ipod sound
Discussion in 'Audio & Video' started by scrtsql, Sep 25, 2009.
  1. Sep 25, 2009 at 7:37 AM
    scrtsql
    scrtsql [OP] Well-Known Member
    chicago ill
    trd 4x4
    hey any one have or had issues with the ipod sounding very low in the truck is thier anything to fix that with out changing the radio
  2. Sep 25, 2009 at 7:45 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    I know you have to adjust the audio levels on the stock radio when its pluged in and set to aux. Once you set them they stay saved. Its different from the radio setting too, so.... Where at in chicago. Im on the far southside
  3. Sep 25, 2009 at 7:49 AM
    scrtsql
    chicago ill
    trd 4x4
    im close elmwood park norridge franklinpark .i was just reading some other forums some say you have to go back to your computer and edit your itunes volume cause my ipod now is hook up striaght to the radio
  4. Sep 25, 2009 at 7:53 AM
    mas32259
    mas32259 Well-Known Member
    NEPA
    2010 SR5 TRD Sport
    TRD short throw shifter, Eibach 1.6" lift coils 5100's on all corners, Ipod interface, Painted engine cover, radiator cover, skid plate, speaker grills overhead console, and added carbon fiber and chrome interior trim (Too much cheap plastic) TRD cat back, LED 3rd brake light. 100 lbs of sound deadner. Infinity ref. 6 1/2 all around. OBX pedals and shifter. DTRL mod, Alt. turn signal mod, LED's in glove box and console, LED's under dash lip and back A/C vent,Weather Tech mats. Took off antenea for wind noise
    Mine was a bit heavy on the bass. untill I replaced the stock speakers. It would be hard to find speakers as cheaply made as stock, a plastic frame, come on.. Make sure the Ipod settings are without bass boost.
  5. Sep 25, 2009 at 8:32 AM
    65tacodude
    Wade
    Manteno, IL
    '18 Tundra Platnium
    ah, yeah im just using the aux port. Yeah try doing that. Sometimes a pain in the ass to get them sounding right. Im worried if i upgrade speakers theyre not going to sound right without proper amperage
  6. Sep 25, 2009 at 8:45 AM
    mas32259
    NEPA
    2010 SR5 TRD Sport
    Get the interface first......... took less than 10 min. to install. $200 at tacoma parts store. The aux is worthless. I tried it and called the dealer and they gave it to me free. They bought back my 2000 TRD for $13,732.... for rust recall. New it was $24,000 which means after 10 years the 2000 cost $1,000 a year to drive. If you keep the stock head unit check out Infinity Reference 6020cs 6-1/2"/6-3/4" 2-way 2ohms. 93db@1 watt. free mounts and harness. at Crutchfield. Open box for $118.00
