Irregular idle with bad gas mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaybird 22546, Feb 28, 2023.
  1. Feb 28, 2023 at 6:06 AM
    Jaybird 22546
    Jaybird 22546 [OP] Member
    2005 toyota tacoma
    Lift
    Just signed up, trying to get some insight from you guys. Sorry if I make it long post, just want to cover all bases .2005 toyota tacoma 2.7 just put reman long block engine in last week , used most of my old part. Throttle body etc .Truck sat for 6 months waiting on motor But can’t get the idle right. Jumps around from 600 to 1100 rpms, also not getting the best mileage either .The throttle body butterfly was stuck when engine was installed but freed up with oil cleaned throttle body and mass air flow senser . Did a hard rest on ecm several times and set throttle by cutting on ignition working gas petal several times as well. Is there air idle senser on a 05 can’t find a part number for it or location. And what about manifold air senser could that cause the problem or the just a bad throttle body not closing Anybody ever run across this issues? Don’t want to just throw parts at it
  2. Feb 28, 2023 at 6:17 AM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Is your PCV valve stuck? My trucks idle jumped around a lot and then upon cleaning the throttle body, MAF, and changing the PCV valve did it settle down and correctly idle.
  3. Feb 28, 2023 at 6:25 AM
    Jaybird 22546
    2005 toyota tacoma
    Lift
    Will pvc valve check this evening thanks
  4. Feb 28, 2023 at 7:33 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Did you clean the MAF and throttlebody before you put them in the reman engine?
  5. Feb 28, 2023 at 7:38 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Any codes?
    2nd gens don't use a MAP sensor or Idle Air Control Valve.
    What are your fuel trims at idle, driving, WOT?
    b_r_o and TnShooter like this.
  6. Feb 28, 2023 at 8:37 AM
    Jaybird 22546
    2005 toyota tacoma
    Lift
    Did Clean maf and throttlebody but the butterfly was stuck from sitting for 6 months oiled and freed it up . P0171 and p0505 codes
  7. Feb 28, 2023 at 8:39 AM
    Jaybird 22546
    2005 toyota tacoma
    Lift
    Also runs fine down the Highway but the idle is a issue
  8. Feb 28, 2023 at 10:14 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Did you move the butterfly by hand, seeing it stuck? Or did you see it stuck in the throttle sweep it does for position? Reason I ask is being stuck, and freeing it may have broken a couple teeth on the plastic gears, leaving spots where the motor is searching for movement.
  9. Feb 28, 2023 at 10:47 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    P0171 is Fuel System Too Lean (too much air/not enough fuel)
    P0505 is Idle Control Malfunction (PCM is unable to control idle speed)
    Seeing those 2 codes together I would really suspect a vacuum leak before anything else.
    There's a vacuum hose on the back of the intake towards the firewall that's kind of a pain to get hooked back up, maybe it didn't get hooked up.
  10. Mar 2, 2023 at 7:35 AM
    Jaybird 22546
    2005 toyota tacoma
    Lift
    Figured out the idle issue it was a vacuum hose dry rotted.
    ZMan2k2 and Dm93 like this.
