Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. Feb 23, 2022 at 3:45 PM
    #2241
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Sorry to hear, that sucks. At least it sounds like not much suffering.
  2. Feb 24, 2022 at 6:07 AM
    #2242
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I went ahead and ordered a rope shackle and the adjustment tool. Should be here tomorrow. I’m going to end up lowering the front just a little more. There is some strange bounce back or something if I hit speed bump/humps head on and going around 30… I know I’m not supposed to go that fast over them but it’s for scientific purposes… :anonymous:
    Yea, we weren’t 100% sure what was wrong with her besides being diagnosed with diabetes. The vet though when she went that way she was unable to cope/recover even with the insulin.
    the.shelbysaurus likes this.
  3. Feb 24, 2022 at 6:39 AM
    #2243
    Montana_Actual
    Montana_Actual ;)
    Cool man let us know how that works. I just ordered DRT CMR's and skids. I plan on doing all the cutting and trimming this summer. I'm gonna lower mine a bit too as soon as my spanner wrench set gets here. I'll probably rub the cab mount with any flex but going to try and avoid it until the CMR is done. Hopefully when the 34s go on I don't have to do fender trimming, but I also plan on getting DRT spindles and removing the extended flares I currently have on. I already have all the replacement clips and adhesive - but no need to do it until the tires go on. One more winter with the wildpeaks. Going to add some PSI today to the fronts as see if that solves the squishy look or if it was just due to being cold. Seeing if I can find that middle ground between squishy tires and stiff ride :D
    Unfortunately, I notice a lot of "creeking" going on, especially when it's cold. I don't like these sounds, but they are probably normal. Mostly over the shitty entrance ways to shops in my small town with potholes bigger than my entire truck...
    hyrule_trd[QUOTED] likes this.
  4. Feb 24, 2022 at 6:58 AM
    #2244
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    that sounds like a great plan, you’re truck is gonna look great. Are you going to hammer the pinch weld too?
    I can’t say I hear any creaking but I keep Woolwax on things that might, like the leafs. Not that I’ve ever been to Montana I’m sure maryland does not get anywhere near as cold. And usually when it’s single digits or in the teens I don’t tend to go anywhere.
    I’m not too concerned how much lift I end up with (but under 2” is lowest I’d go) as long as I’m happy with the ride and can fit the tires.
  5. Feb 24, 2022 at 7:39 AM
    #2245
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    :rofl:
  6. Feb 24, 2022 at 10:36 AM
    #2246
    Sleddog0311
    Sleddog0311 Active Member
    Black 2020 DCSB TRD OR
    Barricade HD rear bumper, Cali-raised smoked rear LED lights, Black Rhino (Chamber) black 17x8.5, 0 offset, 4.75 backspace wheels, Toyo Open County AT III 275x70R17
    Thanks!!!
    Yes they are E rated. They were stiff at 36 psi on the stock OR suspension so I suspect they will be worse with the Ironman Stage 2 but as I said, can't be much worse then a jeep lol.
    I already have a heavy steel rear bumper on and will add a topper soon as well, I'm done vacuuming out Husky hair every day hahahaha. When we go to camp we always have at least a couple hundred pounds of added gear but that's only on weekends.
  7. Feb 24, 2022 at 5:13 PM
    #2247
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I installed my stage 2 kit today.
    I put the rear shocks on the wrong side so the stickers face inboard. Oops.
    took me all day, only one trip to harbor freight to get a bigger set of channel locks to bend the pinch weld and a pry bar.
    i ran out of swear words on the rear leafs but they eventually went in.
    alignment in the morning and the. I just need to add the driveshaft spacer thing. It also came with sway bar spacers but it said “hilux”.
    I took before measurements from ground the fender flares and will do it again tomorrow. I should probably get an ECGS bearing on order
    hyrule_trd and Montana_Actual like this.
  8. Feb 24, 2022 at 5:14 PM
    #2248
    Montana_Actual
    Montana_Actual ;)
    Same deal. If they fit they go on :thumbsup:
    hyrule_trd likes this.
  9. Feb 24, 2022 at 7:26 PM
    #2249
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    IIRC some people who put them on sticker out actually had some slight rubbing issues.
  10. Feb 24, 2022 at 7:32 PM
    #2250
    Montana_Actual
    Montana_Actual ;)
    No I mean the sway bar spacers.
    Jojee117[QUOTED] likes this.
  11. Feb 24, 2022 at 7:37 PM
    #2251
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Great to hear! The spacers should still work. I think someone posted about installing them here somewhere.
    How’’d the pinch weld bending go?
    Where’s the pictures?!
    The stickers do face inward for some odd issue.
  12. Feb 24, 2022 at 7:46 PM
    #2252
    Montana_Actual
    Montana_Actual ;)
    Interesting. So the sticker is the part that says "hilux"?
  13. Feb 24, 2022 at 8:07 PM
    #2253
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Nope, now I’m confused lol. I meant the rear shocks. The stickers on those face inward.
    The spacers I don’t remember. I would guess they are probably the same as the Hilux. But I could also be 100% wrong.
  14. Feb 25, 2022 at 1:43 AM
    #2254
    Montana_Actual
    Montana_Actual ;)
    Yea that's what I was referring to. Cuz they mentioned the spacers being labeled Hilux and they already fixed the shocks. I'd assume the Hilux stuff is the same, but then again, shit happens and wrong stuff has been sent out before :burp:
    Lol.
  15. Feb 25, 2022 at 4:10 AM
    #2255
    Sleddog0311
    You guys are killing me lol
    So when I order my lift and I somehow fit the leafs on the front then what are you going to say hahahahahaha
    Montana_Actual and hyrule_trd like this.
  16. Feb 25, 2022 at 4:14 AM
    #2256
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    That would be pretty impressive…
  17. Feb 25, 2022 at 4:19 AM
    #2257
    Montana_Actual
    Montana_Actual ;)
    If it's anything like Ikea furniture, you unbox, try to assemble first, curse a lot, then fish out the instructions from the excess packaging you discarded 8 hours ago when you started the 1 hour job. Disassemble your backwards mess and then break a cheap piece that was crucial in construction. The next day is spent on the phone complaining about a "missing part" and how quality control has just gone down the drain in recent years.
  18. Feb 25, 2022 at 4:24 AM
    #2258
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Get a few more beers or a jack and coke and try again!
  19. Feb 25, 2022 at 4:24 AM
    #2259
    Sleddog0311
    Soooo true, don't forget momma peaking over your shoulder giving you the suggestions that oooobviously you should have followed to begin with hahahahaha
  20. Feb 25, 2022 at 5:01 AM
    #2260
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    what instruction booklet?
    I didn’t take any pictures because I was dead set in getting it installed. I’ll get pics later after the alignment.
    I did have an issue with the parking brake cable not bolting back up to the leafs.
    I probably should also get longer soft brake lines for everything now
