Is 4.75 backspacing to much????
Discussion in 'Wheels & Tires' started by meckleystephen, Aug 5, 2010.
  1. Aug 5, 2010 at 2:58 PM
    meckleystephen
    meckleystephen [OP] My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    ive looked and cant find the answer to this i am looking into buying some pro comp 1079s and they only come in 4.75 backspacing, most guys i see run 4.5 so will they work:confused:
  2. Aug 5, 2010 at 2:59 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    depends on what size tires you want to run. 285s? then most likely not, you want 4.5s or lower
  3. Aug 5, 2010 at 3:00 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    they should... depends what size tire you get..
  4. Aug 5, 2010 at 3:01 PM
    meckleystephen
    Stephen
    York, PA
    well i am running 265/70/17 nitto terra grapplers and was going to keep them
  5. Aug 5, 2010 at 3:04 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    you'll be fine then
  6. Aug 5, 2010 at 3:06 PM
    meckleystephen
    Stephen
    York, PA
    thanks alot that question has been buggin me i love those wheels
  7. Aug 5, 2010 at 3:10 PM
    meckleystephen
    Stephen
    York, PA
    the ones i i was looking at were 17 x 9 is that wide enough to fit the tire sorry i just dont understand all the wheels spacing and what not
  8. Aug 5, 2010 at 3:15 PM
    Jetta1cab
    Jetta1cab Well-Known Member
    Carlos
    Yuma, Arizona
    08 TRD Sport PreRunner
    Bilstein 5100s @ 0 with OME885x coils. Toyota Rear TSB. Billet grill inserts.
    Width should be okay... depends on whether it's LT or P rated tire. Per NITTO Tires website the approved rim widths for the Terra Grappler on a LT tire is 7.0"-8.5"; For the P tire it's 7.0"-9.0"
    http://www.nittotire.com/index.html#index.tire.terragrappler.sizes
  9. Oct 3, 2020 at 2:58 PM
    Truckdogipa2
    Truckdogipa2 Well-Known Member
    Mark
    2011 Tacoma trd sport long bed
    New frame, Upper control arms, roof rack , method wheels fallen tires duel battery
    I have method 703 they are 4.75 and run the 275/70r17 lt tires from Falken and I def touch the frame it’s very frustrating
  10. Oct 9, 2020 at 2:41 PM
    TacX2
    TacX2 Member
    FL
    19 OR 4x4
    Do you have any pics of the 703? Was thinking about getting them and can’t find any pictures of them on a Tacoma. Curious about them rubbing also was looking at 265/75/16 which shouldn’t be a problem but was looking for some thoughts about the wheel. Thanks
  11. Oct 9, 2020 at 2:52 PM
    Truckdogipa2
    Mark
    It touches my frame w 275:70r17 I love the rims I would highly recommend them . I did a little cutting around my frame anyways w 265 if mine barley touches I’m sure your all set
  12. Oct 9, 2020 at 2:53 PM
    Truckdogipa2
    Mark
    Also I’m on a 2 in lift
