turn "volume adjustment" to 100% --> sync.
    Now I can run Ipod volume @ ~75% and stock headunit volume in low 30s for music. No distortion, either.
  9. Aug 31, 2010 at 1:38 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Fm modulators absolutely suck. Get a direct plug-in adapter (one that plugs into your CD port on the stock head unit).
    Search this forum for types/brands to buy.
    Oh, and a great place to research everything and anything you could possibly want or need to know about ipods......is here:
    http://forums.ilounge.com/
  10. Aug 31, 2010 at 5:56 PM
    blackbox
    SE Ohio
    thickshaft, thanks for that tip, i'm still learning about itunes, that sounds a lot better than buying an amp. i haven't sync'ed it yet, will be interesting to see how this works.
  11. Sep 1, 2010 at 7:04 AM
    Dimonback
    Patrick
    Trying this as I type. Info is much appreciated.
  12. Sep 1, 2010 at 7:38 AM
    Dimonback
    Patrick
    Well, THAT didn't work- now it sounds like I have the earbuds pulled out. I'll try it again.
  13. Sep 1, 2010 at 7:44 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if your using the FM transmitter it wont get much better. those things are total crap. its like a tiny little radio station sending a signal to your antenna from your ipod. I had one for about a week before i set it on fire.
    best bet is to get a aftermarket cd player that has an IPOD input. even some of the el' cheapo headunits have ipod inputs on them now
  14. Sep 1, 2010 at 7:47 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    don't drive with earbuds in.
    it's illegal in a lot of states and you look like a tool
    i know you said you don't have a ton of extra cash, but you can pick up a nice used hu on ebay for 100 bucks.
  15. Sep 1, 2010 at 8:25 AM
    Dimonback
    Patrick
    Okay, I give up. Maybe it's the fact that I don't have the aux input... but it pisses me off that I paid Best Buy $150 for something that fails this bad...
  16. Sep 1, 2010 at 8:45 AM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
  17. Sep 1, 2010 at 9:00 AM
    81shark
    take that item back and buy yourself a hu.
  18. Sep 1, 2010 at 9:07 AM
    Joseph
    Joseph Active Member
    Kentucky
    2010 tacoma
    I have this problem too but it seems to have gotten worse over the course of 6 months.
    It's not the cable as I have tried other input sources (another ipod, laptop) so it must be the ipod itself.
    I'm trying the method mentioned above so I will chime in soon...
    dig the altoid amp though. that's kind of cool...
  19. Sep 1, 2010 at 9:10 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    do the 2nd gen's require an expensive wire harness adapter for new HU's? My old truck needed a $120 wire harness to keep everything running since everything ran through the factory radio.
  20. Sep 1, 2010 at 9:19 AM
    Joseph
    Kentucky
    2010 tacoma
    so the itunes trick didn't work...trying the other fix now...
