Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. Aug 26, 2022 at 7:14 PM
    #2481
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    Back when I was in Seattle I felt like there wasn't a huge difference around town (it was my daily and commuted into Seattle), but it was definitely struggling a little more on the interstate at 75-80 mph (like driving Seattle to Portland or Eugene). Mountain passes are rooough.
    On I90 through Snoqualmie and out to Eastern WA I used to be able to do 80 pretty comfortably. Now I keep it at 70-75 and on the hills I sometimes struggle to do 65. I just drove from Seattle to Colorado Springs a few weeks ago and it was certainly not as fast as when I did it stock in 2020, no more passing semis or other cars at 75 on hills. Heading out of Salt Lake City on I80 there were a few hills I had the pedal on the floor the entire time just to do 60.
    If you live somewhere pretty flat and/or aren't planning to road trip through hilly areas often it'll perform fairly similar to stock. Even if you are somewhere hilly or want to do long road trips just know you're gonna be slower. If you can't make peace with that, don't do it lol.
    Oh also, I don't have the lightest wheel/tire combo, so if you optimized that you might be better off. I just really liked the TRD Sport rims and I got C load 285/75/17s off my partner's Jeep. Next time I'll probably be looking for a lighter tire and probably do a tall skinny 33.
  2. Aug 27, 2022 at 1:00 AM
    #2482
    Wile_E_RedDog
    Wile_E_RedDog Well-Known Member
    Terry
    Sacramento, CA
    2008 Silver Tacoma OR Baja DCSB
    AT Overland Summit,
    All the sites I can find info on suggest curb weights of the following and 280 lbs with most if not all that being at the front axle.
    4,145 lbs. for 4.0 L gen2 DCSB 4x4,
    4,425 lbs. for 3.5 L gen3 DCSB 4x4 OR
    https://www.edmunds.com/toyota/tacoma/2008/features-specs/
    https://www.edmunds.com/toyota/tacoma/2018/features-specs/
  3. Aug 27, 2022 at 5:06 AM
    #2483
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
  4. Aug 27, 2022 at 5:09 AM
    #2484
    Fishingeek603
    New Hamphire
    Good looks. Yea I wanted to build her out for self reliance and longer overland trips. The lighter the better for sure. I was thinking softopper to cage rack with an rtt ontop build out the bed to hold essentials and a fridge. Was also planning on regearing as I hear that makes a world of difference and saves your Trans
  5. Aug 27, 2022 at 8:29 AM
    #2485
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Re-gearing the Four cylinder, while beneficial when up-sizing tires, isn't quite as dramatic an improvement as the V6's. The I4 has a 4.30 final drive, while the V6 get 3.90.
    The biggest issue with Pizza cutter tires is that they're pretty much exclusively E-loads.
    hyrule_trd likes this.
  6. Aug 27, 2022 at 9:32 PM
    #2486
    the.shelbysaurus
    Thanks for the heads up @Snaeper ! Hadn't actually looked into specs or anything yet :anonymous:
    @Fishingeek603 I've been thinking about regearing too. I know it won't be as dramatic of a difference as on a v6, but even a little improvement would be nice. I forgot to mention that I did that SEA-COS drive with like 400-500lbs of stuff in the truck.
  7. Aug 28, 2022 at 1:52 PM
    #2487
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    is everyone replacing the needle bearing when using the FCP? I'm going to pull the trigger soon and curious if I needed to do that while everything is in pieces.
  8. Aug 28, 2022 at 3:41 PM
    #2488
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    It’s hit or miss with any lift. I did mine when I installed the lift.I figured I’m already there doing things so why not.
  9. Aug 28, 2022 at 4:46 PM
    #2489
    GeoTaco
    Freeda Feltcher
    Denverish
    Car seats
    That’s what I’m thinking as well
    hyrule_trd[QUOTED] likes this.
  10. Aug 31, 2022 at 11:58 AM
    #2490
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    It took a few months but Ironman is finally sending me out a replacement set of leaf springs. I'm getting the constant leafs this time around and am curious if anyone installed them without removing any leafs. How much lift did it give? And if you did remove leafs, which ones?
    I've got 700lbs+ of constant weight in the rear
  11. Aug 31, 2022 at 2:08 PM
    #2491
    Wile_E_RedDog
    Terry
    Sacramento, CA
    AT Overland Summit,
  12. Sep 2, 2022 at 5:09 AM
    #2492
    Fishingeek603
    New Hamphire
    well of course im going up to 17's wrapped in some skinny tires. 4.88 is more than 4.30.... I'm considering turboing it at some point in the not so distant future as well. some boys have done some awesome vdery capable 4 banger builds lol
  13. Sep 7, 2022 at 2:03 PM
    #2493
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Forgive the noob question. Lots on info to weed through. Looking for some guidance on which springs to go with for the front FCP shocks. Currently have the Relentless slim winch bumper with winch, sliders, and aluminum skids. Thanks in advance.
  14. Sep 7, 2022 at 2:55 PM
    #2494
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Personally, I’d probably still say the lower rated ones, the A at 720# I think the 820# are too much and (having no real knowledge or understanding) probably for the other vehicles that they fit. They only say they for the Tacoma now so I’m not sure if anything besides the part number changed.
    It is really though to say though. You’re best bet might be to call and ask them.
    if you go with the smaller and end up wanting the higher rate, I’ll sell you the Bs for really cheap and shipping… they have 5-8k miles on them.
  15. Sep 7, 2022 at 11:14 PM
    #2495
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    I agree with @hyrule_trd Get the 720# springs. I had the constant load springs thinking I'd need them but even with all my weight, they were still a bit much. I have a full plate steel bumper with loops, winch, steel skids, cab rack, rock sliders. All this weight barely dropped the front.
  16. Sep 14, 2022 at 8:09 AM
    #2496
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    Who has installed the constant load leaf pack without removing a leaf?
  17. Sep 26, 2022 at 8:33 PM
    #2497
    Yotasama
    Yotasama Member
    Jesse
    2022 dcsb
    I got mine installed 2 weeks ago. cfp stage 2 2.5 inch lift in heavy load front and performance rear. But its sagging real bad. I only get 21.5 to center hub to fender. Just noticed that coil seat height is 8.2 and 8.4... what should I tell them to adjust seat height to? I'm new to this.... I need some help....
  18. Sep 27, 2022 at 4:09 AM
    #2498
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Great looking truck!
    It depends how much you want. I can’t say I remember what they normally set them at but maybe ask to go up .25” to start. That’ll give you roughly 1/2 more lift.
  19. Sep 27, 2022 at 6:15 AM
    #2499
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    If they have the actual ironman adjustment tool then its pretty easy to spray wd40 on the threads and crank it up while the shocks are still on the truck. Its such a beefy tool.
    I have bent other tools before (toytec!) and i have used punches for other shocks like fox 2.5. But man i love their tool.
  20. Oct 5, 2022 at 12:04 PM
    #2500
    themuffinman619
    themuffinman
    Your moms house
    Did anyone actually cycle the rear shocks 2-3 times prior to install? The rear feels super bouncy. Like the shocks are not dampening at all.
