Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. Mar 13, 2025 at 4:53 PM
    #2721
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    hyrule_trd likes this.
  2. Mar 13, 2025 at 8:05 PM
    #2722
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    The Dobinsons should be “only” 2200 or so. Not that it’s cheap or much better than 3500…
    If I get around to swapping the fluid I’ll let you know if that helps a lot. That’ll be about 2-300 for parts and fluids.
    JMcFly[QUOTED] likes this.
  3. Mar 14, 2025 at 6:05 AM
    #2723
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders RCI trans and t-case skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    If you already have leaf springs its "only" around $2500 and 100% worth it. You can't get better suspension for that price but if it's too steep take a look at the Dobinsons IMS... They aren't adjustable or have remote reservoirs but it'll only cost you around $1200.
    Took me all of 2 minutes driving on my MRRs to realize how lacking the FCPs are. It's a major improvement in every single way.
    hyrule_trd and Crikeymike like this.
  4. Mar 15, 2025 at 3:46 AM
    #2724
    r3k
    r3k Well-Known Member
  5. Mar 15, 2025 at 4:24 AM
    #2725
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thanks for sharing that video! I think they’re opinions of the shocks mirror mine, well not that I had a bias or expectation they were going to be bad. I bought them with great expectations. I bet if they had adjusters and I could have them ride softer I’d have no complaints.
    I still think they’re great but just not the right kit for me after driving on them for 4 years.
    I also can’t help but want to change things on my truck and mess with things.
  6. Mar 15, 2025 at 5:52 AM
    #2726
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    After watching the full blind test video I’m not sure what to think about the Dobinsons MRR. Maybe they’ll follow through with another test of the MRRs with the knobs in the mid setting.
    The review is a little odd though, I don’t think I’ve read any bad reviews on TW about them, MRRs I mean.
  7. Mar 25, 2025 at 7:04 PM
    #2727
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Well, I read through all 137 pages. Thank you all for sharing your experiences with the FCPs. I too wanted a rebuildable, large diameter shock that was height adjustable but didn’t want the feel of a gas shock and had no use for resi systems since I’m not doing desert baja. I do more slow crawling and just wanted some well-cushioned articulation. Parts have been ordered and received. I got the FCP 3” performance pre-built struts and rear shocks. I’ll be glad to be rid of this old Toytec lift. We’ll see how this all pairs with my OME Dakar leafs. I’ll let you know how it turns out. I have full front to back Budbuilt skids, BAMF sliders, BAMF LCA and diff skids, and a steel ARB front bumper and Warn 10k steel cabled winch. Just hope I’m not too heavy for the performance springs. I’ll update y’all once I get it installed.
  8. Mar 25, 2025 at 7:53 PM
    #2728
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Nice! It really is a great lift. I think it’ll work well for you with the extra weight. If I had more constant weight in mine I’d probably enjoy it more, just a little too stiff for me.
    I’ve not been in another truck with a different suspension, maybe they’re all the same and my expectations are unrealistic.
    elk340[QUOTED] likes this.
  9. Mar 25, 2025 at 8:00 PM
    #2729
    elk340
    Justin
    Ouray, CO
    I’m sure you’ve already tried lowering it 1/4” (1/2”). I’m afraid I’ll sit too low and be forced to raise it. FWIW, my Toytec ULK was super stiff (no dampening, just bouncing off everything) for about 5k miles before it even began softening up
  10. Mar 25, 2025 at 8:10 PM
    #2730
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I’ve tried a bunch of things, but none worked as well as I’d like. Right now I have 660# OME springs but I need to lower the spring seats just no time or time to get an alignment after. I didn’t adjust them enough when I put them on. It could just be unrealistic expectations of a lift.
    The E rated tires do not help either :rofl:
    When’s the instal happening?
  11. Mar 26, 2025 at 5:21 AM
    #2731
    elk340
    Justin
    Ouray, CO
    I bet lowering the seats, adding a bumper, or getting some D load tires would make a world of difference. Deleting your swaybar could help too. Lift is going in today…and maybe tomorrow and possibly rest of week
  12. Mar 26, 2025 at 8:30 AM
    #2732
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Good luck!
    Tried the sway bar but with having to commute 60 miles highway (daily now) I wasn’t comfortable with it off. Can’t say I noticed a difference. I might be putting my oem wheels/tires back on with my new daily commute to help the mpgs a little. A bumper would be nice…
  13. Apr 3, 2025 at 7:33 AM
    #2733
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Get everything installed? How you liking it?
  14. Apr 3, 2025 at 9:09 AM
    #2734
    elk340
    Justin
    Ouray, CO
    My early impression is very favorable. It feels very planted. Unbroken, they feel very FIRM, but not “springy”. So, I think the added weight of the bumper, steel cabled winch, sliders, skids, topper, etc., have helped a ton. I have just enough weight to compress the springs and it is articulating well. It will also soften up as it breaks in. Keep in mind, I only got the 3” 720# mediums, despite my added weight, I have D load tires, and I don’t have a sway bar. If I had less weight, the springs would not compress. If I got the heavy load springs, the springs would not compress. So, I am very happy I seem to have made the right call on which springs to get. I need to verify with a tape measure, but it appears I am sitting about +3.25”. It appears I still have a slight (1/2”) rake with my OME Dakars and extra leaf. My two inner fins on my inner CV boots are rubbing more than I’d like. I don’t have a diff drop as it interferes with my skids. I think it will settle about +2.75” and the CV angles will be perfect. I’m weighing the risk of driving it as is and letting it break and settle to where I want it or going ahead and lowering it now, alleviating that risk to the boots, knowing I may have to raise it 1/2” after it settles.
    All things considered, I think I will love this setup for the slow rock crawling I do around here. Now I have to replace my leaf packs because while under there, I saw that my passenger side #2 leaf is blown into three pieces. Once I replace these leaf packs, I’ll get the rake I’m looking for and it should feel a little tighter in the back
  15. Apr 3, 2025 at 9:29 AM
    #2735
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Great to hear and review. Sounds like you were spot on.
    One option you have, if you don’t know, the boot slide mod. I talked about it in this thread somewhere and might have shared the pm of the special hose clamps for hoses.
    It involves taking the inner clamps off, sliding the boots a little then re-clamping.
    I got the stuff to do it but never ended up doing it.
  16. Apr 3, 2025 at 9:49 AM
    #2736
    elk340
    Justin
    Ouray, CO
    Correct, that is another option and perhaps the best option at the moment. I did it previously with my prior lift. Those axles eventually gave up (after 80k miles) and were replaced and haven’t slid the boots on them yet
  17. Apr 3, 2025 at 2:53 PM
    #2737
    elk340
    Justin
    Ouray, CO
    Just measured hub to fender. D/S is at 23 5/16” and P/S is at 23 3/16” for a lift average of 3 5/16” over my stock height.
  18. Apr 3, 2025 at 3:00 PM
    #2738
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Definitely a tad high. Maybe since yours is an AC?
    in case you need to, you can adjust the height with them still installed. I’ve done up and down.
  19. Apr 3, 2025 at 3:20 PM
    #2739
    elk340
    Justin
    Ouray, CO
    I think it’ll settle right where I want it to be, but think I will boot slide to be safe
  20. Apr 3, 2025 at 3:43 PM
    #2740
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I think you’re probably right.
    I need to lower mine some, maybe .5” (.25” on the shock), since the springs are longer and I didn’t adjust for it when I swapped them.
