Is a shop trying to shaft me?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texasdynaryder, Jan 12, 2012.
  1. Jan 12, 2012 at 4:05 PM
    Texasdynaryder
    Texasdynaryder [OP] Well-Known Member
    Chance
    Paris, Tx
    OME Nitrocharger OME Dakars All the other small goodies
    Had to put the yota in the shop for some drive line leaks... Driver side cv shaft and output shaft to front diff off the transfer case. The mechanic said he had to uninstall whole transfer case and install the oil seals. Is this normal procedure??? if so what about cv shaft?
  2. Jan 12, 2012 at 4:11 PM
    blt2tuk
    blt2tuk Well-Known Member
    Franklin, North Carolina
    1996 Toyota Tacoma
    It could be leaking where the Trans case bolts to the Trans in that scenario it would have to be removed and resealed with silicone. But if it's just a seal I dont see why the case would need to come out
  3. Jan 12, 2012 at 4:22 PM
    Texasdynaryder
    Chance
    Paris, Tx
    its leaking right behind where the u-joint is connected to the transfer case.. yoke.. spline.. output shaft.. not up to date on correct terminology:confused:
  4. Jan 12, 2012 at 4:24 PM
    Texasdynaryder
    Chance
    Paris, Tx
  5. Jan 12, 2012 at 4:29 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Do you have any pics?
  6. Jan 12, 2012 at 4:32 PM
    Texasdynaryder
    Chance
    Paris, Tx
    sadly no its in NE texas.. im down south
  7. Jan 12, 2012 at 6:10 PM
    Texasdynaryder
    Chance
    Paris, Tx
    the bottom shaft...
