is a 09 tacoma rear diff a 8" or a 8.4"?
Discussion in 'Technical Chat' started by taco_man, May 20, 2010.
  1. May 20, 2010 at 10:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    The VSC/ATRAC is Toyota's Electronic verison of a Limited Slip Diff. So, you basically have the same thing.
  2. May 20, 2010 at 10:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    Jegs is a big aftermarket supplier, like Summit, or Quadratek (sp?)
    http://www.jegs.com/
  3. May 20, 2010 at 10:33 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    VSC/TRAC are standard on the 2009+ Tacomas. But A-TRAC is not. Active Traction Control or A-TRAC is only available on the Off-Road model trucks.
    I know... Similar names.
    Fixed it for you. :D
  4. May 20, 2010 at 10:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    :p
  5. May 20, 2010 at 10:35 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    The wiring may be there - I thought I saw a thread on that. Think about it - It is just software burned on some chip in the Anti-Lock brake computer.
  6. May 20, 2010 at 10:42 AM
    Crom
    Nick
    San Diego, CA
    Millions
    For anyone that may be interested. If you alter the geometry of your suspension such that you require a front end alignment adjustment, then you should have the VSC recalibrated. The dealer can do this service for you, or I believe you can do it yourself. There are two steps to complete the process:
    1. Clearing zero point calibration data.
    2. Yaw rate sensor and deceleration sensor zero point calibration
    Here is the procedure.
    Because the OP is running 37" tires, he would want to have this service done.
  7. May 20, 2010 at 10:48 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Unfortunately there are hardware differences. The 2009+ Off-Road models have a hydraulic brake booster, whereas non-off road (Sport /SR5) models have a vacuum brake booster. The wiring diagrams are also very different as are the modular plugs for the various ECU's.
    It is presumed that A-TRAC requires much more hydraulic pressure thus the change in hardware.
    If you or anyone else is interested I be glad to share any technical diagrams I have on the subject. (PM me).
  8. May 20, 2010 at 11:02 AM
    HBMurphy
    Paul
    So California Coast
    None
    Bravo! I like to see a man that knows his shit. Me? I pretty much talk out my ass! :D
  9. May 20, 2010 at 11:12 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks. FWIW, I do hold you in high regards. How many people around here have done a solo job regearing both front and rear diffs? :D That is totally awesome and way beyond my experience. :cheers:
  10. May 20, 2010 at 11:18 AM
    HBMurphy
    Paul
    So California Coast
    None
    Well, if you ever need my help. It is yours for the asking. :D
    I've said it before, but your contribution to this social experiment we call "Tacoma World" is outstanding! Keep it up! Me as well as many others are thankful!
  11. May 20, 2010 at 11:41 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Either way he needs to probably be very careful with that. Would be nice to know if truetrac works and how it works with electronic traction controls. I am subbed to this thread so hopefully we will know.:)
  12. May 20, 2010 at 11:51 AM
    jandrews
    '09 FourDubDee TRD OR
    All 09+ have VSC. ATRAC is only on TRD Offroad trucks.
  13. May 20, 2010 at 12:06 PM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    darn still no verdic on wether or not this will work.... anyone know who i could call to find out whether it will work or not???
  14. May 20, 2010 at 12:09 PM
    BlueT
    NorthEast
    Ok, i just know not to buy 09+ Tacomas. :D
  15. May 20, 2010 at 12:11 PM
    #35
    Crom
    Nick
    San Diego, CA
    Millions
    I just read up on Trutrac. Am I correct in believing it's a drop in differential made by Eaton?
  16. May 20, 2010 at 12:13 PM
    #36
    98tacoma27
    Ben
    Not Beech Creek
    It's a mechanical LSD, so yes. You just bolt the ring up to it and throw it in (set-up required of course).
  17. May 20, 2010 at 12:15 PM
    #37
    taco_man
    Austin
    Houston
    09 texas edition
    already called eaton and all they told me is we dont make an application for the 2nd gen tacoma. i told him im matching the axle and he told me i could not do it. im still not convinced that i cannot do this. but im trying to figure out who to call. ghost busters maybe?
  18. May 20, 2010 at 12:21 PM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    My info is based on people who have done it. That is the part they used. Again, they weren't 09's though.
  19. May 20, 2010 at 12:23 PM
    #39
    taco_man
    Austin
    Houston
    09 texas edition
    ya blacktaco21 used it but im just worries about vsc. is there anyway i can get rid of the vsc?
  20. May 20, 2010 at 12:23 PM
    #40
    98tacoma27
    Ben
    Not Beech Creek
    Unplug the ECU :notsure:
