Is a K&N cold air intake worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoworld22, May 11, 2017.
  1. Jul 2, 2017 at 3:15 PM
    #41
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    And then I usually show up and post this test that found zero decrease in mpg with even an extremely clogged filter.
    I'll get the same, "clogged doesn't prove that a slight increase can't" or "2 straws are better than one" argument. Even get the "government funded study, invalidates it".
    Results show that clogging the air filter has no significant effect on the fuel economy of the newer vehicles (all fuel injected with closed-loop control and one equipped with MDS). The engine control systems were able to maintain the desired AFR regardless of intake restrictions, and therefore fuel consumption was not increased.
    Closed-loop control in modern fuel injected vehicle applications is sophisticated enough to keep a clogged air filter from affecting the vehicle fuel economy.
    http://www.fueleconomy.gov/feg/pdfs/Air_Filter_Effects_02_26_2009.pdf
    This is an 8 year old study, but I've also gotten the "this is an 8 year old study" argument like a newer EFI would work worse than old technology.
  2. Jul 2, 2017 at 3:30 PM
    #42
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Not everyone has access to this, it's only n certain parts of the country.
  3. Apr 10, 2018 at 7:53 PM
    #43
    Airbear70
    Airbear70 New Member
    Bear
    2018 TRD OFF ROAD
    Stock so far build date is 5-11-18
    To friends out there I am ordering a trd off road want to get the most out of truck so I thought there cold air intake my work with a snorkel any ideas would help I need info fast
  4. Apr 10, 2018 at 7:58 PM
    #44
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    My idea is to start by reading the thread you just posted in. And its fast. After that there are a few dozen threads to search with the exact same info. It's all faaaaaast.
    Edit - I see it's your first post. Welcome. This thread has the info you need.
    blu92in99 and b_r_o like this.
  5. Apr 10, 2018 at 8:03 PM
    #45
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    these trucks like most every other vehicle made, already HAVE a 'cold air intake' in the form of a scoop between the headlight and radiator that feeds a rather large air filter box.
    now, if you find yourself regularly driving in extremely dusty conditions, like closely following someone on a desert dirt road, well, keep more distance. there really isn't that much less dust 6' up in the air near your cab roof than there is 3-4 feet off the ground near your grill.
  6. Dec 31, 2019 at 2:20 PM
    #46
    NOCOTaco1982
    NOCOTaco1982 Active Member
    Wayne
    2019 Tacoma TRD Off Road Cement
    Premium and tech package, Predator Pro running boards
    Does anyone have a part number for the AEM? Can’t seem to find it! Maybe just not looking correctly ‍♂️
