IronMan 4x4 2" lift!
Discussion in 'Product Reviews' started by Haslefre, Aug 4, 2012.
  1. Mar 30, 2013 at 6:36 PM
    #181
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    ok that sounds good
  2. Apr 10, 2013 at 11:57 AM
    #182
    zeekevin
    zeekevin Well-Known Member
    San Diego
    any updates? i really want the rear setup
  3. Apr 10, 2013 at 11:59 AM
    #183
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    The rear rides really nice, I used ome front coils and the ironman rear leaf springs with 5100's
  4. May 22, 2013 at 3:45 PM
    #184
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    It is here
  5. May 22, 2013 at 6:48 PM
    #185
    zeekevin
    San Diego
    Please take some before and after measurements when you do the install
  6. May 22, 2013 at 9:32 PM
    #186
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
    How quick was their shipping? Did you go through Sierra Expeditions?
  7. May 23, 2013 at 4:44 AM
    #187
    BostonBilly
    Easton
    Ya I spoke with Cliff at Sierra Expeditions and then ordered online. The shipping was quick 6 days and would have been a day earlier but I wasnt available to receive it.
  8. May 23, 2013 at 5:37 AM
    #188
    Haslefre
    Haslefre [OP] Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    You guys got lucky. I was the first one to buy from them and I got hosed. It ended up being 45 days before I got mine.
  9. May 23, 2013 at 5:40 AM
    #189
    BostonBilly
    Easton
    I dont know why there arent more people talking about this lift and/or buying it. Whether you like it or hate it for the price point and everything it comes with how can you not look at it
  10. May 23, 2013 at 5:50 AM
    #190
    Haslefre
    Brady
    TN
    2019 Tundra
    It isn't "proven" here in the states yet. There are only minor things I don't like about it, but I am keeping my negative reviews away. For the money and the customer service it is the best lift out there. If you have any questions about my negative reviews, you can PM me ;)
  11. May 23, 2013 at 6:33 AM
    #191
    Swamp Donkey
    Swamp Donkey Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    I've had mine in for over a month. The biggest screw up I had was for the leaf spring poly bushings. I got sent 12 bushings of the same size, and after burning and smashing and whatever else to get the old bushing out I found out the ones they sent were way to big. Had to take them to a lathe...... Grind em etc. :mad: Also, the rear leaf springs were sagging right from the start just after the install with my aprox 700 lbs of weight. Probably a good inch lower in the rear. I have since added air bags.
  12. May 23, 2013 at 7:40 AM
    #192
    sportsguy
    sportsguy searchgeek
    Any updates folks?
  13. May 23, 2013 at 8:06 AM
    #193
    Haslefre
    Brady
    TN
    2019 Tundra
    Mine still rides great. Only neg review I'll post here is already posted. Leaf springs aren't meant for the double cab I don't think. I'll probably do the OMD treatment to them in a year or two. But, almost one full year with the lift and i'm still happy.
  14. May 23, 2013 at 8:07 AM
    #194
    Haslefre
    Brady
    TN
    2019 Tundra
    Btw, your bushings weren't too big. You probably did what I did and tried to fit them without the whole old bushing sleeve removed. We didn't see it for about an hour while installing them
  15. May 23, 2013 at 8:53 AM
    #195
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I think you should post your negative reviews, it would only help in my eyes. I for one have been looking at this kit for awhile, so any review really helps. As long as its a constructive review and not a bashing..
  16. May 23, 2013 at 11:00 AM
    #196
    zeekevin
    San Diego
    Yeah please post the negatives. I need to know the pros and cons before buy the rear lift setup
  17. May 23, 2013 at 11:56 AM
    #197
    Haslefre
    Brady
    TN
    2019 Tundra
    No bashing on this involved. This is what I sent BostonBilly
    Now let me expand on this a little more for those of you who have not bought it yet. It is an amazing lift. It holds exactly what it needs for those who don't HAUL a lot. It hauled great for me the first few times I used it... mind you this was in an access cab I used to have. Now that I have a DCSB, it seems like the added weight in the back has made it settle down a bit more. I can still haul a good amount of weight before I have any sort of flatness to the springs. But, you will have a small difference between left and right on your rear end. I think they added for the weight of the gas tank, but not as much as they should have.
    If you are going to have a topper of some sort, or added weight at all times, I would look into a different leaf pack that is more suited to a higher year-round weight. Or, you can do the OMD (old man doug) mod to these as I plan on doing in the next year when I get to a U-pull junk yard and find some good springs to add.
    The powdercoating on the front coils is soft. Mine chipped on just the drive from the shop to the house, and it has gotten progressivly worse. I would recommend, especially for those in a higher salt area to coat everything in sealant of some sort before installing these. I am in a low salt/snow area and I have some rust spots on the outsides of everything in less than a year. I believe IM4x4 doesn't use the greatest rust proof items because, well, it isn't very cold/snowy in Australia.
    The shocks do a great job at dempening the bumps though. They are exactly what I needed for some of the dirt roads I go down. But again, the body of the shocks have some rust on them now.
  18. May 23, 2013 at 5:52 PM
    #198
    Hughesc99
    Derby, KS
    Ok cool thanks.
    Hmm...well...dunno when to order now
  19. May 23, 2013 at 6:00 PM
    #199
    Hughesc99
    Derby, KS
    So Brady, you know my truck is a dcsb, and im going to add probably a bakflip cover. You think that much added weight is going to make the rear drop too much? What about getting the lean spacer from toytec to help compensate for the lean? I was stuck on this kit b/c it replaces the whole leaf pack, now Im considering the eibachs/bilsteins with an add-a-leaf again. I dont know about paying all that money to have a leaf pack thats going to sag with a little weight again and have powder coating chipping on the first drive. Not to mention the leafs squeaking constantly....
  20. May 23, 2013 at 6:01 PM
    #200
    Haslefre
    Brady
    TN
    2019 Tundra
    Mine was the first shipped out. They made a mistake at the warehouse... Shipped to Sierra on accident
