Is 2013 access cab frame same as 2006
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stellar, May 12, 2024.
  1. May 12, 2024 at 12:01 PM
    Stellar
    Stellar [OP] Member
    Scott
    2006 Navy Blue Tacoma 4x4
    None as of yet
    Hey fellas, I have a rusted out frame on my 2006 access cab. I found a 2013 access cab frame to replace it with and want to confirm it’s the same before I buy it. To be clear, I know they are different but I’m only replacing from the front cab mounts back so I need to know if I can use the back of the 2013 frame to replace my 2006. Thanks in advance!!
  2. May 12, 2024 at 12:09 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    A 2g access cab frame is a 2g access cab frame. Don't cut/weld, in many places you can't pass a vehicle inspection if the frame has been welded.
  3. May 12, 2024 at 12:09 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    It should work. I don't know if the trans mount was different b/t auto/manual(so you may have to use your trans mount somehow). I'd think that'd be the only problem.
  4. May 12, 2024 at 12:52 PM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    That’s what I thought. I’m only using the back of it. I’m gonna go grab it. Thanks guys!!
  5. May 12, 2024 at 1:32 PM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    Thank you!
    gixxerphil[QUOTED] likes this.
  6. May 13, 2024 at 6:25 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Heck why not use the whole thing?
    Take it from a guy who is currently doing some serious work....it might be easier if you can keep your project to bolt on and bolt off.
    ToyoTaco25 likes this.
  7. May 13, 2024 at 7:48 PM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    That’s a lot more work and time. My brother is a pro fitter/welder so he can make short work of the back end. Front end of my current frame isn’t too bad. A couple of patches and reinforcements have already been done. And it Turns out the frame I found was from a 2 wheel drive 4 cylinder which is very different in the front than a 4x4 V6. Same in the back though.
    kidthatsirish[QUOTED] likes this.
  8. May 13, 2024 at 7:57 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    As long as the donor frame was from another 2nd gen with the same engine and transmission (auto or manual) you'll be fine. Now if you got a prerunner frame all you'll have to do is swap out the transmission crossmember which is held by 4 bolts
  9. May 14, 2024 at 4:02 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    do it right or dont do it at all.
    ace_10 and ToyoTaco25 like this.
  10. May 14, 2024 at 6:28 AM
    Goldielocks
    Goldielocks Well-Known Member
    You must take pride in your ride to put this much effort into replacing the back half of your Tacoma. Do it right and thank your brother for his talent!
  11. May 15, 2024 at 3:09 AM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    Turns out the donor frame is a 2 wheel drive 4 cylinder which is very different in the front but seems identical in the back. I only need the back. Still gonna take some measurements and be sure before I buy it. Thanks for your input!
    Sasquatch3153[QUOTED] likes this.
  12. May 15, 2024 at 3:10 AM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    It’s a great truck! And I do take pride in it. Frame, a big downfall but worth fixing. And my bro is really good. He says it’ll be the strongest Taco that ever existed!
