Is $285 reasonable for a tranny flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma909, Dec 2, 2010.
  1. Dec 2, 2010 at 6:46 AM
    Tacoma909
    Tacoma909 [OP] Well-Known Member
    Missoula Montana
    2017 Tacoma 4X4 DCSB
    Level lift
    My dealership wonts $285 for transmission flush:eek:. Does that sound about right? My trucks just hit 100,000 (freeway miles)
  2. Dec 2, 2010 at 6:49 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    its a little high I paid $190 last time but I have an 03
  3. Dec 2, 2010 at 6:52 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    to bad your not in jersey i do them for $169.95
  4. Dec 2, 2010 at 6:53 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Its rape without lube.
  5. Dec 2, 2010 at 7:07 AM
    Tacoma909
    Missoula Montana
    Level lift
    Do you think all Toyota dealerships have the same price as far as lador?
  6. Dec 2, 2010 at 7:09 AM
    thenomad
    thenomad Well-Known Member
    Way
    Kennebunkport, ME
    I just had mine done for 125 (Chevy Impala 3.8L). That is crazy high. I would check somewhere else.
  7. Dec 2, 2010 at 7:23 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Sounds about right. Are they doing a flush or just a dump and refill? If they are doing a BG trans flush then yeah go for it. Ever had the trans serviced before? Better to have someone else do it than try it yourself. The dealer should warranty it for 12/12. It is also replaced with synthetic fluid if a BG service.
  8. Dec 2, 2010 at 7:39 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I paid 110.00 for the BG power steering flush/fill on my car so if that is what they are gonna do then 285 doesn't sound insane for BG tranny service but does sound a bit insane for anything else. My auto tranny on my car takes a 110.00 jug of AMSOIL to completely drain/refill all 9 quarts and paid 40.00 to have place pump in the new juice back when car was newer so yeah, 285 sounds high for regular flush/fill to me.
  9. Dec 2, 2010 at 7:53 AM
    Tacoma909
    Missoula Montana
    Level lift
    The only thing the dealership has done to my toyota is change my oil(except the air cleaner). I won't the full flush, he said he drains and fills acouple of times to completly get all the old fluid. I don't know what BG means?
  10. Dec 2, 2010 at 7:56 AM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    well if there just doin a drain and fill screw that....thats stupid expensive. thats why i dont go to the dealership unless i have to order a special part. the are way to freakin expensive. and BG is about the best automotive fluid service you can buy. good BG trans flush.....its good stuff. thats what im gettin done to mine in about a month
  11. Dec 2, 2010 at 8:19 AM
    pauls2ndblessing
    pauls2ndblessing Well-Known Member
    Paul
    Alabama
    06 PreRunner SR5
    My friend has a BG machine at his shop and has been trying to get me to swap my fluid in my 06 trd sport 2wd.
    It says BG fluid exceeds toyota recommendations, is that true? Is BG safe for our auto tranny's?
  12. Dec 2, 2010 at 8:22 AM
    joerussell610
    Him
    Yes good for auto trans. If vehicle has under 75k they will warranty the trans from defect after the service is done.
  13. Dec 2, 2010 at 8:47 AM
    Butl3rM0nk3y
    Butl3rM0nk3y Well-Known Member
    Brandon
    Loveland, CO
    17 Inferno TRD OR 4x4
    Soft-Topper Bed Mat Bed bolt D-Rings
    I had the Lewisville Toyota dealership tell me $500 for a flush with a machine. Also told me that you couldnt replace a u-joint in the drive shaft with any assurance that the shaft would still be in balance. That guy was a jackass, I laughed at him. Did the u-joint myself for $20 in part cost and about an hour of my time. Called the Toyota dealership in Hurst, and they charge $169 for a flush. $285 is a bit high.
  14. Jan 3, 2015 at 4:47 AM
    ShoreBoy
    ShoreBoy New Member
    Eastern Shore MD
    12 TRD DC Sport
    I had a BG flush right before I hit 35K on my 2012. Less than 800 miles later the rear of the truck would shake when the engine hit about 1,500 RPM and the speed was between 30 and 40 mph. Toyota said the BG flush was done incorrectly and damaged the transmission. A new one had to be installed. Anyone ever hear of this before?:mad::eek:
  15. Jan 3, 2015 at 5:36 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Id look for another diagnosis and not mention the trans flush. Seems odd to me that a transmission problem would cause a vibration in the rear of the vehicle.
  16. Jan 3, 2015 at 5:45 AM
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
  17. Jan 3, 2015 at 7:23 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    That's for a complete fluid flush/change with the BG machine? BTW, very happy with the alignment your tech did, thanks :).
  18. Jan 3, 2015 at 8:56 AM
    taco 2011
    taco 2011 Well-Known Member
    Alabama
    2011 Toyota Tacoma TRD SR5
    Westin Bull guard,predator nerf bars, Window Tint Legal limit, Weather tech Floor mats, Weather tech smoke visors, Wet Okole seat covers, OEM Roof Racks, Reverse Camera, Pace Edwards Full Metal Jack Rabbit Cover,Dyno power locking tailgate Trd alloy wheels, Dunlop at tires JL Stealthbox, JL custom fit molding kit, Directed Audio 500 watt amp, LCI adaptor. More mods to come.
    I don't think i have ever done this. Am I really supposed to do it every 30,000 miles ? I did do my 30,000 mile change at toyota. Is that something they do at 30,000 mile service ? I'll check my receipt just wondering what you all think.
