Ironman Lift
Discussion in 'Suspension' started by coryip, May 12, 2012.
  1. Jan 30, 2013 at 10:45 AM
    #101
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Does this lift exist for 1st gens?
  2. Jan 30, 2013 at 10:55 AM
    #102
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Unfortunately, no. I doubt they will start either since they don't make it anymore
  3. Jan 30, 2013 at 2:35 PM
    #103
    60driver
    60driver Well-Known Member
    Sean
    CT
    10 DC TRD Sport 4x4 Tim Mica
    Illum 4x4 switch, 20" LED bar in lower grill, LED in scoop, aux fuse box, avid light bar and 'sliders'
    Thanks for taking the time to write that review Hagen. Lots of good info and the truck looks nice.
  4. Jan 30, 2013 at 2:43 PM
    #104
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    They discontinued it?! That makes me a little more reluctant to get it... :(
  5. Jan 30, 2013 at 2:43 PM
    #105
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    all terrains? new tread pattern? what model is this?
  6. Jan 30, 2013 at 2:45 PM
    #106
    dlooney
    Dennis
    Wilmington NC
    Treadwright.com
    I think these are the guard dogs. They are retreads. They'll be my next tire...
    Good price for an aggressive tire. they also have BFG A/T pattern.
  7. Jan 30, 2013 at 2:50 PM
    #107
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    I believe he was referring to 1st gen Tacomas.These kits are a great deal and I don't think they're going anywhere.
  8. Jan 30, 2013 at 2:55 PM
    #108
    dlooney
    Dennis
    Wilmington NC
    Ohhhh gotcha. Yeah still weighing my options....so many different aspects I have to figure out.
  9. Jan 30, 2013 at 3:10 PM
    #109
    Haslefre
    Brady
    TN
    2019 Tundra
    Just order it. You will feel better about yourself
  10. Feb 20, 2013 at 2:37 PM
    #110
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  11. May 3, 2013 at 5:10 PM
    #111
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    OK:
    I did the install today. Notes:
    Front end is easy enough with a spring compressor, and ball point press.
    Disconnect the sway bar, no probs.
    No surprises.
    Driveshaft spacer: you'll need the big washers off the old bolts; the new ones don't come with a big flat washer.
    The rear kit comes with 6 bushings per spring, enough to do both ends of the rear springs, and the shackles. Shackle pins weren't greasable.
    pressed the old bushes out (which were nicely frozen) to find the supplied bushes were too big. Trip to the local toyota dealer solved that. don't press your old bushes out of the shackle unless you have toyota replacements
    Rear springs are labeled for driver and passenger side.
    Installed them thusly to find passenger side 1" taller than drivers side.
    My 220lbs standing on the pass side bumper equals the sides: the weight of the fuel tank, which is on drivers side, should be about 200lbs.
    Guess what: the drive on the other side of the road in Oz.
    So, I suspect I need to swap rear leaves to Oz sides.
    Anyone got input on this?
  12. May 3, 2013 at 5:15 PM
    #112
    Haslefre
    Brady
    TN
    2019 Tundra
    I had the same problem. Still kind of have a sag to the driver side from it...
  13. May 3, 2013 at 6:01 PM
    #113
    AlanLoshbaugh
    Alan
    Columbia, MO
    do you know if you put drivers side on the usa drivers side?
    and: you didn't swap, to try and correct?
  14. May 3, 2013 at 6:08 PM
    #114
    Haslefre
    Brady
    TN
    2019 Tundra
    I swapped after the first time... Got a bit better on the other side.
  15. May 3, 2013 at 6:22 PM
    #115
    AlanLoshbaugh
    Alan
    Columbia, MO
    I have a half tank of fuel; so a full tank would add about 90lbs to driver side, making it list more.
    Adding 125lbs to passengerside loweredd it a little less than a half inch.
    I reckon I'll swap rears tomorrow.
  16. May 4, 2013 at 10:30 AM
    #116
    AlanLoshbaugh
    Alan
    Columbia, MO
    OK:
    with drivers spring on drivers side, passenger spring on passenger side
    measuring at centerline of axle to wheel well
    drivers side was 38"
    passenger side was 39"
    swapping springs side to side
    drivers side 38 1/4
    passenger side 39 3/4
    so, we went from 1" diff
    to 1 3/4" diff
    back we go...I'm getting good at it, at least.
  17. May 4, 2013 at 11:23 AM
    #117
    AlanLoshbaugh
    Alan
    Columbia, MO
    aaaaaaaand, we're back to 38 and 39; 1" diff.
    50 minutes to swap sides.
    not bad, and, I ain't doin' it again.
  18. May 4, 2013 at 11:28 AM
    #118
    AlanLoshbaugh
    Alan
    Columbia, MO
    Also:
    the driveline might be a little "rumbly" compared to previous, but, myaybe not.
    It doesn't feel vibrate-y.
    At some point I may try subbing out the standoff plates for body washers of less thickness, or, add a body washer and see if it's different.
  19. May 4, 2013 at 11:28 AM
    #119
    Haslefre
    Brady
    TN
    2019 Tundra
    Don't blame you. I am not sure why it happens and only some of us notice it. Id like to put a small spacer in the driver side
  20. May 4, 2013 at 11:29 AM
    #120
    AlanLoshbaugh
    Alan
    Columbia, MO
    One more note:
    make sure you have bolt heads on the inside of the rear shackles.
    If you have bolt heds out, and threads in, the upper bolt will snag on the frame.
