Ironman foam cell pro lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tac85, Mar 2, 2025.
  1. Mar 2, 2025 at 4:05 AM
    Tac85
    Tac85 [OP] Member
    Hi,
    Planning for my tacoma 2017 DCSB a suspension upgrade.
    Ironman foam cell pro and add a leaf. No plan for uca now maybe later on
    Tire P265/70 R17 17
    What is the drawback of going with 3 inch lift.
    As per the forums it ia better less than 3inch lift however need to understand the impact.
    And shall i go with 1.5 or 2 since the shocks are adjustable and keep the rake.
    hyrule_trd likes this.
  2. Mar 20, 2025 at 1:20 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    When you lift 3” it changes the angle of the cv joints and can cause the boots to wear and fail quicker.
    2-2.5 lift is pretty good. For these trucks and there will be more up/down travel too.
    I was running about 2.5” for a while then swapped spings and am sitting at about 3” now. I’ll eventually lower the spring seat again.
  3. Mar 20, 2025 at 1:44 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Best to outline your use of the truck to best suggest. But rule of thumb has been becoming no more than 2" keep rake do not level budget for a front clamshell bushing if it doesnt cause vibrations early odds are high it eventually will.
    Next thing is why lift? Generally a change in wheel offset and a bigger tire will achieve a great look with substantially less drawbacks.
    hyrule_trd and jmneill like this.
