Is 300 miles per tank good?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Mar 31, 2014.
  1. Apr 2, 2014 at 4:19 PM
    #41
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I'll be lucky to get 200 miles per tank.
  2. Apr 2, 2014 at 4:28 PM
    #42
    rademan11
    rademan11 Well-Known Member
    DFW TEXAS
    4X4 trd off road
    Ranch Topper, Bull Bar.....Yes, I know everyone thinks they are crap, I like the look
    2014 ...... DCSB 4x4 6cyl. Auto
    On week 6 with it.
    15 to 16 mpg.
    Hit the highway last weekend, 17 mpg.
    1700 miles total.
    Hoping milage gets better with break in.
  3. Apr 2, 2014 at 5:10 PM
    #43
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Wtf? Why only 200mpt. ?
  4. Apr 2, 2014 at 5:36 PM
    #44
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    The race car burns 2.2-2.7 gallons per burnout and 1/4 pass. Is that bad?. Only $1100 for 55 gallons(VP116Nos).
  5. Apr 2, 2014 at 5:38 PM
    #45
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    A huge amount of things. I need a MAJOR tune up. I need a new air filter housing. The housing itself has holes in it from the previous owner and the pipe that goes from the housing to the throttle body (i think) has separated from the housing (supposed to be one piece). Pair that with the aftermarket Mass Air Flow Sensor that a stupid mechanic put in cause he got a good price on it and the fact that my tires are dry rotted and very low on tread and the U-Joints in my tranny needs replacement. I actually did a test. I got a GPS app on my phone that would register acceleration, average speed, current speed, and miles driven. I had a 1/4 of a tank. I drove until the needle hit E which was 30 miles later with an average of 18 mph. I NEVER take it on the highway unless its necessary because of this. I got quoted for a complete tune up from Toyota for $3406.68. I told them, I'd might as well trade mine in for a new one.
  6. Apr 2, 2014 at 5:44 PM
    #46
    frycook
    frycook Well-Known Member
    Zach
    Tacoma, WA
    07 Speedway blue TRD OR
    All Pro LT w/ fox 2.5x8" RR coilovers, Rear will have B.A.M.F Shock relocation kit w/ Kind 12" smoothies RR, ATO hybrid bumper, All Pro sliders
    I wish my numbers looked like OP's lol
  7. Apr 2, 2014 at 9:32 PM
    #47
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Ive never seen 300 in my 2.7 single cab. Even with 85% highway driving.
  8. Apr 3, 2014 at 5:49 AM
    #48
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Reg. Cab is at the least 16 gal.
  9. Apr 3, 2014 at 10:26 AM
    #49
    gray223
    SE Missouri
    2014 Tundra Limited
    4x4 reg have 18. Think 2wd have 16.
  10. Apr 3, 2014 at 3:28 PM
    #50
    Andy.G
    Andy
    Virginia
    Sounds right.
  11. Apr 3, 2014 at 5:49 PM
    #51
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    2001 DCSB 3.4 and I get 220 per tank (15.7 avg. gal/ fill up). I'm hoping the P0420 code has something to do with my bad gas mileage so when I do get new cats and 02 sensors hopefully my average MPG will increase by a couple
  12. Apr 3, 2014 at 10:13 PM
    #52
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    i just took a trip to arizona. i put a bottle of lucas UCL and a full tank of 91 octane chevron and i got 320 miles out of a full tank! i have a 2.7L auto. forgot to mention that cruise control at 80 helped also
  13. Apr 4, 2014 at 11:32 AM
    #53
    Mikeyjd
    Mikeyjd MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    It's better for fuel pump life to not run the tank extremely close to empty. The fuel doubles as a cooling agent in the case of the fuel pump and lower fuel levels cause decreased cooling to take place. The only place I can see it mattering how far a tank will get you is if you are going way out in the wilderness and don't have access to enough jerry cans for the extra fuel needed.
  14. Apr 4, 2014 at 11:49 AM
    #54
    Sirbarkz2much
    Sirbarkz2much Well-Known Member
    Sherman Oaks,CA
    02 PreRunner SR5 Limited Double Cab
    I'm running BF Goodrich All Terrains 265-75 R16's I keep the air pressure at about 30psi.
    Load Index E I believe.
  15. Apr 5, 2014 at 12:03 AM
    #55
    beedoola
    beedoola Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    300 seems good. I usually get anywhere from 280 to 310.
  16. Apr 5, 2014 at 5:03 AM
    #56
    yotaco03
    yotaco03 Active Member
    Maine
    03 tacoma TRD SR5 V6
    bone stock
    well i thought i was doing bad but from the looks of things i guess im doing alright. ive been filling up at about 260-270 and putting in a little over 16 gallons. this should improve once i lift her up and throw some bigger tires on.... NOT
  17. Apr 5, 2014 at 5:57 AM
    #57
    FEARFACT
    FEARFACT Well-Known Member
    03 double cab 4x4
    coilovers,33s etc
    200 and im in need...the most I remember going was about 230 and my light was on
  18. Apr 5, 2014 at 6:26 AM
    #58
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If I'm easy on the skinny pedal I can get about 16mpg I don't so its less on most fill up's. That's a supercharged 3.4 on 37x12.50's with 5.29 gears.
  19. Apr 5, 2014 at 6:36 AM
    #59
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Hi,
    Just filled up bluTaco, dcsb Prerunner, TRD cai, 265/65-17 Goodyear Silent Armor @35 psi, all cold weather, 160lbs ballast in box, all short trips, mostly six miles, a few at 15-20 miles, no warm ups, no idling, 10% corn squeezings, 285.8 on the trip odo, 16.01 gallons= 17.85. I think that is very acceptable.
  20. Apr 5, 2014 at 9:08 AM
    #60
    Zer0
    SGV, California
    99 PreRunner
    i got about 300 only of im going on a long trip and put 91 chevron with lucas ucl. i did a trip to AZ last week from So Cal and got gas when I was near empty at 302 miles. then again i have a 2.7 2wd
