IQ bubble.. Tacoma console.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacorun2014, Oct 8, 2023.
  1. Oct 8, 2023 at 1:37 PM
    Tacorun2014
    Tacorun2014 [OP] Member
    2014 Toyota Tacoma prerunner
    Saw some comments. My trk is a 2017 trd sport . Noticed after I
    Remove a few items I had in space that it’s bubbled. Saw a video how to relpace $40 part if change over the charger itself. 700 think said if want with new charger attached. After watching video I done $40 part it’s 8 more screws after do all the rest. Lol . But likely happen again. This dude used job weld to keep from bubbling. Not that charge will work after that. I finally have a phone I can use charging if I remove case. So still never use. But the bubble is annoying and cosmetic. Anyone tried maybe a slit lift and glue down? We’ll input the stuff I was storing …ok gum unused hand warmer in plastic still. Rubber gloves incase needed. I park in garage always and never sits more 8 hrs if drove to work. I don’t use charger. So it’s heat related it’s the engine compartment. I rarely use anything but defrost
    N heat for 20 minutes cause
    It takes a couple warm up and drive less 10 minutes to work. So again I call BS defect from build design, for cost of trk and my OCD I will hate it’s there but keep covering to not look at it.
  2. Oct 8, 2023 at 1:52 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
  3. Oct 8, 2023 at 3:47 PM
    findbrianhere
    findbrianhere Well-Known Member
    Brian
    Bloomington, IN
    2016 Tacoma TRD Off-Road
    2.5" Old Man EMU Lift Add a Leaf Old Man Upper Control Arms 18" Black Rhino Rims 33" Nitto Grapplers Wescott Designs Rock Sliders Uptop Overland Alpha Cab Warren Synthetic Winch in-bumper Borla Exhaust Nitro 5.29 gears Genesis dual battery Morimoto headlights/taillights Injen Cold Air Intake
    I think I have the same issue if I'm understanding you correctly. I've contemplated cutting and super gluing if it's needed. Awaiting a rainy day I guess, especially since I have chargers elsewhere.
  4. Oct 8, 2023 at 3:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Oct 8, 2023 at 4:11 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    And you mention you have OCD
    Steves104x4 likes this.
  6. Oct 8, 2023 at 6:47 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
  7. Oct 8, 2023 at 7:31 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Let me translate.
    Hello Tacomaworld. My truck which is equipped with wireless charging developed a bubble on the rubber charging pad.
    I do not use the charger and the truck has been parked in the garage and not exposed to heat.
    Does it truly cost $700 to replace the charger? I have seen videos online where others have done it for $40 or less.
    Perhaps I can just cut the bubble with the exacto knife, and glue it back down ?
    thanks for all the help.
  8. Oct 8, 2023 at 7:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    WTF...
    j-utah, bbartol, MQQSE and 2 others like this.
  9. Oct 8, 2023 at 7:45 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    nailed it. well done
    hiPSI, OBXPaul, axxkicker and 5 others like this.
  10. Oct 8, 2023 at 7:49 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Steves104x4, Delta09 and bbartol like this.
  11. Oct 8, 2023 at 8:25 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Thank you brother!!
    I work with people from all over the world, and at times it is harder to understand people from my own country the most lol :D
  12. Oct 9, 2023 at 4:12 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
  13. Oct 9, 2023 at 5:11 AM
    Dutch216
    Dutch216 Well-Known Member
    Dutch
    Cleveland Ohio
    2023 Tacoma TRD OffRoad Premium
    Why did I click on this? Im only half way into my first cup of coffee.. Ugh.
    Chew, j-utah and rolled93slc like this.
  14. Oct 9, 2023 at 6:35 AM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    Steves104x4 and MQQSE like this.
