Is 16mpg Avg the Best I Can Do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BLOODYMARY, Jan 21, 2014.
  1. Jan 21, 2014 at 1:42 PM
    BLOODYMARY
    BLOODYMARY [OP] Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    I have the mods in my sig and avg 16mpg and drive nearly 100miles a day for work. Is it my 285s? Or just normal? I'd like to at least get 1-2mpg more. I have new plugs, cleaned TB, and fresh oil...perplexed.
  2. Jan 21, 2014 at 1:45 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    driving habits are the biggest, off the shelf mods wont help you MPG.
  3. Jan 21, 2014 at 1:46 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Those tires will definitely drop your mpgs. Are you also recalculating your mileage for the tire size difference?
  4. Jan 21, 2014 at 1:48 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    tires arent helping any, you bought the wrong vehicle for a 100 miles a day commute.
  5. Jan 21, 2014 at 1:48 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I have 285's and a 3" lift. I average 15mpg. Seems normal to me.
  6. Jan 21, 2014 at 2:24 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    The wider tires will drop the fuel economy a little bit but not as much as some people say. How you drive it has the biggest role in how much you burn. You should for the most part be able to keep it under 2000rpm and it will sip the gas (in comparison). Taking off hard from stops is bad, so is driving over the speed limit on the highway. I set my cruise control for 100km/h on the highway (just a **** hair over 60mph), sure my commute might take another minute or two, but you'd be surprised how much wasted fuel you burn when you go even 10 over the limit.
    Fuel econ works on a bell curve, peaking right around 90km/h. Granted not every engine, transmission, and gearing are the same, but statistically, under and especially over 90km/h your mpg drop substantially.
  7. Jan 21, 2014 at 2:28 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Drive with a light foot. That's about all you can do with those mods. Nothing you add will help. You've got a good looking bad commuter vehicle.
  8. Jan 21, 2014 at 2:34 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Agreed.
    I am guessing you drive HWY speeds so if you slow down you will get at least a couple more miles per gallon. Keep the truck under 60MPH and stay away from heavy acceleration and that will help. 55 would be best.
    The best option is a second vehicle that gets 40 plus MPG. It would pay for itself and keep all those miles off your truck.
  9. Jan 21, 2014 at 2:48 PM
    dde0485
    dde0485 Well-Known Member
    Black Hills, South Dakota
    '10 Tacoma TRD Sport 4X4
    If you're spending ~$300 a month on gas, I would absolutely get a used car with better gas mileage. A payment on that should be less than $300 and you get to keep your taco low on mileage!
  10. Jan 21, 2014 at 6:03 PM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    X2
  11. Jan 21, 2014 at 6:06 PM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    x3
  12. Jan 21, 2014 at 6:13 PM
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    I average in the 18s and i have the same set up, i also have a CAI and Catback exhaust. I have changed over to the E3 spark plugs and i can definitely say the truck sounds better and feels better, the oil i changed over to Mobil 1 0-20 full sinthetic.
  13. Jan 21, 2014 at 7:45 PM
    BLOODYMARY
    Keith
    Tulsa, OK
    2012 Tacoma Double
    I keep going back n forth on Long Tube headers. Will it help or hurt?
  14. Jan 21, 2014 at 7:54 PM
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    with the extremely cold temps in the northeast i am lucky if i see 14mpgs :rolleyes:.
    All city commute less than 8 miles round trip on 265's Duratracs. I wish i could get 16.
  15. Jan 21, 2014 at 8:00 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    I have a 2012 dclb stock tire and suspension and at very best I get 17mpg. I doubt there is anything you can do with that set up to get better then 16.
  16. Jan 21, 2014 at 8:03 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I have the same lift as you and same tire size but E rated Nitto Grapplers, and average 16-17 mpg, not odd at all. Truck is rated 16/21 from factory with 245/265's so I would say adding lift and tire size and still getting close aint bad.
  17. Jan 21, 2014 at 8:03 PM
    Captain Nemo
    Captain Nemo Well-Known Member
    20K Under the Los Angeles Sea
    '10 Access Cab TRD Off-Road
    ARB bumper w/ TJM winch, All Pro rear bumper, BudBuilt skid plates, DeMello Hybrid sliders, IPAA spotlights, Icon Stage 2 Suspension Lift Kit, 285/85/16 BF Goodrich AT, FJ TRD Trail rims, Optima dual battery w/ Wrangler solenoid, Wet Okole seat covers, BakFlip CS-F1 tonneau
    x4
  18. Jan 21, 2014 at 8:04 PM
    BLOODYMARY
    Keith
    Tulsa, OK
    2012 Tacoma Double
    will long tubes hurt my mpg?
  19. Jan 21, 2014 at 8:05 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Yeah im getting around 16 mpg on 285's. Curious how it will be in the summer.
  20. Jan 21, 2014 at 9:30 PM
    tacoflaco
    tacoflaco Well-Known Member
    Sean
    Bay Area, CA
    2013 ACLB Baja
    SnugTop SuperSport SpiderTrax 1.25" Spacers BAMF Sliders OEM smoked headlamps Pro Grille Paint matched grille surround Tepui RTT
    I'm on 285s with a 3" lift and am getting about 16.5. I have an 8 mile commute though and it is mostly highway.
