IronRyno Fabrication LA area. Rock sliders, Suspension installs, CMC, Slider adapters
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Shmellmopwho, May 18, 2015.
  1. May 9, 2023 at 8:28 AM
    #3521
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    wish I had something like this on my Tacoma, but you're a bit far away and I think my wife just might smother me if I buy anything more for the truck right now. plus, her theory is that my running boards are the same as rock sliders...o_O
    Shmellmopwho[OP] likes this.
  2. May 9, 2023 at 8:32 AM
    #3522
    Dr_Kevorkian
    Dr_Kevorkian Well-Known Member
    California
    2nd Gen Pyrite Mica AC
  3. May 11, 2023 at 5:11 PM
    #3523
    21TacoTRDPRO
    21TacoTRDPRO Follow my IG @21toyoduh
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Exterior Gears: 5.29 revolution Lift: @Wescottdesigns UCA: @jbaoffroad Leaf springs: @ivdsuspension Wheels: @stealth_custom_series Tires: @yokohamatire Yoko MT Front Bumper @drtfabrication Rear bumper @outgearsolutions HC with tire carrier Roof rack: @Prinsudesingstudio w/2 Load panels 44" light bar Rock Sliders: @rcioffroad 20 BYND 4X4 tactical camper Bed stiffeners:@ChassisUnlimited @cali_raised_led P/S molle panels and Ditch light brackets Sequential led side mirror turn: @MesoCustoms Cat shields: @cali_raised_led Oil: @FUMOTO oil drain valve AC mod Rear Differential Breather: routed to fuel door CMC: @ironrynofabrication Fender Flare Trim: @21toyoduh Rock lights: @RoughCountry Hood scoop 12" LED amber / white + strove light bar Tailgate power lock/unlock: @toyotausa Hood Struts: @redlinetunninginc Rear recovery points: @nytop.store Rear sway bar: @progressgroupinc Tire carrier: Fishbone Offroad Interior Power Switch: @switch.pros.official Power tray: @powertrays @ragofabrication Center Console molle panels /bridge & wifey mount Footwell lights: @VLEDS front /rear + sunvisor vanity lights @Weathertec floor liners, in-channel guards, hood guard @DongarTechnologies rear view mirror USB @AJTDesign minimalist key fobs On board Air: @viaircorp 400P Wifey Air System CMD Center: @expeditionessentials @3TPAM 4x @RAMmounts GMARS: @MidlandUSA MXT275 GPS/Safety: @Garmin Overlander, Garmin Montana 700i
    I had the privilege of linking up with Ryan to do a CMC on my taco. While he worked we chopped it up; This dude is so down to earth, great family values and just a good all around man. The CMC turned out waaaay better than I expected and better than some others that I've seen from Big name establishments. I wish I would have know about his services sooner so I Could have got one of his rock sliders.. I highly recommend you hitting up Ryan for a CMC /rock sliders or suspension installs.
  4. May 12, 2023 at 7:16 AM
    #3524
    rip ej1
    rip ej1 Well-Known Member
    Daniel
    NorCal
    2020 AG TRD Pro
    Damn that's so cleeeean. :thumbsup:
  5. May 12, 2023 at 9:12 AM
    #3525
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Thank you bro
  6. May 12, 2023 at 1:54 PM
    #3526
    Shmellmopwho
    Shmellmopwho [OP] Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Go wheeling on a light trail, find a way to break your running boards, tell your wife you wanna go down to Disneyland and just make a vacation down here for the amusement park and a new set of “Steps” ;) ( that’s what we’ll call them)
  7. May 12, 2023 at 1:56 PM
    #3527
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Dude, it was such a pleasure meeting you. I really enjoyed hanging out and talking and getting to work on your truck. Your smile on your face when you were leaving not having to hear the tire rub the cab mount anymore was the icing on the cake hahaha! I really appreciate your kind words and your support for what I’m doing. Suuuuper nice to meet you man!
    21TacoTRDPRO[QUOTED] likes this.
  8. May 13, 2023 at 7:56 PM
    #3528
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    If anyone needs help with anything, sliders, cmc, suspension work, let me know!
  9. May 13, 2023 at 9:07 PM
    #3529
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    @Shmellmopwho, you obviously do a lot of suspensions. I assume you work on UCA’s on occasion? I’m curious if you swap the direction of the UCA bolt, when you put them back together?
    I rebuilt my TC uppers today, and in the process damaged the AC line. That sucked! It was a beeach getting out, but worse putting back. Ended up reversing the bolt and removed the break line (?) mount, which made it so much easier to install.
  10. May 13, 2023 at 9:20 PM
    #3530
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    The only problem that I see with putting that bolt back in the other way is gravity. IF!! for some reason that nut decided it was gonna come off, with the angle that the bolt goes in at, I worry about the bolt working it’s way out with repetitive pivoting of the UCA. Since there is no flange keeping the bolt in its place anymore, it is no longer guaranteed to stay put if that nut somehow came off. If the bolt is in the correct orientation and the nut comes off on the lower end, the bolt will have a much more difficult time traveling upwards and out towards the front of the truck. Is the way you have it coming out unlikely? Yes. Is it less safe than running the bolt the way it came from factory? In my opinion. Yes. If you were to drill a small hole in the end of the bolt and put a cotter pin there, so the nut couldn’t come off it would make me feel more comfortable haha
  11. May 14, 2023 at 9:54 AM
    #3531
    H3llRid3r
    SLcUT
    Good point. For what it’s worth, I had read somewhere that reversing the direction of the bolt was approved by Toyota.
  12. May 14, 2023 at 10:00 AM
    #3532
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It is approved, I have the documentation somewhere. But as Ryan said it's much safer to be installed in the original orientation. If it were my truck, I would want a small hole drilled and cotter pin at the end. And/or double nut.
  13. May 14, 2023 at 11:26 AM
    #3533
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Perfect! Toyota approved probably totally acceptable then. Just from a physics standpoint, gravity potentially wiggling that bolt downward and out is much more likely with the bolt being reversed. Strength wise, no difference though!
  14. May 14, 2023 at 12:19 PM
    #3534
    H3llRid3r
    SLcUT
    I assume you’ve done so many of them that you have it down to a science?
    Anyway, just wanted an opinion from someone who does it on the regular.
    Thx.
  15. May 14, 2023 at 1:16 PM
    #3535
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Haha I’ve done a few now :D
    Glad you got everything back in nicely and your truck is drivable! Strength wise you’re totally safe but like @Superdave1.0 said, maybe throw an extra nut on their as a jam nut for safety :thumbsup:
    H3llRid3r[QUOTED] likes this.
  16. May 15, 2023 at 7:07 PM
    #3536
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Bump! Hit me up if you need any work done.
    ROCK SLIDERS
    SUSPENSION WORK
    CMC
    H3llRid3r and jackn7 like this.
  17. May 17, 2023 at 2:45 PM
    #3537
    Shmellmopwho
    Lomita CA
    Bunch of stuff
  18. May 22, 2023 at 1:08 PM
    #3538
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    OmahTako, Superdave1.0, Jr. and 3 others like this.
  19. May 22, 2023 at 1:40 PM
    #3539
    BigCountry762x39
    TL
    PNW, Oregon!
  20. May 22, 2023 at 1:46 PM
    #3540
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    FWIW, I’ve had a UCA bolt back out half way that was installed in the factory downhill position. It’s not just gravity that would pull the oily out, heavy articulation on the trail will do it too. I always use blue loctite on my installs and have swapped most of the suspension nuts on my personal truck to nylocks.
