Is a performance chip worth it?
Discussion in 'Performance and Tuning' started by Walter541, Oct 4, 2012.
  1. Apr 25, 2013 at 5:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    TRD is 2.5" diameter. The '05-'08 factory catback was 2.25". They might have upped it in '08? I am not exactly sure when the diameter changed. All I really know, is that mine is 3.5". :p
  2. Apr 25, 2013 at 5:37 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    They kept it the same at 2.5" since I made that mistake thinking that the TRD was still 2.25" when I ordered my resonator lol I'm a 2011 so I'm sure it hasn't changed much in the 12's+
  3. Apr 25, 2013 at 5:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Oh yeah. 2011 def has 2.5". I remember when it used to be an upgrade going to 2.5". Lol.
  4. Apr 26, 2013 at 7:15 AM
    ZombieHorde
    ZombieHorde Active Member
    Utah
    13' Tacoma TRD Off
    Cat Back Exhaust, pondering others...
    That I would have to check on. I did some research and considered buying an exhaust from an online store. The trouble is I don't have a lift or a welder, so I just had the dealership do it when I bought it. I have the old system, so I can see. The specs say a 8HP gain, and 1-2 MPG gain. I can say the HP is true. Plus is sounds great. The dealer charges about $100 more than if you can do it yourself: http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idProduct=-9567
  5. Apr 26, 2013 at 9:24 AM
    Walter541
    Walter541 [OP] the game is the game
    Walter
    Los Angeles
    2004 Tacoma TRD
    Revtek 3in lift, Alpine INA 910, Westin Bull Bar, Polk Audio speakers, Kicker 1000W amp, Kicker 12in Sub, K&N Air Intake, Royal Purple Fluids, NGK Iridium IX spark plugs, NGK Wire Set, Ultra Wheels, Bigfoot XT Tires, Line X Bed Liner, PIAA Fog Lights, Limo Tint
    Is the TRD cat back only available for 05+? :(
  6. Apr 27, 2013 at 6:52 AM
    ZombieHorde
    Utah
    13' Tacoma TRD Off
