IronMan 4x4 2" lift!
Discussion in 'Product Reviews' started by Haslefre, Aug 4, 2012.
  1. Mar 11, 2013 at 2:01 PM
    #161
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Boner if a gb is set up! Might be willing to buy if it's around 600. Bucks
  2. Mar 11, 2013 at 4:16 PM
    #162
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    The suspense is killing me!
  3. Mar 13, 2013 at 12:20 PM
    #163
    brochacho
    brochacho Well-Known Member
    Vancouver, WA
    2016 4Runner SR5
    subd for group buy!
  4. Mar 14, 2013 at 7:10 PM
    #164
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
  5. Mar 18, 2013 at 1:36 PM
    #165
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  6. Mar 22, 2013 at 7:43 AM
    #166
    Swamp Donkey
    Swamp Donkey Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    Hey,
    I am going to be installing this lift tomorrow. I only have two questions and they are about both your mistakes! What exactly do I have to use off of my original rear leaf spring bushings for the new kit? I would say is it obvious, but if you missed it! And this top spacer plate deal that was installed incorrectly, if I follow instructions to a "T" will I be fine? Or are the instructions real crappy?
  7. Mar 22, 2013 at 6:45 PM
    #167
    Haslefre
    Haslefre [OP] Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Sorry I didn't get back to you earlier. I've been in the hospital all day long.
    Rear spring bushings... NOTHING! You need to re-use your shackle obviously...but with those bushings... Cut them or press them out. You get new bushings. Might as well use NEW poly ones vs the shitty ones we get originally. Make it easier on yourself and put some grease on them.
    Instructions? What are those? I went pretty much off the OME install linked in the suspension pages. It isn't anything new. For the front though, make sure you take your springs and shocks to a store and have them swapped. No home use coil compressor will get them to work. If you need any assistance, just holler. Hopefully I will have more time to reply. If I don't get ahold of Hagen. He seems to have it down fairly well also.
  8. Mar 23, 2013 at 6:59 PM
    #168
    Swamp Donkey
    Fort St John B.C
    I got the lift in. Until I talk with the guy I bought the kit from I will not post much other then I am not that thrilled.
    The 1st pic is before lift. 2nd is after lift. I think my back end is sagging more with the brand new 5 pack leaf springs with 2 overloads! I mean the overall differential between the two. Very depressing.
  9. Mar 23, 2013 at 7:10 PM
    #169
    Haslefre
    Brady
    TN
    2019 Tundra
    Can you send me pictures of the leaf springs? I'm thinking they sold you the wrong rating for the cap.
  10. Mar 23, 2013 at 7:47 PM
    #170
    Swamp Donkey
    Fort St John B.C
    My leaf springs are perfectly flat right now. I told the fella I am always loaded and went across the weigh scales and got front and rear axle weights and told him I wanted the most HD kick ass rear leaf springs.
    The other pic is just of all the crap I have in the back of my truck at any given moment.
    The GVWR is 2426 Kg. (5400 or so Lbs.) So I am right around the vehicles max GVWR.
    The door sticker says 1249kg and the scale said 1160 kg for front axle.
    Rear axle sticker say 1410 kg and my rear axle was 1300 kg.
    My curb weight is just a hair below 4000 lbs. 3970 kinda area.
    Thinking I need a little more help back there! Like I mentioned before, the truck is always loaded. So I will have to figure something out.
  11. Mar 23, 2013 at 7:53 PM
    #171
    Haslefre
    Brady
    TN
    2019 Tundra
    I would recommend taking out an overload leaf and finding some Chevy springs to reinforce your current pack, even brand new. Look for the thread on it... Probably your best choice. Or spending cash on a custom all pro set
  12. Mar 23, 2013 at 7:53 PM
    #172
    Swamp Donkey
    Fort St John B.C
    I figure a humongous front bumper and winch might level things out!:facepalm:
  13. Mar 23, 2013 at 7:56 PM
    #173
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    Actually the springs may be working just fine, I think what you are seeing is the the front is now higher than the back when you're loaded down, this is more than likely because these springs were designed for the V6 trucks which have an additional 80-90lbs on the front axle, therefore the springs in the front are giving you more lift. I have the exact same truck as you, with the cap, and had the same stance as your truck in second the pic. Now from your pics I can tell that the springs are working, what size tires do you have?
  14. Mar 23, 2013 at 8:17 PM
    #174
    Swamp Donkey
    Fort St John B.C
    Stock 245-75-16 tires. It just drives me nuts to be so low in the back, getting blasted by high beams from others who thinks I have my high beams on. It even feels lower now in the back then stock when I am driving. Don't need to recline the seats! I am already chillin with my back bumper inches from the ground! HAHAHA.
  15. Mar 23, 2013 at 8:57 PM
    #175
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Sub'd for reference - Great Thread!
  16. Mar 23, 2013 at 8:57 PM
    #176
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    Well how much weight do you figure is in the back? The cap takes an 1/2 inch off the springs as it weights 200lbs, then add all the weight that you have back there and you're probably pushing +500lbs. More than likely you just need a heavier set of springs like Dakars.
  17. Mar 23, 2013 at 9:03 PM
    #177
    Swamp Donkey
    Fort St John B.C
    Darn. Go through all the cost, effort etc of installing the wrong part and having to do it all over again. :( I figure around 7-800 lbs with the canopy.
  18. Mar 25, 2013 at 4:20 AM
    #178
    tweeter1148
    tweeter1148 Well-Known Member
    Brandon
    Fort Worth, TX
    19 DBL CAB SHORT BED TRD OFF ROAD
    So all you need to buy extra for this kit is the sway bar relocation bracket? I see their greasable shackles are pretty cheap..should i pick those up too.
  19. Mar 30, 2013 at 6:28 PM
    #179
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Cape Breton Island Nova Scotia
    09 Tacoma 4x4 TRD Off Road
    The Ironman website doesnt say much about their products. Are the leaf springs military wrap? Are they really comparable to Dakars?
  20. Mar 30, 2013 at 6:30 PM
    #180
    Haslefre
    Brady
    TN
    2019 Tundra
    Close to yes. Same engineers opened their own company from OME
