Ironman 4x4 Foam Cell Pro
Discussion in 'Suspension' started by Allstar780, Apr 15, 2016.
  1. May 24, 2021 at 6:49 PM
    #1501
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Curious to see video. Plus where in PNW? If pdx area and you need a second person, hit me up.
    Fletcher37[QUOTED] likes this.
  2. May 24, 2021 at 7:35 PM
    #1502
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    Let's try this... HD version still downloading. Phone cam video is all over the place but it's the "squeak" I'm trying to capture.
    https://youtu.be/Sw3fBlfXzYE
  3. May 24, 2021 at 7:51 PM
    #1503
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I’m no expert but does not sound like leafs. Maybe radiator mount bushing...
    @Superhulk LB, what did your squeak end up being?
  4. May 24, 2021 at 7:51 PM
    #1504
    Fletcher37
    PNW
    I'm in Beaverton. Didn't you deal with a squeak too?
    I was also hoping to increase the lift up front a bit but I'm not sure what the max preload is for these. Does Ironman list a max preload setting?
    Superhulk LB[QUOTED] likes this.
  5. May 24, 2021 at 7:53 PM
    #1505
    Fletcher37
    PNW
    Definitely not the leaf springs. It's from the front. Good idea to check the radiator mounts. I'm suspicious it's suspension given that it gets quiet when everything gets wet and "lubed".
  6. May 24, 2021 at 8:03 PM
    #1506
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Maybe take a can of fluid film with you on your next trip and each time you stop pick one thing to spray. Maybe you can isolate it that way.
  7. May 24, 2021 at 8:22 PM
    #1507
    Superhulk LB
    Josh
    Oregon
    I had a very obnoxious squeak. Not gone, but improved enough I can live with it. It was the rubber bushing/grommet on top of the strut tower. I had to loosen the top hat bolt and apply a heavy amount of sly lube beneath and above the bushing.
  8. May 24, 2021 at 8:49 PM
    #1508
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Did someb...
    Did somebody say they had, a squeak?
    https://youtu.be/LSc4l9pmVBc
    Welcome to my world.
    I call him, McSqueakin.
  9. May 24, 2021 at 9:12 PM
    #1509
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    I’m back in this thread for a second…. I’m got squeaks for days… plan on getting it all fixed but I have other things that will be worked on at the same time so giving a local shop my truck for a few days as soon as I buy a commuter car
    Superhulk LB likes this.
  10. May 25, 2021 at 6:25 AM
    #1510
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Good lord. Should I cancel my order right now lol only squeak I deal with now are my camburg uni-ball uca and that's an easy fix with some drops of lube :laugh:
  11. May 25, 2021 at 6:41 AM
    #1511
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I’ve not had any squeaks or creaks with mine. That said, I only have 3-4K miles on my kit.
    JoeTacoma02[QUOTED] likes this.
  12. May 25, 2021 at 8:11 AM
    #1512
    JoeTacoma02
    What lube did you use for the front and rear bushings on the leaf spring/uca? I guess this is more of a question for everyone. Gonna call Ironman tomorrow about the status of my order and want to make sure I have it before installation.
  13. May 25, 2021 at 8:44 AM
    #1513
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    For the leafs I coated in Woolwax as part of winter prep. For the shackles and bushings I used Lucas Red and Tacky grease. My SPC uppers used some valvoline palladium 3% moly but that’s in the zerk.
    Besides the leaf shackles I didn’t use grease anywhere else. I did spray a lot of metal with the Woolwax though. Not sure if I hit a potential problem area with that.
    JoeTacoma02 and Superhulk LB like this.
  14. May 25, 2021 at 10:20 AM
    #1514
    ohcaltexscar
    Chas
    Southwest Ohio
    Nobody’s going to ask huh?
    Fine since you’re all twisting my arm, I have an Ironman 4x4 kit as well. The Nitro Gas instead of the FCP but potato potato.
    My glorious creaks and squeaks, as far as I have been able to deduce, are from my Whiteline LCA bushes and not the Ironman kit.
    Reading through this though I suspect there could be other problem spots as well.
    I have a tub of Formula 5 from ES to coat them with when I pull my cam bolts.
    Jojee117 and hyrule_trd like this.
  15. May 25, 2021 at 10:46 AM
    #1515
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I thought it looked like you had those silver UCA and green coils.
    The body mounts and radiator mounts are known to squeak, but the body mounts not so much on new new trucks. Though I have seen more people replace the radiator mounts. Some are the sway bar as well.
    ohcaltexscar[QUOTED] likes this.
  16. May 26, 2021 at 3:56 PM
    #1516
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Check out @Fletcher37 post here- https://www.tacomaworld.com/threads/obnoxious-squeaky-noise-thoughts.700012/page-3#post-25735819
  17. May 26, 2021 at 3:59 PM
    #1517
    ohcaltexscar
    Chas
    Southwest Ohio
    Mine creaks like that when I turn the steering wheel, rolling or parked.
    I’ll check my sway bar and body/radiator mounts too just to see.
    I’m thinking about swapping the green coils for some Dobinson’s teals with a lower spring rate. Smoother ride that way and it’ll reduce that NC Bro rake I accidentally got. :rofl:
  18. May 27, 2021 at 9:48 AM
    #1518
    ohcaltexscar
    Chas
    Southwest Ohio
    hyrule_trd[QUOTED] likes this.
  19. Jun 2, 2021 at 9:25 AM
    #1519
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    So... after moving about 400lbs of stuff yesterday, my truck now has a noticeable squeak. I don’t think it’s the leaves as it only makes the noise after momentum shifts from pressing the brake or letting off of it. I did respray the leaf packs today and will drive around some later. Bouncing on the bed/shaking does not reproduce the sound. Definitely sounds like it’s from the back. Nothing looks loose but I’ll tq things later anyway and check that the spare tire didn’t come loose. Any other thoughts?
    https://youtu.be/JWB2C-EQ0UY
  20. Jun 4, 2021 at 8:03 PM
    #1520
    JoeTacoma02
    Bushings? Damn. And I just received my kit on Wednesday. Haven't opened the box yet but I'm surprise such a small box can fit both front/rear shocks + UCA + coils + bushings + u bolts. I assume my stage 2 kit comes with all of those besides the top plate, right? Lol
    EDIT: What my reply meant to say in regards to your post is I hope mine doesn't start creaking and moaning hahah
