Is 32 psi good to run in stock highway tires in my SR?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by carlk, Apr 17, 2022.
  1. Apr 19, 2022 at 8:34 AM
    #41
    Alky
    Alky Well-Known Member
    Denny
    2020 Prerunner Sport
    Lomax, Kicker upgrades and JL Audio 8" sub.
    I don't believe so. Totally different scenario but on my 69 Camaro 18' fronts I run 45-47 psi on a stiffer suspension.
    The only takeaway from running a higher tire pressure is taking away the plushness of the ride quality. IMOP.
    But to each his own . Aloha
  2. Apr 19, 2022 at 10:29 AM
    #42
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the door placard says 32 psi on my trucks so that's a good starting point. sometimes i lower the rear to 30-31 if i'm running with an empty bed. helps with the rear end staying planted with no weight in the bed.
    davidstacoma likes this.
  3. Apr 19, 2022 at 12:47 PM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had a 66 gto street/strip car, never ran more that 32 psi in that car with normal driving...if i did the center of the tires would wear out first. Going to the strip was different with the 90/10 front shocks, and 10.50 15'' rear slicks...only ran 10 psi in the slicks, and pumped the front tires to 40 psi.
    shakerhood and davidstacoma like this.
  4. Apr 19, 2022 at 1:52 PM
    #44
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    his name is steel wheels so i guess he likes it rough
    Tac0Tic0[QUOTED] likes this.
  5. Apr 19, 2022 at 3:58 PM
    #45
    zoo truck
    None
    Your kidding right? the truck would be bouncing, and jittering all over the road. They originally had 35-36 psi in them from the dealer when i drove the truck 160 miles home. Between the weird transmission hunting, and very harsh non-compliant ride...i was wondering what i had purchased if the right decision that i should have got another tundra.
    Setting them to 32 psi after i got home was night and day difference....was even better swapping to the goodyear adventure tires at the same psi.
  6. Apr 19, 2022 at 4:21 PM
    #46
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I'll one up that. The wife was driving the truck and stopped by discount tire to air up as one tire seemed a little low. The next day, I took the truck and it felt like someone had changed out my suspension and put 2000lb springs. I checked air pressure and it was 46 psi. I usually run about 33-34. What a difference.
    zoo truck[QUOTED] and shakerhood like this.
  7. Apr 20, 2022 at 6:14 AM
    #47
    zoo truck
    None
    Its a fact you run excessive air pressure in your tires its harder on the front end components not to mention your tire will wear far more faster in the center. There's a reason for the manufacture stating the correct psi to run at.
  8. Apr 20, 2022 at 11:27 AM
    #48
    zoo truck
    None
    Well then by all means...carry on.
