Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. Jul 28, 2020 at 10:11 AM
    #301
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    They’ve been really good at getting back to me also. I did noticed that their emails get delayed or gets mixed up.
    Starting a chat online and then moving to a phone call as needed has been the best way to get issues resolved. I had a similar coil issue and they are working with me through this process. The customer support has been really good from my experience.
    BearWithMe likes this.
  2. Jul 28, 2020 at 10:13 AM
    #302
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Question: on your rear driver side, is the shock tube touching the mounting housing? I just noticed mine is touching. I’ll have to snap a picture later.
  3. Jul 28, 2020 at 10:15 AM
    #303
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Yes for me, both the metal shock tube at the axle mount and the plastic dust tube at the top frame mount are barely touching where they shouldn’t be. Passenger side has more clearance. I made sure to install the angled lower mount inward to push the shock tube away from the axle.
    Superhulk LB[QUOTED] likes this.
  4. Jul 28, 2020 at 10:16 AM
    #304
    roy326
    Roy
    Southern California
    Do you mean at the bottom one bolt connection or the top with 3 bolted connection?
    With mine, the ironman logo is facing in since i had a conflict with it facing outwards.
  5. Jul 28, 2020 at 10:19 AM
    #305
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    interested to see
    well that does not sound good. Is it too big to fit in the spot or maybe an every truck is different? Sounds like it might not be the latter tho...
  6. Jul 28, 2020 at 10:19 AM
    #306
    Superhulk LB
    Josh
    Oregon
    That sounds like the front? this is the rear at the top. Need to look close at the bottom now too.
  7. Jul 28, 2020 at 10:25 AM
    #307
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    It’s just barely touching. I might take a Dremel and grind down the flange on the axle tube just a little bit. Would only need to remove a millimeter or two.
  8. Jul 28, 2020 at 10:27 AM
    #308
    Superhulk LB
    Josh
    Oregon
    Yeah. Thought about just loosening and trying to rotate it a little too. Not sure if that would change anything.
  9. Jul 28, 2020 at 8:45 PM
    #309
    Superhulk LB
    Josh
    Oregon
    Here is what it looks like.
  10. Jul 28, 2020 at 9:07 PM
    #310
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    oh ok, that’s not at all what I was thinking. I was think the back part of the front shock for some reason. That does not look bad, nothing should be an issue there. Not what you’d expect though.
  11. Jul 28, 2020 at 9:25 PM
    #311
    Superhulk LB
    Josh
    Oregon
    Yeah. That portion really should be stationary the shock moves in and out of the tube. So nothing really to worry about other than cosmetics.
    Thanks. Had to look it over again.
    hyrule_trd[QUOTED] likes this.
  12. Jul 28, 2020 at 10:30 PM
    #312
    FCL30
    FCL30 TACOTUNING NEXUS CREW MEMBER
    TACOTUNING
    Panama City, Panama
    2017 WHITE TRD SPORT 4X4 285/70R17 STOCK GEARS
    AFE CAI, HOOD STRUTS, IRONMAN4X4 FOAM CELL PRO LIFT, BAKFLIP MX4 COVER, HOOKEROAD ROOF RACK
    For Hilux/Fortuner and Tacoma(bubba wrote that) it is 229mm.......I put it that height and exceeded 3" of lift. How in the world with 255 and 260mm you get 2" lift? Are you on B coils and steel bumper/winch???
  13. Jul 29, 2020 at 3:37 AM
    #313
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    So after looking at your post, mine and a few others, I did a little more research. From what I can tell by searching measurements the Hilux sits .5 to 1 inch shorter, when center to fender than the Tacoma. It could be the fenders being different or other variables though. It looks like my planned measurements would be wrong, and need to come down to 230 and 235mm to get the height I was planning on.
    I’ll also say I was going to document the install and put the oem next to the FCP and measure them against each other.
    Anyone here measure the spring seat height with a ruler to see.
    I’ll do more looking around today. It think this might be the issue, or I misunderstood the flyer, badly.
  14. Jul 30, 2020 at 6:17 PM
    #314
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Not sure that last post makes sense anymore...
    either way I’ll measure the old next to new one and go from there. My kit should be shipped next week. Fingers crossed.
    FCL30 likes this.
  15. Jul 31, 2020 at 4:00 PM
    #315
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    Dialed out my driveline vibrations today. I used a set of 2.5 degree shims on the axle, the Ironman carrier bearing spacer kit, and an additional 4mm washer from Ace. Also grabbed some longer bolts for the carrier bearing from Ace. Perfect, no vibes at any speed.
    Without the additional 4mm washer, it was almost perfect but had a slight vibe around 5mph when starting off from a stop.
  16. Jul 31, 2020 at 4:28 PM
    #316
    roy326
    Roy
    Southern California
    I think you’re are saying the width of the two cars are different . Since the Tacoma is wider the lift is more following the simple Trig rule Theta x L = arc length so the L changes then arc length (lift height ) changes
  17. Jul 31, 2020 at 4:31 PM
    #317
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Awesome. Had you measured angles before the lift? I won’t be able to, not the right tools. Where did you put the washers? Mind sharing a pic?
  18. Jul 31, 2020 at 4:37 PM
    #318
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Id take the credit for that but I was thinking more of the heights of the 2ng gen and 3rd gen being different. I don’t remember if it’s due to suspension or wheel well/ fenders.
  19. Jul 31, 2020 at 4:49 PM
    #319
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    No date yet but it’s a start!
  20. Jul 31, 2020 at 4:51 PM
    #320
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    I did measure beforehand (spent $30 on a nice digital level) but to be honest, the math and the science behind U-joints kind of eludes me. Even after extensive Googling I'm not sure I understand the theory... So I decided to just iterate a bit and got it on my third try.
    In this photo, working from the top down we have:
    1. The truck
    2. The gold-colored rectangular spacer from the Ironman kit
    3. An additional round 4mm-thick washer below that. Not sure where I picked that up, found it in my spare parts bin
    4. The carrier bearing mounting flange
    5. A metric fender washer
    6. A longer bolt. Grade not terribly important since there's not much load on this. I think the captive nut on the frame is M12x1.5 but don't quote me on that. It was one of the metric fine thread variants, not coarse.
    roy326 and hyrule_trd[QUOTED] like this.
