IronMan 4x4 2" lift!
Discussion in 'Product Reviews' started by Haslefre, Aug 4, 2012.
  1. Apr 10, 2014 at 4:21 AM
    #401
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    So your 315/75's are basically 35x12
    Do you get off road much, cause aren't those gonna rub a lot?
    Didn't going from 30 to 35 cause a large perceived power drop?
    It sure looks good!
  2. Apr 10, 2014 at 8:22 AM
    #402
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    ya basically a 35. I get off road a lot and won't rub once I get .75'' spacers. You have to cut 2 inches out of the fenders and beat the pinch weld flat.
  3. Apr 10, 2014 at 8:30 AM
    #403
    AlanLoshbaugh
    Alan
    Columbia, MO
    Did you re-gear?
  4. Apr 10, 2014 at 8:31 AM
    #404
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I am right now with the ECGS GB but the difference between 265 and 315 in power was minimal
  5. Apr 10, 2014 at 8:36 AM
    #405
    AlanLoshbaugh
    Alan
    Columbia, MO
    ECGS GB?
    I would have thought there'd be a fair diff between 32 and 35. And; stock and 35, as I presume you haven't changed diff gearing from the stock gears/tire size...
    Cool to know.
  6. Apr 10, 2014 at 9:00 AM
    #406
    BabyTaco
    Wyoming
    2011 RC Tacoma
    No but I also had treadwright guard dogs which are noticeable heavier than other tires I guess.
  7. Apr 24, 2014 at 10:52 PM
    #407
    gb42
    gb42 Well-Known Member
    Geoff
    WA State
    2016 MGM TRD OR DCSB MT
    Just wanted to update.
    I ended up putting a bag of sand near each wheel well. Now I only have slight takeoff vibes and the truck rides much smoother now. Very happy with the suspension, especially the price for the quality.
  8. Apr 25, 2014 at 7:29 AM
    #408
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Really? What's the weight on them?
    I stuck with a 265, but went from 65 to 70 sidewall. The tires that I put on are 10lbs. heavier each, and I had a noticeable difference in perceived power. Takes more gas to go and more brake to stop....
  9. Apr 28, 2014 at 6:07 AM
    #409
    ALBtacoma
    ALBtacoma Well-Known Member
    Pete
    Red deer AB, Canada
    07 trail limo trd sport
    Has anyone got the foam shocks or are most of you running the gas one? I'm also not sure what shocks to get. I don't off road too much mostly when camping and hunting. But I also quite of bit of renos in my house and load it up pretty heavy sometimes. Just not sure if I should get the b or c suspension?
  10. Apr 28, 2014 at 7:15 AM
    #410
    Haslefre
    Haslefre [OP] Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Shit, I can't remember which I got. I think I purchased the gas. Let me go look at my first pictures.
    As far as I can tell, they were gas. It's been 2 years since I bought the kit...
  11. Apr 28, 2014 at 7:17 AM
    #411
    AlanLoshbaugh
    Alan
    Columbia, MO
    I got the foam
  12. Apr 28, 2014 at 7:22 AM
    #412
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Foam here, couldn't tell ya if its any better than the gas though. They work for me :notsure:
  13. Apr 28, 2014 at 5:25 PM
    #413
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    I think very few of us will actually use them enough to notice the difference. I went with the foam to be different...
  14. Apr 28, 2014 at 5:32 PM
    #414
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    Where can you get this lift?
  15. Apr 28, 2014 at 5:37 PM
    #415
    Ironman 4x4
    Ironman 4x4 Active Member
    Hey Mate,
    Nitro Gas Soft Ride shock absorbers are best used where comfort is preferred rather than firm control. The softer valving is best suited to light or no load applications. The Foam Cell shock absorbers provide a similar feel to the Nitro Gas shock absorbers, but these shock absorbers feature a larger piston and bore size to allow for more oil capacity which allows the shock absorber to operate cooler in rough offroad conditions or long haul corrugations.
    As for B or C suspension. That really comes down to how much load you are carrying constantly in the back. A B spring may sag when adding a large load, but if not carrying constantly would probably be better for when driving unloaded and won't cause permanent sag (only temp whilst weight is on it). C springs would be better if you are constantly carrying weight i.e. tools etc are in the back full time.
    Hope that helps answer some questions!
    Cheers,
    Ironman 4x4
  16. Apr 29, 2014 at 11:20 AM
    #416
    ALBtacoma
    Pete
    Red deer AB, Canada
    Do you if they are still working on a group buy! Would be a great way to let North America know you're here to stay
  17. Apr 29, 2014 at 11:47 AM
    #417
    AlanLoshbaugh
    Alan
    Columbia, MO
    I'm not sure there ever was one.
    There's 19 tonnes of ironman in a cargo container that should be here about any day
    You should be able to order about mid may
  18. Apr 29, 2014 at 2:24 PM
    #418
    ALBtacoma
    Pete
    Red deer AB, Canada
    I thought i read earlier that haslefre was talking to ironman about maybe doing one. So just thought I would ask to see if he had an update.
  19. Apr 29, 2014 at 2:30 PM
    #419
    AlanLoshbaugh
    Alan
    Columbia, MO
    two vendors I know of are:
    trdparts4u
    metaltech 4x4
  20. Apr 29, 2014 at 2:35 PM
    #420
    Haslefre
    Brady
    TN
    2019 Tundra
    Currently, they are not being sold. When they open in Portland, I'll go down and talk to them. But no, I never was going to set it up, just guide people to the right place.
