Iridium Spark Plug Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mbrogz3000, Sep 2, 2016.
  1. Sep 2, 2016 at 8:49 AM
    mbrogz3000
    mbrogz3000 [OP] Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I upgraded to either Denso or NKG (can't remember) iridium tip spark plugs at 30k miles. I'm now at 60k+, and was wondering whether I still need to swap out the plugs since I've upgraded to iridium? If no one knows that answer, then:
    What is the spark plug maintenance cycle for folks who have the TRD Supercharger? I will just follow that cycle then.
  2. Sep 2, 2016 at 8:53 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Iridium plugs are normally good for 100k.
  3. Sep 2, 2016 at 9:11 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    They last longer than the standard plugs...definitely longer than 30k...I think they are usually good for 100k
  4. Sep 2, 2016 at 11:46 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't worry about it until 80 to 100K as long as I didn't notice any issues.
  5. Sep 2, 2016 at 12:50 PM
    mbrogz3000
    Northern NJ
    Thanks for the responses guys - I'll leave them be for now. Make next summer I'll swap them then.
  6. Sep 2, 2016 at 3:34 PM
    eon_blue
    Azusa, CA
    Are you supercharged? If not then they should last you to at least 80k I would think. If I remember correctly, supercharged applications have to change them out at around 60k.
  7. Sep 2, 2016 at 7:48 PM
    mbrogz3000
    Northern NJ
    No, not supercharged, yet :( . Maybe once I make a case my wife that it saves fuel or some other backwards fabricated BCA, heh heh heh.
    So the derived recommendation here is... If you are not supercharged and have iridium plugs, then it's acceptable to go to between 80k to 100k miles. If you are supercharged, then change them out every 60k miles.
    The benefit of going with iridium is not having to swap spark plugs every 30k miles.
  8. Sep 2, 2016 at 7:55 PM
    eon_blue
    Azusa, CA
    Another added benefit of Iridium is that if you are supercharged, the engine performs much, much better. I learned this the hard way. Stock copper plugs cause spark knock like crazy, colder iridium plugs = no spark knock.
    Also, saying that the supercharger 'saves fuel' doesn't necessarily have to be a lie...it can actually be true. Technically speaking, a supercharger makes an engine run much, much more efficiently. Only reason it causes MPG's to go down is because people tend to go wide open throttle with it to get all of the added power. That'll kill your gas mileage even if you're not supercharged. If you drive normally with a supercharger installed, you can actually see better MPG. I get great mileage if I'm driving carefully with my s/c. If I decide to have some fun with it, well....that's another story, haha.
  9. Sep 2, 2016 at 8:37 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The 2.7L come with iridium plugs from the factory. The factory maintenance for the spark plugs is 120k miles.
