Is a pinion shim needed..?
Discussion in 'Suspension' started by Hogsnatcher, Jan 6, 2024.
  1. Jan 6, 2024 at 2:42 PM
    Hogsnatcher
    Hogsnatcher [OP] Member
    2013 Tacoma Sport - Long bed
    …for a 1” block in the rear. Currently has a 1.5” block AND a pinion shim. Want to lower just a bit.
  2. Jan 7, 2024 at 1:11 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Probably not but nobody can say for sure. Depends if you get vibes and what the driveshaft angles are.
  3. Jan 7, 2024 at 7:17 AM
    Hogsnatcher
    Is there a range of shaft angle that is deemed acceptable by Toyota, and can they actually measure pinion angle? Or, is acceptable angle simply determined by symptoms?
  4. Jan 7, 2024 at 4:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    There is a spec range. Let me see if I can find it. It’s not Toyota specific it’s specific to the current angles on the vehicle.
