is 10w-30 okay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NRXTM, Feb 3, 2013.
  1. Feb 3, 2013 at 8:08 PM
    NRXTM
    NRXTM [OP] Well-Known Member
    Houston
    2011 toyota tacoma
    so i accidently put in 10w-30 oil in my truck , will it be fine ? btw it has only 10,000 miles
  2. Feb 3, 2013 at 8:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's a bit heavy, but it's not going to kill you in South Texas.
    If it were dipping into the 20s when you're starting up in the morning, I'd say dump it, but you'll be okay.
  3. Feb 3, 2013 at 8:16 PM
    NRXTM
    Houston
    2011 toyota tacoma
    okay , thanks just needed a little peace of mind :)
  4. Feb 3, 2013 at 8:32 PM
    jandrews
    '09 FourDubDee TRD OR
    Your truck gon' blow up.
  5. Feb 3, 2013 at 8:44 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    You are fine all oil ends up at 30 wt. and the lower number is just how fast it warms up to 30.
  6. Feb 3, 2013 at 9:13 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Have to disagree with you on this one. 0/20 is not 30 wt. you are half way right but not all oils are 30wt.
    One number is your start up velocity(cold) and the other number is the running temp velocity. So a 10/30 will start at 10wt and when it warms up it will be at a 30wt.
  7. Feb 3, 2013 at 9:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He was referring to the difference between a 5w30 and a 10w30.
    Hot weather, both are pretty much identical.
    At low temps, the 5w30 is a bit lighter with a lower cold-flow point, but as I mentioned, in Houston it's not a big concern. It's Houston, not Grand Rapids.
  8. Feb 3, 2013 at 9:24 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea not saying nothing wrong with putting the 10-30 in it. Just that not all oils are 30wt. My truck takes 0-20 so not all tacos have 30w
  9. Feb 3, 2013 at 9:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He's got a 2011, so I'm pretty sure he's also spec'd for 5w20, but the 20wt spec is primarily for CAFE fuel standards.
    2011 2.7 takes 0w20.
    2011 4.0 takes 0w20, 5w20, or 5w30.
  10. Feb 3, 2013 at 9:34 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    At least you get options with the v-6 oil! I'm stuck with 0-20 synthetic from factory so when my free oil changes are over I get to spend big bucks on oil.
  11. Feb 3, 2013 at 9:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Costco man....
    They occasionally run $10 instant rebates so 6 quarts of Mobil-1 is only $26.
    Toyota OEM filters are $88 for 20 filters from Camelback or Titus-Will.
  12. Feb 3, 2013 at 9:38 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    That's what I want to run is Mobil-1. Not sure if we have Costco tho? Have to check.
  13. Feb 3, 2013 at 9:41 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Costco, Sams... should have one or the other.
  14. Feb 4, 2013 at 3:27 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I bought a 5qt jug from walmart for my wife's cx-7 a few weeks ago for less than $25. Not too bad.
  15. Feb 4, 2013 at 4:38 PM
    NRXTM
    Houston
    2011 toyota tacoma
    thanks every one
  16. Feb 4, 2013 at 7:04 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    dont worry about it... for awhile i was running rotella T in my truck LOL its 15w 40... eat your heart out!
    and i wondered why i was getting crappy mileage!
