is $335 a good price for dealer to install a timing belt kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, May 3, 2017.
  1. May 3, 2017 at 11:52 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    its a 4runner with 4.7 v8 and im supplying all the parts so its just the labor charge, dealer said it would be $335 to do it.
    is that a fair price? I think it sounds reasonable for how much work is involved, but I wanted to check with you guys on that.
    I am not in good health to do it myself and for the peace of mind, as well as the warranty, I would rather have a Toyota dealer do it, rather then just finding some shop to do it trying to save a couple of dollars.
    I want to be sure im being charged reasonably for the work
  2. May 3, 2017 at 11:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sounds fair.
    Whats the parts list?
    They'll accept using your parts? Seems unusual.
    Hope you get feeling better!
    keakar[OP] likes this.
  3. May 3, 2017 at 12:03 PM
    keakar
    karl
    louisiana
    thanks guys, wasn't sure just how long it would take to do it but I was "assuming" it was a several hour job so I was thinking it was a good price too, but I just wanted to hear some confirmation on it
    its the oem kit from aircabinman so its all oem Toyota parts and that is why they are ok with it
    as to feeling better I have permanent back issues so no more crawling under the hood for me, replace battery or alternator and maint tune ups is about the best I can manage
    Includes The Following Brand New Parts:
    Quantity Part Manufacturer Part Number
    1 Timing Belt Toyota 13568-09070
    1 Idler Roller Koyo OE 13505-0F010/50030
    1 Tensioner Roller Koyo OE 13503-0F010/50011
    1 Front Crankshaft Seal Toyota 90311-A0001/43006
    2 Front Camshaft Seals Toyota 90311-71001/71002
    1 Water Pump Aisin OE 16100-59275-83
    1 Water Pump Gasket (Metal) Aisin 16271-0F010
    2 Water Pump O-Rings Ishino/KP - - - - - - - - - -
    1 Thermostat Toyota 90916-03100
    1 Thermostat Gasket Ishino 16346-50010
    1 Hydraulic Tensioner Toyota 13540-50030
    1 Serpentine Drive Belt Toyota 90916-02586
  4. May 3, 2017 at 12:07 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That seems fair to me. Actually seems like a very good price for quality work.
    Throw your specs and repairs in at repairpal.com to get an idea of price range. You can separate the parts from labor as well on that site. Usually where I get an idea for quotes for folks.
  5. May 3, 2017 at 12:20 PM
    keakar
    karl
    louisiana
    what are you guys thoughts on the front engine seals being replaced?
    I hadn't thought those would be needed but new parts are never a "bad" idea
    are the seals easy to replace or add extra work to the job? they may not be including replacing these in the estimate
  6. May 3, 2017 at 12:50 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    I did a series of simultaneous maintenance at 90,000 miles (t-belt, waterpump/thermostat, transmission flush, etc), but IIRC the t-belt (parts and labor) was around $500ish. Granted, it's a Tacoma with a 3.4 and not a 4Runner with a 4.7, but still, if they do good work $350 seems like a solid price. Was going to do the camshaft seals at the same time, but they said they looked great and probably wouldn't need changing until the next t-belt change in 100,000 miles.
  7. May 3, 2017 at 12:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    I always replace cam/crank seals on things, even if they are not wet around them. Mostly because if I'm doing a 90k service I don't want to go back in for another 90k.
    Anything I touch going in and out (and maybe a few surrounding items) get refreshed at the same time.
    Cost more? Yes. But if the vehicle is a keeper, at least I know it's fully refreshed.
  8. May 3, 2017 at 1:08 PM
    keakar
    karl
    louisiana
    I guess what I am asking is does replacing those seal involve much more work or does it only take an extra 5-10 minutes to do them?
    im in favor or replacing, just wondering if doing it adds another hour labor to the price
    EDIT - ok I found out on the 4.7 v8 the cams have to be removed to change the seals so that 7 hours additional labor so that's definitely out unless they are found to be leaking
  9. May 3, 2017 at 1:10 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    that's a reasonable price.
    I had my mechanic do the same on my 3.4 4runner.
    He charged me $350 for just labor
  10. May 3, 2017 at 1:12 PM
    keakar
    karl
    louisiana
    I think the work involved is pretty much identical between the two
    https://www.youtube.com/watch?v=Z46cM-Bw1rI
  11. May 3, 2017 at 1:18 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    So around $600 all in?
  12. May 3, 2017 at 1:20 PM
    keakar
    karl
    louisiana
    just wondering, is it a good idea to have them flush and replace the tranny filter and fluid while im at it?
    the truck still looks new inside and out so I am wanting to go another 150k miles needing nothing and having no issues with it
  13. May 3, 2017 at 1:22 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Yup.
    I had that done when I they replaced the timing belt
    keakar[QUOTED][OP] likes this.
  14. May 3, 2017 at 1:22 PM
    keakar
    karl
    louisiana
  15. May 3, 2017 at 1:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    You'll have to ask the shop how they bill those. Seems to me since they are already exposed that it should just be actual time, not flat rate time.
    It takes a little more than 10 minutes, but not much with the right tool and experience. And of course if it's already damp around the area they need replacing anyway.
  16. May 3, 2017 at 1:25 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    I'm the same way, especially with long-term vehicles like mine, but despite my asking they said they typically change them out every-other 90k service, and (how un-dealership like) weren't eager to charge me money to do it.
    And well, ya gotta dive in and do another t-belt in 90k regardless? :notsure: If something is good for 200k miles, but you change it every 100k miles, wouldn't that just be extra time and cost for no tangible benefit? At some point, being that "thorough" becomes a law of diminishing returns.
  17. May 3, 2017 at 1:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Agree conceptually. Except the seals are cheap and I'm the labor. :D
    If everything was nice and dry and I intended to sell in say 30-40k, I'd probably let them slide.
    keakar[OP] and McMash[QUOTED] like this.
  18. May 3, 2017 at 1:35 PM
    2BeersPlease
  19. May 3, 2017 at 6:11 PM
    DELPIERO10
    DELPIERO10 Active Member
    JOAQUIN
    2003 RED TACOMA TRD OFFROAD
    Im surprising, my friend charge me $100 just for the labor, and I trust his work
  20. May 3, 2017 at 11:26 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I paid north of $500. A friend of mine is a master mechanic for Toyota so he hooked me up.
