Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. Jan 3, 2021 at 9:22 AM
    #1201
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    Yeah I did the constants. I couldn't take the new bolt off, so I stuck the old one on top and smashed it down to hold it. It'll be a fun one to take off..
  2. Jan 4, 2021 at 5:20 AM
    #1202
    Majora
    Andrew
    MD/WV
    Another thing I forgot to mention is that when I installed the leafs and shocks in the rear, the shock is fully extended which makes me nervous. Is this because there was no weight (was using a lift)? I'm thinking of getting shock extensions for now until I get my rear bumper to help weigh things down
  3. Jan 4, 2021 at 5:34 AM
    #1203
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    That’s an interesting question. While I’m not sure, I would think that’s the case. It would be tough to tell without jacking the rear end up again.
    That said and assuming there we’re no changes, here is what I got from IM a few months ago-
    The specs of the rear 45744FE shocks are 610mm extended and 399mm compressed. The front struts 45710FE are 564mm extended and 432mm compressed.
    Not sure how much that will help but maybe you can find an easy way to measure it.
    ShawZ and Majora[QUOTED] like this.
  4. Jan 4, 2021 at 3:32 PM
    #1204
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Ironman 4x4 Foam Cell Stage 2 Pro kit installed. Alignment went well. 2.5 inch lift.
    IMG_20210104_054306468.jpg IMG_20210104_155847047.jpg IMG_20210104_155909722.jpg IMG_20210104_182512937.jpg
    13txtaco, nwmorrow, rhmedjr and 4 others like this.
  5. Jan 5, 2021 at 5:22 PM
    #1205
    ShawZ
    ShawZ Well-Known Member
    Jon
    N. NV
    2020 Tacoma DCSB
    Ironman FCP Stg 2 FN f(x) AT3W 285/70/17 RSI SmartCap
    Random question... Working on getting another front end measurement but having a hard time consistently finding the "middle" of the center cap. With new tires pushing just past the fenders, its not as easy as stock wheels and tires!
    Im running FN wheels, (photo attached) could I just measure from either the top or bottom of the center cap and still get a decent bearing on how much I've dropped the front? I've read over and over that the center gives a consistent measure, and that makes sense, but I think I need to drop the front another full inch. Would it matter where I measure this full inch from? The top or bottom of the center caps are a way easier measurement than the "center"!
    Thanks!
    13txtaco, rhmedjr and hyrule_trd like this.
  6. Jan 5, 2021 at 5:52 PM
    #1206
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I think as long as you can get consistent measurements it would be fine for what you’re trying to do. I think that measuring from center or the cap is the standard for us to brag and compare our lifts, taking out variables like tire size.
    If you wanted you could always subtract the distance from the bottom of the center cap to the middle.
  7. Jan 5, 2021 at 6:52 PM
    #1207
    rhmedjr
    rhmedjr Raul
    Raul
    Oregon
    2020 TRD Sport
    Ironman Pro Foam Cell Stage 2 Lift Diode Dyanmics SS3 Pro Fog Lights Diode Dynamics Sl1 Low Beams Yakima Bedrock Rear Towers with 78” HD Bars Kuat Skinny Mini Rack Tepui Kukenam 3 Person Tent
    In my experience it seems to translate at a 2:1 ratio, if you lower the collars down 1/2-5/8” from their current position; it will yield 1” lowering of total front suspension. For your case I don’t see why it matter where you measure from, you could measure from center of fender well to the top of the tire (providing the same tire wear it should be within 1/32) which is accurate enough to achieve what your after.
    Like stated by @Devir7 the center of hub measurement is really just to standardize the amount of lift without the variable of wheel size and tire size being accounted for.
    The way I took my measurement is by using a plumb bob (string with a washer on the end, and got the bottom of the washer lined up eye level to center of hub, then measured that length.) Took two people and 10 minutes but I had the same issue with the sidewall protruding out and wanted as accurate a measurement as I could get.
  8. Jan 5, 2021 at 6:56 PM
    #1208
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    One other thought is to measure the shock assembly itself. Like others have said, if you take it down half inch at the shock, you should lower the fender an 1”
    ShawZ[QUOTED], hyrule_trd and rhmedjr like this.
  9. Jan 5, 2021 at 7:43 PM
    #1209
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    Question. I have the 2.5" FCP suspension, 265/75r16 (32s) tires. Just installed the IM4x4 UCAs today. When I go get my alignment done tomorrow, how much caster do you all recommend I have them aim for?
  10. Jan 5, 2021 at 7:47 PM
    #1210
    Superhulk LB
    Josh
    Oregon
    Do you have Ironmans alignment sheet?
    Astr0Aar0n[QUOTED] likes this.
  11. Jan 5, 2021 at 7:49 PM
    #1211
    Majora
    Andrew
    MD/WV
    Welp, I just dropped mine off tonight. Picking it up tomorrow night. What is this sheet so I can send it to my mechanic?
  12. Jan 5, 2021 at 7:51 PM
    #1212
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Superhulk LB likes this.
  13. Jan 5, 2021 at 7:57 PM
    #1213
    Astr0Aar0n
    Portland, OR
    I do not
  14. Jan 5, 2021 at 7:57 PM
    #1214
    Majora
    Andrew
    MD/WV
    I sent an email to a Chris Miller at Ironman. I haven't heard back though. If I don't hear from him tomorrow, I'll be reaching out to their instagram again haha
    hyrule_trd[QUOTED] likes this.
  15. Jan 5, 2021 at 7:59 PM
    #1215
    ShawZ
    Jon
    N. NV
    2020 Tacoma DCSB
    @Astr0Aar0n See Post #1182 (Pg 60) of this topic. Mandog has the Ironman specs written out. I also lost the Ironman UCA sheet, but @mandog has it for you. Hopefully that helps! Good luck!
    Astr0Aar0n likes this.
  16. Jan 5, 2021 at 8:00 PM
    #1216
    Superhulk LB
    Josh
    Oregon
    Here is the link also. https://ironman4x4.com/system/resou...RmY19VQ0EwMDFGQV9JTS5wZGYiXV0/UCA001FA IM.pdf
  17. Jan 6, 2021 at 4:50 PM
    #1217
    Astr0Aar0n
    Portland, OR
    Here's where I ended up after alignment.
    ShawZ, Superhulk LB and hyrule_trd like this.
  18. Jan 6, 2021 at 6:04 PM
    #1218
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I guess that looks good :notsure:
  19. Jan 7, 2021 at 6:28 AM
    #1219
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    I think we could all make guesses at how the spec sheets look, but its really going to boil down to each specific vehicle and how it feels in certain driving scenarios.
    I did a little more off-road driving on my way out to Arizona (about 25 miles of dirt road) and I really like how it feels on the trails. Could get it up closer to highway speeds out here and it felt great. Also, no issue with sway-bar delete, but was just coming into the turns gradually, not any high-speed moves.
    13txtaco, nwmorrow and Superhulk LB like this.
  20. Jan 7, 2021 at 6:34 AM
    #1220
    mandog
    Race City, USA
    Oh, I will say at the encouragement of @ShawZ .. I did go around and check all the bolts/nuts. Nothing loose, but I haven’t been able to get a good handle on the rear strut for its top nut, the one that compresses the rubber washer (?) from above. It’s on tight, but the rubber isn’t mooshed out to the size of the large metal washers its in between. the rod inside just keeps spinning, despite holding it with vice grips while tightening the nut. I suppose its fine, though.
