is 4 cylinder 2.4/2.7 ECM reprogramming/tuning possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Mar 20, 2015.
  1. May 17, 2019 at 8:53 AM
    kmeeker
    kmeeker New Member
    Looking for a ecu flash file to run with my Tactrix Openport 2.0 (bought for my Subi but trying to help hubby with his Taco). I'm confused, I thought 1996 on was OBDII?
  2. Jul 10, 2021 at 9:02 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    So op or others ever find a solution? I have a 97 2.7auto aswell and ive done EVERYTHING under the sun and it still has rough idle, been wondering about if I sc or i get tune can i adjust. Atm I just use the ac and it runs smooth.
  3. Jul 11, 2021 at 6:01 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Jul 11, 2021 at 6:16 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
  5. Jul 11, 2021 at 7:29 AM
    YotaGangYotaGang
    Covina
  6. Jul 11, 2021 at 7:29 AM
    YotaGangYotaGang
    Covina
    ima mark it first then do it, gonna put it in drive w/ someone holding the brakes
    Black DOG Lila likes this.
  7. Jul 11, 2021 at 7:48 AM
    Rachelsdaddy
    Southern NH
    BlackDog likes this?!?! She knows better. It will increase temporarily. Very. Then it will return to where it was but now it’s as if your throttle bore is worn out because the plate can’t close and the TPS will read differently. The only acceptable time to mess with that stop is if you have slight bore wear and the plate sticks shut. But have fun regardless which way you go. I gotta mow the lawn. PS. IAC is responsible for idle…..
  8. Jul 11, 2021 at 7:51 AM
    YotaGangYotaGang
    Covina
    well ima mark it and if it goes back to normal ill just put it back where it was. the link she put was the same link i got idea from, the guy moved his and says its been over a month and its smooth, at this point ill try anything
  9. Jul 11, 2021 at 8:02 AM
    Rachelsdaddy
    Southern NH
    I understand 100%, the belt is off my AC, in traffic I turn it or the defrost on low…. Annoying. Only way around it is to increase voltage to IAC… sucks
  10. Jul 11, 2021 at 8:04 AM
    YotaGangYotaGang
    Covina
    What do you mean? You experiencing same thing i experience? You took ac belt off for you can turn on ac but not have air blow thru? how do i increase voltage to iac
  11. Jul 11, 2021 at 8:16 AM
    Rachelsdaddy
    Southern NH
    Yeah, the compressor obviously won’t turn but the fan works and your idle will rise cuz the ECM is sending IAC more voltage to increase the idle because it knows that you are adding the load of the compressor…. I imagine if you had nothing better to do you could run a separate circuit with a potentiometer to the IAC, you’ll have to dig up the schematic. Anything is possible w/ determination and money…. Over and out.
  12. Jul 11, 2021 at 8:19 AM
    YotaGangYotaGang
    Covina
    is that what you did? I emailed lcengeneering to see what they can do for me, ill see if they get back to me on Monday. Maybe adding a sc will increase rpm on idle? idk, but searching on here it seems a lot of people have this problem
  13. Jul 11, 2021 at 8:26 AM
    Black DOG Lila
    Virginia
    Only you would fix a worn butterfly stop by removing the AC belt and running defrost to up RPM
    :rofl::rofl::rofl:
    If the setscrew and seat is worn how would the TPS know full closed is too far?
  14. Jul 11, 2021 at 11:04 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    The haltech custom designed ecu solves the tunability problem right?
  15. Jul 11, 2021 at 12:09 PM
    #35
    YotaGangYotaGang
    Covina
    does it? idk what tht is
    crazytacoman[QUOTED] likes this.
  16. Jul 11, 2021 at 2:01 PM
    #36
    Rachelsdaddy
    Southern NH
    Mine isn’t worn you meathead. The belt is off because the compressor is junk. Put the bottle down and re-read the thread. The stop screw can be turned a 1/16-1/8 turn if the butterfly is jamming in the bore due to slight wear. The TPS is attached to the throne shaft. If you screw with it too much the normally 11% with throttle closed changes upwards of 14%….. then what Ms Smartypants?
  17. Jul 11, 2021 at 2:02 PM
    #37
    Rachelsdaddy
    Southern NH
    To Hell with it. Remove the locknut so you can get an additional turn or two.
