Is a K&N Air Filter worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD-baby, Oct 17, 2017.
  1. Oct 17, 2017 at 7:37 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    you might gain 1 horsepower at 6,000 rpm if you pair with a CAI and exhaust.
    So yeah, totally worth it in my book :rolleyes:
  2. Oct 17, 2017 at 7:47 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Listen to the "old man", he's got a K&N a/f in his build list on his sig.
  3. Oct 17, 2017 at 8:18 PM
    MHARMS
    MHARMS Well-Known Member
    2014 Black Tacoma TRD sport DCLB
    GoRhino Dominator D2 nerf bars, K&N air filter, LED cabin lights, Neoprene seats, Billstein 5100 front shocks 2.5" lift, ultra crusher 17” wheels w/ko2s, DIY tinted tail lights, LED reverse lights, CONDENSATE DRAIN HOSE EXTENTION!
    Exactly
  4. Oct 17, 2017 at 8:28 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    K&N? Never again- downstream oil mist burned out the air flow sensor on my 2002 TRD, the replacement cost was so high, I would never have paid that much in paper filters for the years I had the truck. And no, I didn't overspray the oil or not follow directions properly, in fact the service I bought it from was maintaining it for me.
    TacoTuesday!! likes this.
  5. Oct 17, 2017 at 8:38 PM
    CJREX
    CJREX Well-Known Member
    Georgia
    All of the performance gains you experience will be directly correlated to the weight reduction experienced by your wallet.
    The lighter your wallet, the less mass that has to be accelerated.
    Add in a throttle body spacer and a fart pipe and you will be within spitting distance of an Alcubierre drive :burnrubber:
    Or just go buy a bottle of snake oil when it's on sale.
    IOW, No.
    DaveInDenver likes this.
  6. Oct 17, 2017 at 8:47 PM
    ChuckWW3
    ChuckWW3 Active Member
    Charles
    San Diego, Ca
    2011 Sport DCSB
    - Bilstein 5100's Front - 5160's Rear - Eibach Coils - ICON AAL - TC upper control arms - Cooper ST MAXX (255/80/17) - ICON Rebound wheels - TRD Cold air intake
    I have the K&N "CAI".....If you take a look at your stock filter/ filter box you'll realize that it's more of a cold air intake than the K&N...@or above 5000rpm you will notice a tiny increase in HP and it definitely sounds really throaty but not worth it in my opinion...as far as your MAF sensor being damaged by it...all you need to to is pull the sensor and clean it every do often...takes about 5 minutes.
  7. Oct 17, 2017 at 9:54 PM
    OnHartung'sRoad
    Cleaning the sensor body would help to keep oil deposits down, but the carbon buildup on the heated sensor wires on mine was from burning oil mist carried in the air passing through the filter, causing the wires to break. I don't think cleaning will be effective on the sensor wires directly. I hadn't cleaned it, and upon opening up my dead sensor, it was pretty obvious that red K&N filter oil mist being deposited on the sensor wires caused the problem.
  8. Oct 18, 2017 at 6:54 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I would use the OEM Toyota paper filters(made in USA), they are better build and quality than the aftermarket filters, ive tried a few cheaper aftermarket filters and none have the build quality of the OEM Filter,just got to search online for the best prices they will cost a little more.
  9. Oct 18, 2017 at 7:04 AM
    DANGERMONEY
    DANGERMONEY Well-Known Member
    I would stick with the paper. I've had the KN drop ins and the cais.
    Nothing major but noise.
  10. Oct 18, 2017 at 7:55 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Most people around here swear that they let in more dirt. I do mostly road driving to work so I'm trying one out right now. I've ran them in every car I've owned and most of my family's cars without issue. My Dad's Outlander has been running fine with one for over 100,000 miles.
    Will you notice a difference? Probably not until you get up in the RPMs. Is nothing huge, but I did it to let my truck breath a little better one hot/humid Midwestern Summer afternoons.
  11. Sep 2, 2018 at 8:34 PM
    Joisey
    Joisey Well-Known Member
    I have run a K&N filter in my 1990 F150 pickup (302) for 114K, my 91 Ford Explorer (4.0 V6) 89K, my 2006 GMC Sierra (5.3) 126K and a Husqvarna ZTH6125KAA zero turn two cylinder Kawasaki air cooled engine equipped with a Donaldson type filter housing for 16 years and counting. Not one engine burned oil. Not one engine harmed a mass air flow sensor (auto engines only, of course).
    The major difference was seen on the Kawasaki engine on the Husqvarna. It's a rear engine unit equipped with an inner and outer filter (both OE Kawasaki). The original outer filter would let enough fine dust thru it to make the inner fine filter discolor with dirt. The inner filter appears to be a fine mesh white felt over a screen with molded ends. Replacing both filters cost over $40. I put the K&N outer filter in the housing along with a new inner OE fine filter. That was 16 years ago and I have yet to find any dust on the inner filter. It is as white and clean as the day I put it in.
    If any engine would be eaten by fine dust, this would be this one because it is a rear engine design, cutting grass in dry hot weather. I have to change the blades 3 times per year because thin patches in the grass allow the blades to pick up grit and sand blast the edge off of them.
    So, over 320 K street and dirt road miles on car engines and 16 years cutting 8 acres per cut, every week on an average during the cutting season for 16 years and counting and zero dirt problems getting past the K&N filters.
    WhiteyII and grubburg like this.
  12. Sep 2, 2018 at 8:37 PM
    Jimbo2
    Jimbo2 Well-Known Member
    2018 Trd off road dcsb
    K&n is pure crap and the oil will get into your maf and can fuck shit up
    BadAss182MK likes this.
  13. Sep 2, 2018 at 8:58 PM
    AZF1504x4
    AZF1504x4 Well-Known Member
    Just put the K&N sticker on your back window that’ll do the same as installing the filter itself.
    Gator352, shakerhood and BadAss182MK like this.
  14. Sep 2, 2018 at 9:15 PM
    BadAss182MK
    BadAss182MK Well-Known Member
    2018 Tacoma TRD Off-Road
    :amen:
  15. Sep 3, 2018 at 5:28 AM
    #35
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    The computers in your truck automatically adjust for air/fuel flow. Throwing in a K&N does nothing for fuel mileage or performance.
    Taco1.1 and shakerhood like this.
  16. Sep 3, 2018 at 6:15 AM
    #36
    lebvette75
    lebvette75 Well-Known Member
    Larry
    Pine Bluff, Arkansas
    2017 Tacoma TRD Offroad 4x4...Excess Cab...Dark Gray color
    Method 305NV machined face wheels(16") BF Goodrich AT KO2 (stock size) Marathon camo seat covers Skinz tailgate letters AVS window visors
  17. Jan 19, 2019 at 8:29 PM
    #37
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I had a great result with mine and 90k miles. Zero problems and definitely faster. The exhaust didnt add any power, but I'm positive the K and N did. if it didn't, pretty sure they'd have been class auctioned by now.
